PYRO DETONATOR 2 igniter detonator fireworks pyrotechnics
Device which can detonate or ignite just about anything you want it to. Made for safe ignition of fireworks but with some skills you can make this fine case and put anything you want on the end of it.
Heres the link to the PYRO DETONATOR 1: http://www.instructables.com/id/Detonator-box-Ignition-box-Fireworks-Pyro-box/
Step 1Getting started
Getting started
So firstly these are the things you will need.
A hobby case, I used the one you see in the picture
A toggle switch with red cover
7.2 volt rechargable battery with plugs on the end (rc car)
Push switch (red)
Key switch (with keys)
Jack plug (not quite shore which one it is, you see it in the picture)
Jack plug socket with lock
pull ties (tiewraps)
Led with fitting
Drill
Isolation tape
Sticker maching
wire
30 meters of wire(more or less)
173 comments
1-40 of 173next »
Sep 4, 2011. 5:50 PMskrubybubl says:
Im not sure which one is the jack, and if anyone can
Please send a link where you can buy it
Thanks
Sep 4, 2011. 6:01 AMskrubybubl says:
Also, What type of jack socket do you use?
Anyone answer please
Sep 4, 2011. 6:00 AMskrubybubl says:
You could use a potato cannon, but remember that they are felonies in California, florida and several more
Sep 4, 2011. 5:54 AMskrubybubl says:
Wait... What type of jack socket do you use?
Aug 29, 2011. 4:27 AMchry_cool says:
Very smart Piece of kit !
Sep 22, 2009. 3:57 PMFlashmaster says:
What is there to blow up? Wat can you use as an ignitable substance?
Jun 29, 2011. 9:37 PMMR.BOOM9897 says:
I was thinking on maybe testing it on firecrackers. just a thought
Nov 6, 2009. 10:10 AMDoomLaki says:
the suger, the KNO3, provides the oxigen to make the energie containing suger ignite.
Oct 23, 2009. 4:48 AMowwio says:
50% pottasium nitrate 50% molten sugar - let it go hard and lite it :P
make lots of smoke (but stand back, explodes 1st)
Oct 29, 2010. 10:07 AMMasterMind555 says:
Where the hell did you got the ''arm'' switch? Do they sell it in an electric store? Cause I would like to do it and like that my mother won't be able to say that I'm too near of my ''bomb'' lol
Mar 4, 2011. 12:02 AMsjoobbani says:
radio shack, but they're $5 online they're cheaper, most electrical stores have them>
Oct 7, 2008. 5:03 PMPyromanX says:
PLEASE help with the case!!! Cannot find!!!
Jan 27, 2011. 1:06 PMjvifun says:
go to any hardware store
Oct 30, 2010. 7:35 AMMasterMind555 says:
If you really can't find one ( Like an old used case of something ) I guess you can build one with wood. Anyway for me the case is the last of my problems lol
Jan 27, 2011. 1:04 PMjvifun says:
hi i was wondering i found a website where thej sell the batteries
they have a difference in mAh i dont know how much i need
nice guide
greetings joel
Jul 17, 2010. 3:36 PMchemist71186 says:
Ok quick question. Considering the modern day understanding that electricity (flow of electrons) comes out of the negative (black) side of the battery and goes through the load (in this case the switches and buttons etc) and returns back to the battery at the positive side of battery, here is my question....... Looking at the wiring schematic, if the electricity is coming out of the negative (black) side of the battery, then it appears that the first thing the electricity goes to in the circuit if the phone jack which has wires leading to the explosive. So, why is it that when you wire it like this, that the electricity can only flow to the explosive if you flip the switch and hit the momentary push button? Because, in my mind according to this schematic, if the only way to complete the circuit would be to turn the key on, flip the switch, and press the monentary button, then wouldn't the electricity HAVE to be coming out of the positive (red) side of the battery? If this question seemed confusing, someone just please explain to me EXACTLY where the electricity from this battery is entering the wires and EXACTLY where it is coming out of the wires and entering back into the battery. Thanks
Jul 30, 2010. 10:59 AMskicero says:
Electricity only flows when there is a path for it to flow. And it flows pretty much instantaneously so, for all practical purposes, the direction of the flow does not matter. The electricity doesn't go right to the explosive jack because the circuit isn't complete, and thus there is no path for it to flow. You should read up a bit on Electronics theory. :)
Jul 30, 2010. 1:15 PMchemist71186 says:
No, I understand that. What I am saying is I would think that the current must be flowing in the direction that the key must be turned first, then the flip switch must be pressed, then the mom push button must be pressed for this thing to blow something up, right? The reason I say that is because if the current is "everywhere" at all times the circuit is closed, then this ignitor would blow something up without the key on or the flip switch flipped on right?
Sep 2, 2010. 12:44 PMrrrmanion says:
no electrons can flow till they key is turned- the battery only has 1 terminal connected otherwise. then electricity will flow through the wire with the green led as there is another full circuit. next the arm switch must be pressed so electricity can flow through the green led still then as far as the fire switch. when that is pressed, the electricity flows through all parts of the circuit. and then... BOOM!!!
Jul 29, 2010. 5:57 AMchemist711 says:
HHHEEEELLLPPPP, can anyone answer my last post?
Jul 29, 2010. 5:58 AMchemist711 says:
HHHHEEELLLLLPPPP, Can anyone answer my post below please?
Jul 22, 2010. 9:03 AMthemandon says:
where can u go to get all the suppys?
Jul 10, 2010. 9:02 PMguitarcreator says:
ive been trying to hook up more LED lights to the whole system so that there's one for every switch. i cant seem to get it right though. i can rig it up so that the lights come on whenever i have the toggle switch turned on and when the power switch is on but if i wire it up to the momentary switch button i need to have the button pushed down for the lights to come on. can someone please help me with finding a way to wire it up without changing the momentary switch? thanks.
Mar 11, 2010. 7:07 AMnerd12 says:
you should have done it the other way. the arm switch should not be covered and the fire switch is supposed to be covered.
Jun 29, 2010. 11:12 AMbowmaster says:
I agree, it makes it both safer, and more BA.
Apr 15, 2010. 8:22 AMPurple Guy says:
 Thats what I was thinking too :P
*Purple Guy*
Jun 6, 2010. 11:26 AMtimhannah1988 says:
What LED did you use as surely it will blow under that volts etc
Jan 5, 2010. 12:30 PMprogramedfiles says:
i think it would be nice if you added a led so when you "arm" the device the led is turned on
Oct 7, 2009. 3:06 PMowwio says:
 How do i connect the jack socket?
It is audio not power.
And my key switch has 4 terminals. Y?
please help.
Oct 23, 2009. 4:47 AMowwio says:
nvm sorted :P
Jun 17, 2009. 3:12 PMDurkaDurkaDie says:
Yeah i have a question im new here and i was wondering do i have to incorporate the key switch?
Dec 26, 2011. 2:23 PMowwio says:
if you wish, you can use just 1 switch. The 3 is for both safety and effect. With 1 switch, it is much easier to fire by accident.
Aug 22, 2009. 6:38 PMArirox says:
That Was Dumb Of Me I Need The Detinator Part To ignite it Any one no how to make it?????
Aug 10, 2009. 2:55 PMPatented says:
do you really need a battery that big? 9 volt square battery would be alright no?
Jul 18, 2009. 5:26 PMmr_goodbytes says:
Jul 16, 2009. 7:13 PMike4life says:
What gauge wire do I need to use for this project? Also where can I get the actual electronic igniters to go on the end of the wire?
Jun 25, 2009. 6:46 AMjwilkes2007 says:
Sorry to bug you again I hate not being able to edit my comments as to not create more post just for one question. I was gonna use wires with alligator clips. People have been talking about steel wool Do you gotta use it? or can you just use alagator clips and attach the positive and negative to the firework? I get the whole connect with the audio wire being cut at the end so the wires are showing the positive and negative. less mess cause it is 1 plug a thick black wire and comes out as two nice. But Whats the best way to hook it up thanks for the hell.
Jun 17, 2009. 3:13 PMDurkaDurkaDie says:
How did you get the momentary swithch with the red cover? please reply
Jun 22, 2009. 6:53 PMinstructors says:
You can get Something Similar at your Local Radio Shack.
Jun 17, 2009. 12:14 PMsaber66 says:
you would need to buy e matches (electronic matches) to shoot of rocket fuel, fireworks, ect. if you have ever shoot off a hobby rocket with the eletronic detonators, you need the little thing to but into the rocket fuel, and it looks like an l.e.d with the two prong that you attche the alligator clips to, well these are e matches, you can but them at skylighter.com, one of the best websites to buy pyrotechnics supplies.
1-40 of 173next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:larsjet
I would really like a lot of tips for my projects Thanks LARS
