Mold Making with Jello
Have you ever wanted to make a mold and cast something -- but were discouraged by the cost of casting supplies? Have you ever just wanted to make one duplicate -- rather and one thousand? Perhaps you only wanted to make one or two chocolate book marks or plaster casts of an ink jet cartridge...
Well, here's a very DIY, cheap an recyclable method to make molds for relatively low temperature casting.
Step 1Materials
Materials
You will absolutely need:
Gelatin -- I'm using Jello
Water
A vessel to pour in that will hold your positive item
Mixing container
Mixing Stick
A refrigerator with space for your vessel
You may need:
Skewers or other support device
Hot Glue
Tape
You probably want:
Chap Stick or Vaseline (chap stick being "edible")
52 comments
1-40 of 52next »
Sep 18, 2011. 2:02 PMlizz1155 says:
Have you ever tried doing this with agar-agar instead of gelatin? (Agar's kind of the veggie substitute for gelatine, but it melts at 85 degrees C and solidifies between 32-40 degrees C, which could be more convenient than gelatin). I'm trying to work out whether this might be suitable for life-casting a hand?
Jul 27, 2011. 1:18 PMdubit1 says:
could i cast a hand or fot in this
Jun 18, 2010. 4:37 PManarchy burger says:
this works wonderfully on fairly small or light objects. unfortunately, this time, i needed to make a cast for heavy stuff. after several disasters trying various ways to cast my husband's tools (hammer, wrenches, screwdriver)--they are a little heavy for most suggestions,( and he'd get ticked if they had jello, silicone, etc on them,) my daughter &i had an epiphany. salt dough. 2pts flour, 1 pt. salt, 1 pt. water. kneaded it until it felt like clay. we used 1/2 the salt dough on the bottom of a lg. cookie sheet, put cheap plastic wrap on it, lightly pressed in his hammer, wrenches, & srcewdriver, put more plastic wrap on top, and the other 1/2 of the salt dough on top of that, pressed it down pretty firmly, and froze it for about an hour. after we removed the tools (by tugging the plastic wrap) we had 2 half molds. the chocolate also set up very quickly. so, the hubby gets life size peanut butter cup tools on father's day.
Sep 3, 2009. 4:16 AMjujibelly says:
To be honest I only clicked this instructable because I thought the picture was the brain bug from Starship Troopers...cool none the less.
Jul 11, 2009. 4:30 PMcontrolledwrinkles says:
This is for larger scale molds, but it's really cheap. You take a bucket of soapy water, the soap keeps the silicon from sticking to you, and then you squeeze an entire tube of "GE silicon sealant" into it (apparently you have to use the stuff that stinks, it won't work with the unscented kind), you then pat at it gently till it sort of balls up in your hands, if you press hard it will stick to you and it's a bear to remove, but you can handle it very gently till it starts to cure and then you will be able to remove it from the soapy water as a ball and mold it around whatever you were planning to make a casting of. In 12 hours you can cut it from your item and viola! You now have a clear silicon mold that will last for 5 years and that cost under $10 to do. Apparently it's really good at showing details as well.
Jan 18, 2009. 10:15 AMshortone says:
HELP! I really want to cast my hands/arms in plaster for an art project but I can't figure out anything that might work...the jello molds seem close enough but I don't know how I could get my hands out after the jello set without damaging the arm part of my mold. Also, I don't want to have to order any weird mold-making stuff.....i live in a tiny town so jello is about the only thing i could come by... some advice please??
Apr 9, 2009. 6:19 AMgluneau says:
mold each hand in a long thin container like a juice pitcher. When it is set, pull the whole jello thingy out of the juice container and carefully cut it in half. Then carefully put the two pieces back in the juice container. And voila, you'll have your arm/hand mold. You'll obviously need an assistant for this.
Apr 11, 2009. 4:37 PMshortone says:
yeah that's what I've found as well. luckily I've managed to find a different mold-making material :D
Feb 19, 2009. 9:30 PMshortone says:
I actually ended up just dipping my hands into melted (but not insanely hot) wax and then filling the wax molds with plaster, which worked really well! alginate does sound like fun though...as soon as I get more money (haha...not anytime soon) It would be fun to try out. :D thanks!
Jul 12, 2008. 11:04 PMspecopps117 says:
will that survive the temps of melted aluminum?
Apr 11, 2009. 2:56 PMthepelton says:
That's something like 1220 degree F, if I recall. 660 C.
Jul 13, 2008. 10:35 AMspecopps117 says:
intermediate material?positive mold? sorry Im kind of new to casting also wouldnt the aluminum just thaw the mold?...then burn through it getting all over my back "patio" or are you saying it would make a chemical reaction making the mold stronger?
Jul 13, 2008. 10:14 PMspecopps117 says:
wouldn't wax melt how a bout "quick crete" thats more accessible in my area
Jul 14, 2008. 5:51 AMspecopps117 says:
ok thank you
Jan 29, 2009. 10:30 PMdiy high speed photography says:
Very nice setups. I want to make a lens prototype using this. I need colourless jello.....how can u help me.
Feb 18, 2009. 4:31 PMa7xforlife says:
Use plain knox gelatine. It's clear.
Feb 18, 2009. 5:30 PMFoamCrazy says:
knox gelatin isn't clear its yellow
Dec 16, 2008. 7:40 AMheathbar64 says:
Forgot to mention earlier, I remember in an old magazine, instructions to make gel lenses like for 3d glasses out of gelatin, with way less water. From that I guess you could reduce the amount of water in your jello quite a bit and get some really rubbery molds
Dec 16, 2008. 7:37 AMheathbar64 says:
hey cool, I was just reading my copy of thurstun james prop builders molding and casting or whatever the book is. I found proper moulage is quite expensive, so the Idea popped into my head, "why not use gelatin to make a mold?" and what do you know?, good old instructables has the info. Btw, no that book doesn't tell how to make your own moulage. I've read it several times. But it does have a lot of other cool idea's well worth the read.
Nov 17, 2008. 3:20 PMpatmac says:
could I make a jello mold and pour jello into it? In other words, I want to make something out of jello but I don't know if it will stick to the jello mold.
Jun 15, 2008. 4:55 PMmaxeen says:
I am going to mold a ballistic gel object in it and make it a airsoft tartget
Jun 15, 2007. 6:30 AMdrcrash says:
You can use gelatin to make a better molding compound called "moulage," which is a rubbery solid that you can melt in a double boiler, apply warm, and let it cool to make a mold. The best part is that moulage is reusable many, many times. It used to be popular for lifecasting, before alginates. (You heat it up to 115 F, let it cool almost to skin temperature, and apply it.) I think there's a recipe for making your own moulage in Thurston Jame's classic book, "The Prop Builder's Molding and Casting Handbook." Check it out. (Great book, covering molding and casting in 30+ materials. You can find it at www.build-stuff.com, or likely at your library.) I recently found out that some urethanes can be cast in damp molds like alginate molds. I'm guessing they'd work in moulage molds, too.
Apr 18, 2008. 12:37 PMatomiclizard says:
Do you have any instructions for moulage-making or know of any free websites with the info?
Jun 15, 2007. 6:32 AMdrcrash says:
Oops, typo, sorry. The author's name is Thurston James. I think moulage-making would make a great instructable.
Feb 26, 2008. 8:01 PMravebot says:
chicken poop?
Nov 8, 2007. 7:16 AMstasterisk says:
Crisco makes REALLY GOOD mold release. Just smear that stuff on. I made a bunch of white chocolate oranges this morning.
Sep 30, 2007. 7:16 AMdrcrash says:
I just came across a couple of books with interesting information on making gelatin molds and agar moulage molds. Turns out gelatin is better than I thought, and used to be common for low-volume casting (up to a few dozen things, I think.) Very interestingly, it IS reusable---you can melt it down and use it to make another mold 5 to 15 times. Cool. (It's not as reusable as agar moulage, which you can use 50 to 100 times.) To make a gelatin mold more durable, you can swab the surface with a solution of alum and water. That will make it tougher and more heat resistant. (1/4 pound powdered alum to 1 pint hot water). You can then apply a mold release that's just stearic acid in kerosene. (melt 1/4 pound stearic acid and mix it with 1 pint kerosene.) To make the molds last a lot longer, you can use mostly glycerin or propylene glycol rather than water when cooking up the gelatin. It will dry much, much more slowly and you can get a bunch of casts out of it over several days. For details, check out "How to Make Professional Molds and Castings, from Plaster to Plastics" by Ralph Travers. (If your library doesn't have it, they can get it by interlibrary loan; that's what I did.) For agar moulage recipes and instructions, check out "The Materials and Methods of Sculpture by Jack C. Rich. I did some research, and the best place to get agar agar powder is usually from a local asian grocery store. Most of them sell "Telephone" brand agar agar in .85 oz. packets, and it's good stuff. The big advantage of agar agar is for lifecasting. It has a low melting point and an even lower re-solidifying point. (It has "hysteresis," meaning it doesn't like to change state, so you can let it cool well below its melting point before it will go ahead and re-solidify. For life casting, that means you can let it cool almost to body temperature before putting it on somebody. For non-lifecasting, gelatin is likely better. I think it's tougher, and easier to apply, and its higher melting point means that you can cast things in it that get pretty warm when they set. (But not really hot.)
Jun 5, 2007. 5:31 PMTool Using Animal says:
Yo! T! Check it out, worked perfectly.
Aug 26, 2007. 5:55 PMthreecheersfornick says:
What did you make the second dog out of?
Aug 26, 2007. 6:12 PMTool Using Animal says:
It's plaster, because of the need to keep the gelatin firm I let it harden over night in the fridge.
Jun 5, 2007. 6:08 PMTool Using Animal says:
Surprisingly well when I unmolded the original, just slight tearing. The cast I cut free, the plaster was very soft from curing in the fridge overnight..
Aug 16, 2007. 9:20 AMcapt-capsaicin says:
Has anyone seen an instructable for casting with silicone? I have seen many instructables for making silicone molds but I want to make silicone parts.
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
313
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
