3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make your own solar powered led string lights. ($5 bucks max)
  Making a basic solar powered string of led lights isn't too difficult.  This instructable will require no electronics knowledge and no programing.
  What were will be doing is upgrading some old battery powered mini lights to LEDs and then using some basic components, charging the batteries with a small solar panel.  With the aid on 1 IC and 1 inductor, we can automate the string so it turns off and charges during the day and turns on at night.
Let's get started.
Step 1Let's see what we need to get started.
29 comments
Mar 26, 2012. 3:27 PMiApple guy says:
Just made mine for under $2 my own way. It works with glass pannels, and it looks COMPLEATLY different. Instructable coming soon!
Mar 26, 2012. 9:49 AMiApple guy says:
(removed by author or community request)
Mar 26, 2012. 9:25 AMiApple guy says:
I started to think about this project again just today, and I figured out how to make this with glass pannels. I will make the instructable soon, well actually today so come check it out. It will not be up til later today, I still need to make it!
Dec 16, 2011. 11:58 AMaalnizzo says:
Couldnt find that LED driver chip anywhere.
Got these ...
http://www.diodes.com/datasheets/ZXLD383.pdf
instead. Because of this and your diagram here I think I got an idea of how to wire it right but not 100%. With this chip instead of the one you have here, a) my wiring below should work right? (on my chip) (see pic).
Will this charge bat? and keep the solar cell from draining power?
Dec 17, 2011. 3:06 PMaalnizzo says:
Thanks! Appreciate it. Yeah this chip is freaking tiny!. Wound up having to solder solar tabbing to the connections super carefully to have something to solder the wiring to. Seriously didnt think they would be this small, like a mm, by two mms, with three connections on the one side. Talk about a challenge to solder. Building them now, will be glad to see then working soon!
Sep 2, 2011. 8:04 PMiApple guy says:
I took my LED solar lights apart, and now they aren't working. I tried soldering them, and maybe I melted the wire connections (as seen in photo). These were some different looking solar panels on some landscape lights I bought at Wal-Mart. Can somebody give me some advice?
Sep 3, 2011. 11:24 AMiApple guy says:
yes they are glass panels
Jul 23, 2011. 7:20 AMtrknjim says:
Is the 220uf inductor a capacitor or are you using a 220 ohm resisitor? I didn't see a schematic, just a diagram mock for the components. Pretty sweet a simple... I like it !!!
Jul 23, 2011. 6:51 PMtrknjim says:
Thanks for the fast reply. Do you have the inductors and the ICs for sale? I found numerous inductors and in different values, BUT STILL CAN'T LOCATE the QX5251F IC. Seems to be a proprietary component !!!
Jul 12, 2011. 2:46 PMshanakoenig says:
Thanks! I am actually working with a cheap solar light currently (in quantity purchased for about $2 each). I have been reading some basic electronic books, tons of instructables and the comments and going through the overunity joule thief forum. I have learned a lot but have come onto a few basic stumbling blocks I would love any advice on.
Basic goal:
Build an efficient circuit that can run a large LED array at 3.4 volts 20 ma per LED (full brightness). I would love to be able to do between 10 and 30 on a single circuit, but I can always do 2 circuits if it is more efficient that a single circuit. Obviously I know the more leds I use the big the solar panel I will need and larger battery capacity.
Set up:
When I take apart my basic cheap solar light I can only run 1 or 2 color changing led well off the current circuit, if I add a third LED they start to flicker. I currently have modified a few to run 2 LEDs or 3 with some flickering and they will run all night on a full charge with a cheap 600 mah recharable battery.
This circuit runs at about (it varies up and down) 13 ma and with 1 led the volts across it measure about 2.3, with 2 leds about 2.1 each.
This is way to dim, based on an instrucitble or a comment on one, someone tried adding a second battery in series to boost the voltage. I tried this and it worked great I found the best results before the leds get dimmer then I want is 6. I can add more and the circuit only draws slightly more power, but the leds get dimmer then I want, I have tried up to 17, but really 6-8 is best. Below is a chart of the approximate ma and volts (measured across each led) that is draw for different number of LEDs (all color changing or white rate 3.4-3.6 volts and 20 ma).
1 LED = 60 ma / 3.6-5 volts (varies up and down)
2 LED = 98 / 3.3 - 4.4
3 LED = 103 / 3.1 - 3.6
4 LED = 106/ 3 -3.3
5 LED = 108 / 2.9 - 3.2
6 LED = 112 / 2.7 -3.1
10 LED = 120 / 2.7 - 2.9
17 LED = 122 / 2.4 - 2.6
This was all tested on fully charged batteries and the batteries dies the voltage drops.
Problem:
This seems to drain my batteries MUCH faster than it should. With a 6 LED array it should consume about 340 ma per hour, so if I wanted it to last 10 hours that would be 3400 ma. (I have other solar panels that I plan to swap out to provide enough power). I thought that two 3000 ma batteries would last at least 7 hours even taking into account i can only use the first 80% before the voltage drops too low. However my lights dies after only a few hours!
I read your comment on one of BrownDog's instrutables about no name rechargeable batteries and figured that that may be the problem. So I added two more 3000 ma batteries in parallel, for a total of 2.4 volt 6,000 ma battery pack. This lasts on full for brightness for 5 hours and then gets dimmer over the next 3 hours until it dies. I really want my lights to last at least 10 hours, this is 3400 ma. If only 50% of my battery is good and I can only really use 80% of that, does it mean I REALLY only have 2400? How do you test the batteries to see how much they really hold? I have tested with my millimeter after I have charged them and I get about 1.4 unloaded so I assumed they were fully charged to 3000 ma.
What I would love to know is how you are able to light 10 led off two1.2 volt batteries in series with 2000 ma all night?
By doubling the input voltage am I reducing the efficiency of the circuit?
I have attached pictures of my set up, circuit and a close up of the IC. Would you recommend changing the inductor to up the current, as add my batteries only in series to give longer life and not extra voltage (also more solar panels)? What do you think would be more efficient?
Jul 12, 2011. 11:07 PMshanakoenig says:
Thanks for the info! I am actually using color changing lights, mostly at least with a few white LEDs thrown in, so I probably need to since with the circuit as is. I have actually run it for the equivalent of several days and all the circuits seem good on 2 batteries, I tired with 3 at one time and quickly fried a circuit so that is the limit.
Based on what you said I need to leave the circuit as is. If I don't remove my capaciotr and diode, but change my inductor to 33uh or 20uh instead or the 47uh that is currently in there will I still be able to up the current? If so and my IC can handle it that would be a great way to get a few more LEDs at full brightness.
**Small note on my battery use, I am trying to power between 10-20 LEDs in a single array at full brightness to light up some fiber optics. This would last for days for a normal light, but these are huge sculptures several feet across. i am stressing the filaments and I need very bright light for it to leaks from all the stress points the way I want. I have tested this with a single high brightness 3.4 volt 20 LED that is powered by a 4.5v battery pack and it looks amazing. I want to get my solar powered lights up to that level and have them last all night. :)
Jul 16, 2011. 5:19 PMshanakoenig says:
Well it didn't work, it no longer turns off in the light. I am pretty sure since I doubled my battery voltage the amount of power coming from the solar cells in no longer greater than what is coming from the batteries so it doesn't switch the circuit inside the IC.
*****Have you tried your circuit with 2 batteries? *****
I have tried changing my inductor on my circuit but I assume it barely makes a difference since the capacitor(which I need for my color changing LEDs) is limiting the final output voltage. Right now there is a ceramic disc capacitor with 104 on it, based on similar images I have found on the web I assume this is .1uF 50VDC cap.
Currently my unmodified circuit uses a 47 uf inductor, a mystery IC circuit, a IN5819 Diode and a .1 uF capacitor. With that 1 battery and 1 color changing LED the circuit draws about 13 ma from the battery and about 3.5 ma and 2.8 to 5 volts to the LED.
*****Where did you get your induction to amps chart? Is this from your own tests? *****
My amp output based on induction input is very different from yours. What is the best way to test? Trial or is there a formula I can use? Based on your info I think a 22 uF inductor could double my amps. Then should I double my capacitor size to .2uF. If I get a much bigger capacitor like .5 uF would this still work and just give me more headroom to go a 10 uF inductor? Would this decrease the circuit effiency?
Thanks in advance for all your help! I am really new electronics and circuits, I have 10 + awesome sculptures I am trying to get lit right and every time I think I finally got things working I hit one more road block. :(
Jul 17, 2011. 8:06 PMshanakoenig says:
The IC is okay. It still works when I change back to a single battery.
Part of my problem with my IC is it only turns off once the I get at least .45 volts from my solar panel. This works fine with the solar panel that is included with the garden light. As soon as even a tiny amount of light hits it it produces at least this. I want to replace it with CIS solar panels rated at 5 volts open circuit and 100 ma short circuit. These are great in full sun, but inside with a light on they only produce about .1 ma in the circuit, not enough to turn off the light.
Do you know how many volts your circuit needs to shut off? I have contacted the supplier and I think I will order those, it seems the simplest way. Then I can change the inductor to my ma requirements, and add a diode and capacitor to the end for my color changing LEDs.
I would also love the link for some of the LED controllers you mentioned, more options are always better :)
Jul 12, 2011. 3:30 AMshanakoenig says:
Who manufacturers the IC you are using? I have emailed the vendor but if I don't here back do you know where else I can get them from? What exactly do they do?
Also if I use a 100 uf inductor will that make my lights about twice as bright but use my batteries about twice as fast?
Sorry for the basic questions I am really new to this. Thanks in advance :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:rcisneros
