I used information from http://www.olimex.com/dev/images/PIC/PIC-USB-4550-sch.gif and Ian's excellent instructible http://www.instructables.com/id/Business-Card-PIC-Programmer/ to complete this project.
Remove these ads by
Signing UpStep 1Parts and Tools
(1) DB9 Female Serial port connector w/ at least a 5 wire cable attached (Connector was $4.50)
(1) Cable with 5 wires and a connector to connect to PIC circuit (I used an old mouse cable)
(1) 1.5K Ohm Resistor ($0.14 ea)
(1) 10K Ohm Resistor ($0.14 ea)
(4) 1N4148 Diodes ($0.18 ea)
(1) 8.2V Zener Diode ($0.32 ea)
(1) 5.1V Zener Diode ($0.27ea)
(2) BC547 Transistors ($0.41 ea)
(1) 22uF Tantalum Capacitor ($0.32 ea)
(1) 100uF Electrolytic Capacitor ($0.27 ea)
(1) Small Prototype Board ($1.99 ea)
(1) Small Mint Tin (Had one laying around)
Some small guage wire for connections
Tools required:
- Soldering Iron and Solder
- Wire Strippers
- Multimeter (for checking connections)
i ahve checked all the hardware. it found ok.plz reply its urgent
Checking connection of JDM Programmer ...
Error opening LPT driver!
No Programmer found! Check connection!
No PIC detected!
WHO CAN HELP ME?
thanks
give me a schematic for 18f248 programmer
1. MCLR Pin is pin 1 on the 248
2. VDD Pin(s) is pin 20 on the 248
3. VSS Pin(s) is pin 8 and 19 on the 248
4. PGC Clock Pin is pin 27 on the 248
5. PGD Data Pin is pin 28 on the 248
The schematic will me the same for the programmer, just connect it to the pic as described above.
http://www.instructables.com/id/LED-Wheel-Effect-Without-a-Microcontroller-/
L77SDE09S-ND
RadioShack:
Model: 276-1538
The housing is usually sold separately. Or you can chop a serial cable in half and use it. Let me know if you have any other questions.
