Repair a Broken Ethernet Plug
 by laxap
Featured
The locking tab of RJ45 plugs breaks very easily. Replace it by two nylon cable ties (aka zip ties), in minutes.
IMPORTANT NOTES:
- This must be regarded as a temporary "Mac Gyver" solution, for home usage.
- Definitely not for IT staff! (no crimper? asking for one in the budget won't get you fired!)
- Before the tab breaks, consider protecting the plug.
Step 1: On Broken RJ45 Locking Tabs...
There are always some Ethernet cables around with a broken tab. Did you remember to exchange the cable?
Now the RJ45 plug no longer locks properly, making the connection unreliable. You firmly push the plug into the socket, hurray you're connected again! so you forget about the plug until the next lost connection some weeks later, wasting a long time to figure out that it's this damn broken plug again. And so on.
Now it's time to act and grab your RJ45 crimp tool. Oh, you don't have one? Or you're reluctant to use it? so read on...
Step 5: Make its Head Thin
With the sharp knife, and preferably on a piece of scrap material, cut the head of the cable tie, to make it flat.
1-40 of 216Next »
Doncans says: Jun 13, 2013. 7:48 AM
ingeniosamente simple y espectacularmente útil
felicitaciones
ljuwana says: May 17, 2013. 7:30 AM
nice trick...so simple
x burn says: Apr 23, 2013. 6:04 PM
really brilliant
Fat Aido says: Mar 14, 2013. 3:16 PM
I am in love with you man! xxx
softenersreviews says: Mar 2, 2013. 3:48 AM
Great job on the ties!
dmesser says: Jun 6, 2012. 9:01 AM
This might be fine s a temporary fix. But seriously, just crimp on a new end. They're as cheap as cheap as pull-ties, and you won't have to fiddle with getting the cuts just right. Any home improvement store carries the crimper and ends.
roseuz says: May 27, 2012. 12:21 AM
Ah!!!!!!!!!! What a waste of time and disappointment. I wish I could be as positive as the others, but sorry, that's just not the case. I tried this, which took probably at least an hour with the cutting the head of the tie being the longest. It cracked to the top, but I managed to change the direction of the cut to get it even and finish the job. I also super-glued it and wiped off any excess. It eventually cracked again though.
Once I finally reached the last step, I am able to put it into my Ethernet port, but sometimes must fidget with it to get it pushed in all the way so that when I tug on it I can feel resistance. The second thing that bothered me the most is that it's too difficult to get out and I usually have to pull out my Ethernet cord as I have a non wireless printer that's not in my room and this would frustrate me every time I have to take the cord out.
I guess the easiest and fastest solution, would be to buy a coupler as someone else suggested and a one foot cord and tape the damaged end of the cord into the coupler.
mmcpherson4 says: Jan 28, 2010. 3:30 AM
MUAHAHAH!!! NEVER will I EVER be disconnected from Xbox Live because of that cursed cable!!! :D Thanks a bunch dude!
hunter999 in reply to mmcpherson4Jan 24, 2012. 9:34 AM
same here dude - no getting booted from cod or gears!
socalsmiley in reply to mmcpherson4Dec 30, 2011. 6:03 PM
haha same exact reason im doing this!
Lawrence.Frewin says: Jan 24, 2012. 3:31 AM
An excellent fix for an all too common problem. Saved me hours of laying new cables or renewing connectors. A simple and annoyingly obvious fix once you have seen it done once.
eddles777 says: Jan 5, 2012. 4:13 PM
thanks mate for showing this. i applied to to my own cat-5 cable and also used the same application modified for my old telephone wire cable.
pratyushpmhptr says: Jul 15, 2011. 5:39 AM
(removed by author or community request)
muckquomp in reply to pratyushpmhptrNov 27, 2011. 11:11 AM
The Home Depot electrical department has them. Various sizes. Try the hardware department as well depending on store.
RCGuru in reply to pratyushpmhptrAug 30, 2011. 5:47 PM
Poundland in Uk and dollar world in other places
prodo123 says: Jul 11, 2011. 12:15 PM
I can't cut the friggin nylon tie with an extremely sharp razor. Now what, sand it flat?
laxap (author) in reply to prodo123Jul 11, 2011. 12:49 PM
Because the nylon is quite hard, a sharp and sturdy blade+handle is necessary. Use a utility knife (stanley, or snap-off).
Side cutting pliers may also be used.
prodo123 in reply to laxapJul 29, 2011. 6:46 PM
I used a Stanley utility knife and it still won't cut...
Then I used wire cutters and it completely deformed the end
Then I used needle nose pliers and it did the same thing
Horus9339 in reply to prodo123Aug 22, 2011. 2:58 AM
Sorry but you made me laugh. Have you got a sharp blade installed in the knife? If you use a little backwards and forwards motion and gently push you will make it through the plastic clip. You could use some mineral oil to help with the friction. You have to have some patients, they are tough little pesky things.
If you have a little modelers drill you could use a small sander tip but that would defeat the whole point of this genius repair. Which can be done with little to no tools, I have managed to do this with a set of True Utility Nail Clippers. So keep going and you will succeed.
Good luck.
prodo123 in reply to Horus9339Nov 5, 2011. 9:57 PM
I got a new Ethernet cable, problem solved.
And yes, it was sharpened at that time. In fact, laying my finger over it got me a small cut. So it looks like there's something wrong with my cable ties. Or maybe it's some industrial-grade cable tie? I don't know.
muckquomp in reply to prodo123Nov 27, 2011. 11:08 AM
Oh well . . . got here too late to tell you to try a finger nail clipper. The big ones with a wide flat Jaw for toe nails. This is what I plan to use instead.
throbscottle says: Nov 14, 2011. 3:04 AM
This rocks more than a very rocky thing! Thank you!
I have a cable where the tab broke off from being plugged/unplugged every day, so this will be much better than the original tab because it's almost unbreakable!
lmlei says: Sep 14, 2011. 9:20 PM
Can people that tried this way confirm if its safe for my laptop...? I LOVE the idea i just hope its safe to use haha
Rybka30 in reply to lmleiOct 23, 2011. 6:35 AM
I used it for few months... and then PC engineer said me it can break ethernet card in computer... i dunno how, but he said it can... :/
mmykle in reply to Rybka30Oct 24, 2011. 10:14 AM
It can only break the port if you misjudge the how small to cut the ziptie. If it is too big the cable will get stuck in the port. However in most cases you should be able to get it out by sliding a knife in between the ziptie and the ethernet port.
PaulMakesThings says: Oct 22, 2011. 9:57 PM
Finally gave this a try on my cable that keeps coming loose. For a moment I thought it hadn't worked but then I nudged the ties forward a bit and it clicked and locked. Excellent job on this!
julietaodio says: Sep 22, 2011. 9:20 PM
How clever!!!!!!!! ithis is the most amazing solution for something sooo annoying thank you for reminding me of things like these make the world interesting. I know, a little drama hasn´t killed anybody but it is true 8)
rquader says: Aug 22, 2011. 12:11 PM
Great fix. I'll try this out on my cables!
Electronics Man says: Jul 27, 2011. 3:07 PM
This is awsome! Good Job :)
trustr says: Jul 26, 2011. 12:33 AM
You Sir... are a genius!
weldam says: Jul 25, 2011. 6:57 AM
cool
brssnkl says: Jun 16, 2011. 9:11 AM
replacing it is easier
kkroflin says: May 28, 2011. 5:08 PM
Well done!
qdexheimer says: May 16, 2011. 5:38 AM
Had a RJ-45 network cable with both plugs broken. After some hard time, it works perfectly for both sides. Thanks for this wonderful idea, I'll repair a lot of Ethernet Plugs with that method.
Quentin, from France
stsvolga2 says: May 2, 2011. 6:48 AM
sabladask says: Apr 30, 2011. 12:03 PM
your the best!!
the pvc bike guy says: Apr 29, 2011. 9:47 AM
Thank you!
WildBlueRhino says: Mar 15, 2011. 7:42 AM
Such a useful little trick. A bit fiddly, but it's worked perfectly. :)
zamg0d1 says: Mar 6, 2011. 6:18 AM
Great way to kill your Ethernet cable.... Ingenious but the tie around the cable itself will will the cable due to the tightness of it..
Mooch07 says: Mar 5, 2011. 9:18 AM
Just did this and it works great! Thanks
1-40 of 216Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
