Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
http://www.titanium-jewelry.com/abouttitanium.html
And here is a link about BLACK titanium.
http://www.titanium-jewelry.com/about-black-titanium.html
At our jewelry store we regulary polish our customers titanium wedding bands.
Here is how we do it. We use the 3 stage platinum polishing process to polish out gray titanium.
1) Start with 800 grit rouge compound getting deep scratches out.
2) Switch to 1500 grit
3) Final step use 8000 grit for an ultra reflective high polish
The result is very nice!
I heard that Anodizing titanium it's amazing.
Cheers!
http://www.ebay.com/sch/Metals-Alloys-/29402/i.html?_from=R40&_nkw=titanium+plate
Read this: http://mrtitanium.com/interference.html
Pretty neat stuff!
http://www.youtube.com/watch?v=N07NpyXisRg
This really shows you how fast it is. I gotta get some Titanium... fun stuff.
http://youtu.be/RE3Ia6nuaRs?t=2m46s
Where did you order the Titanium? And how much did it kost?
What if there was not a jeweler close by with the tool? Then people would go to the emergency room where they had the same tool but with an electric motor to power the blade. Here is where the caution comes in: If anyone used that cutter on a titanium ring, the blade would have been completely dull in less than 10 seconds! Titanium resists that kind of cutting and it doesn't transmit heat easily. The friction of the blade on the metal generates a lot of heat. All the heat stays in the blade and kills the hardness in seconds.
Not meaning to rain on the parade but titanium rings are unsafe.
Now a suggestion: Make the ring out of a metal that can be cut and inlay it with titanium. The metal is beautiful and colorful when treated correctly. You could have a one-of-a-kind ring that is still safe to wear as long as there is a place that a blade can cut the base material. Silver is a good and not too expensive choice. Softening the silver would allow for the inlay process.
Peace.
I bet that CP2 ring Mr. Balleng made would anodize to all kinds of beautiful colors.
However, if it's soft metal you may not even need the trip to a pro, can just snip it off with common hand tools.
Cheers.
