UPDATE: This thing has a very short range. If you build this, you would be lucky to get 150 feet. I have since taken it apart and rebuilt it with a 24 inch barrel.
Cost to make - roughly $15 plus cost of Mad Bull XM PB4 unit.
My cost to make - $3. I had almost everything I needed already.
HOW IT WORKS:
The Mad Bull XM PB4 is a Rerservoir and Valve system for pressurized volatile liquid. For airsoft, this liquid is called Green Gas. When the Valve of the PB4 is triggered (opened) all the liquid flows out of the reservoir into the Chamber behind the Nerf Football. The liquid - being very volatile - QUICKLY vaporizes into a gas state. The volume of the Gas is hundreds of times Larger than the volume of the liquid state. This Rapid Expansion from liquid to gas is what Pushes the Nerf Football out of the launcher. For further explanation, please talk to your local high school science teacher.
UPDATE: I took this launcher apart and built alonger launcher. The new launcher is 24 inches long. It is a compromise between the pistol and the LAW which extends to 30 inches long. It abandoned this design because the range sucked.
Remove these ads by
Signing UpStep 1Tools and Materials
Dremel / Rotary tool with the following attachments
- Cut off wheel
- sanding drum
- shaper / cutters
Drill with assorted drill bit
Screw tap
scroll saw
hack saw
screw driver
Clamp (optional)
Sandpaper
Materials
ABS or PVC Pipe 2" schedule 40
Shielded pipe coupler (see my M72 Law instructable).
Wood
screws
aluminum bar
steel rod
Mad Bull XM PB4 airsoft grenade (also sold by RAP4).
![How to Make an Airsoft/Paintball Landmine [HD Video Tutorial]](http://img.instructables.com/files/deriv/FXB/1QR5/GQ5QCIVI/FXB1QR5GQ5QCIVI.SQUARE.jpg)
I scrapped the design and built one with a 24 inch barrel. The new design is now a shoulder fired launcher with a max range probably a little over 100 YARDS.
Look at the current launchers in the market that use the 40mm grenades(example, Deep Fire M72). They require you to unscrew the back and plopin another grenade with a fresh charge of green gas. Well, if youhave to have multiple grenades at $40 a pop, that gets expensive fast.
Well, you say, "y not just one grenade, and keep refillingit?"
Hmmm, that goes something like this : FIRE > unscrew back >extract 40mm grenade > fill > replace grenade > screwback on > FIRE. Sounds like a lot of steps, right?
My Launcher goes FIRE > refill grenade> FIRE!
which looks faster?
The short answer - No, you do not want to remove the grenade.
gessing
http://www.rap4.com/paintball/os/panzerfaust-grenade-launchers-p-5521.html
It looks very effective. Looks like it runs of an air tank so no refilling per shot, very cool.
