Introduction: Mini LED Flashlight
Picture of Mini LED Flashlight
This project was created for YuKonstruct's first Build Night.
YuKonstruct is the first makerspace in Canada's north. Our mission is to provide access to shared space, quality tools, available expertise, and a collaborative environment to help makers build anything!
This little flashlight that you can keep on your keychain was created in collaboration with licheness
Step 1: Gather Your Materials
Picture of Gather Your Materials
You'll need:
  • LED
  • coin battery
  • small button
  • hot glue gun and glue sticks
  • needle and thread
  • scissors
  • small pliers
  • felt or duffle fabric
  • key ring
  • coin larger than your battery and pen to trace circles (optional)
Step 2: Cut the Felt
Picture of Cut the Felt
Cut out three felt circles about the size of a loonie (a Canadian $1 coin slightly larger than the battery).
In the middle of one circle, cut a 1/4" hole.
Step 3: Add the LED and Battery
Picture of Add the LED and Battery
Using small pliers, carefully bend the end of each LED lead (the metal ends) to make a half curl.
Place the battery on the felt circle (with the hole) sandwiching the battery and felt between the LED leads.
Place one lead on top of the felt and across the middle of the hole. The other lead lies directly on the battery. Keep positive-to-positive and negative-to-negative (longer lead is positive, look for + sign on battery). To confirm the polarity, test LED by pushing down on the felt side lead until it touches battery (the light should come on).
Using a glue gun, tack the LED lead (on the battery side) in place with a little bit of glue. The lead should lie across the middle of the battery and the glue should be closer to the curl end of the lead (away from the middle) so that it does not interfere with the switch.
Step 4: Sew It Together
Picture of Sew It Together
Sew the button in the middle of the second felt circle.
Make a sandwich: button felt circle on top; felt circle with hole, battery side down (lead runs directly across the middle of the hole with the LED bulb sticking out one side); remaining felt circle goes on the bottom. Push down on the button to test your positioning and adjust if needed.
Sew your sandwich together using a blanket stitch, working your way around the edge and sewing through all three pieces of felt while keeping the pieces aligned. Tie off.
Step 5: Add Key Ring
Picture of Add Key Ring
If you are adding a key ring, attach it to the side opposite the LED bulb, looping your thread back and forth through the ring and back through the edge of the felt 5 or 6 times keeping your threads close together. Tie off.
Ta-da, you are done! Turn on the flashlight by pressing down on the button.
itsruthanitha (author)2016-03-24
wow... Thanks for sharing the Informative Tutorial.The perfect selection for a smorgasbord of outdoor camping, Will be able to reverse the lightness’s of light into strobe, degraded and high. From high all the mode to SOS flashing, dimmer switch lets you take just the right amount of light. High mode when you need powerful low and light style to maintain battery quality. http://patriotdeal.com/products/powerful-mini-flashlight Use this code "PD10"and save 10%.
Ismegordo (author)2014-11-04
WOW what a great little project, I think I will make this one with my Grandson over the next weekend or so. Thanks for the Clear instructions.
jmateos (author)2014-11-03
gracias por compartirlo!!!
akshaylals (author)2014-08-20
Be carefull. How did your left hand finger got hurt?or u simply stick it on ur hand
nodcah (author)2014-08-19
Very clever using the felt as a spring! It also looks fantastic! =)
samalert (author)2014-08-19
Those are so cute ! When i was small i used to have a similar keychain all covered in yellow rubber. I used to love that a lot, it reminded me of the same old days.
seamster (author)2014-08-19
Nice and simple! Great project for beginners to get their feet wet with LEDs. Thanks for sharing this!
thebear1 (author)2014-08-19
neat thanks for posting
About This Instructable
12,379views
175favorites
License:
Bio: YuKonstruct is a non-profit society which provides an enthusiastic community of makers and entrepreneurs affordable access to space, equipment and knowledge. This community serves to ... More »
More by YuKonstruct:Creative Reuse ProjectsYuKonstruct's Favourite FixesCosplay Repair Station
Add instructable to:
