Introduction: Make a Motor Pulley for Sewing Machine
Sometimes finding the right replacement part for an old machine is near impossible. It may be easier to build one from scratch. here is how to build a 3/4 inch pulley for an old sewing machine.
I Made it at TechShop (Chandler) http://www.techshop.ws
Materials and tools:
3/4" x 4" steel rod
8-32 thread tap
8-32 set screw
1/8" drill bit
1/4" drill bit
center drill
drill press
Metal Lathe
HSS lathe bit
sandpaper
Step 1: Start With Sketch or Drawing
Step 2: Turn Metal Stock to Desired Diameter
Step 3: Center Drill Metal Stock
Step 4: Grind Lathe Bit to Cut Profile Per Spec
I found a spec sheet for different size pulleys on google. Grind your bit to 16 degrees per side to make a 32 degree v-groove.
Step 5: Cut V-Groove With Lathe Bit
Cut groove till it is the correct diameter from the drawing. cut the width so it matches the drawing.
Step 6: Drill Pulley to Shaft Diameter
Step 7: Cutoff Pulley With Parting Tool.
Use plenty of cutting oil
Step 8: Center Punch for Drilling
Step 9: Drill Set Screw Hole for Threading
Step 10: Tap Threads Into Set Screw Hole
Step 11: Install Set Screw
I also polished the pulley a little.
