3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Sam Flynn Suit from TRON Legacy
Okay all... so more than a few people have asked for this Instructable.  I hope I am able to explain enough.  Sadly I didn't completely document the whole process, but here it goes!
Step 1Electroluminecent Tech
EL for short, comes in many different forms.  Sheets, strips, tape, ribbon, even flexible fabric (although I didn't discover this version until after my suit was made.)  The version I used was a cuttable form I first saw on a webseries on Revision3 internet TV.  I found it on the site: http://electroluminescence-inc.com/
Attached are some photos.  The checked pattern around the perimeter alternates the connection points (anode + / cathode -) which allows the sheet to be cut so long as two opposite contacts are connected to the sheet.
40 comments
Nov 17, 2011. 12:24 PMJsquared24 says:
Best.Tron.Outfit.Ever.
May 31, 2011. 8:54 PMThe nerdling says:
needs to be skin tight, other wise cool costume
Aug 13, 2011. 5:16 PMRalphNL says:
I agree!
Maybe using a diving/jump suit or thermal cloths would be a great idea instead of a leather jacket
Nov 15, 2011. 2:53 PMcdastmalchi says:
SPANDEX! lol
Aug 25, 2011. 4:26 AMtaz1328 says:
Hey. Nice job on your costume! Quick question...how many sheets of EL paper did you need for it? Just trying to get a rough estimate on the damage to the wallet. Haha.
yeah for about 530 bucks... im working on making a quorra costume. ive never worked with this stuff before. she has less illumination on her suit so how many sheets would you suggest?
Oct 4, 2011. 8:25 PMtebright1 says:
How well did the paint work on the suit?
Nov 15, 2011. 2:51 PMcdastmalchi says:
actually painting leather is fairly easy. it isnt 100% fullproof to all benting but if you wipe down the leather with acetone then paint it, it will not chip nearly as easily
Oct 27, 2011. 6:24 PMmenahunie says:
I used shoe dye instead of paint..
They come in plastic squeeze applicator bottles.
Oct 19, 2011. 11:20 AMschroedc says:
thank you for creating what I started to, but financially could not continue. I was even looking at the same company for the panels. I'm really glad someone completed my shared vision!
PS> I bought a black leather motorcycle suit for my base...
Sep 5, 2011. 12:25 PMllaurencelle says:
Was the entire costume made out of EL tape or EL panels? because I was looking into making a Quorra costume, but I'm not sure how you would bend the tape in order to create the curves and such. I really want to find a way to make the tape work if i can
Oct 5, 2011. 3:08 AMsd2kool4u says:
Amazing Right!?
http://www.ebay.com/itm/EL-Tape-Curve-Tron-Costume-2cm-12cm-Bend-Half-Way-Halloween-/150671860380?pt=Adult_Fancy_Dress_UK&var=&hash=item68c8730831
http://www.ebay.com/itm/4-X-EL-Curve-Tape-Tron-Costume-2cm-12cm-Bend-Half-Way-Haloween-/150671916660?pt=Adult_Fancy_Dress_UK&var=&hash=item68c8733e5f
http://www.ebay.com/itm/EL-Hoop-Bright-Glowing-EL-Tape-Ring-Tron-Disc-Fancy-Dress-Costume-/150671711652?pt=Adult_Fancy_Dress_UK&var=&hash=item68c8729399
Sep 6, 2011. 9:10 AMllaurencelle says:
Do you know what type of tape it is I'd need to be able to cut it?
Oct 5, 2011. 3:10 AMsd2kool4u says:
http://www.aradanicostumes.com/disc_mount?keyword=tron&category_id=0
this is what i use
Sep 27, 2011. 3:40 PMsd2kool4u says:
where did you get your suit
Aug 31, 2011. 8:04 PMdelgeezee says:
too expensive! how many sheets did you use?
Aug 15, 2011. 11:52 AMwclark5 says:
hey Im working on one now and I found the perfect material my surfing wetsuit
Aug 16, 2011. 3:46 PMrwerts says:
Please post more info once you get them. I'm looking into making one for halloween this year.
Jul 15, 2011. 12:50 AMatilladolphun says:
verry nice work
May 29, 2011. 8:35 AMdprasetyo1 says:
awesome costume.
can u tell me ,how to buy el wire sheet like that.
i cant find it in my country....
or maybe you want to sell that.
Jul 12, 2011. 6:12 AMsd2kool4u says:
heeeeeey i finally found http://e-luminates.com/osc3/index.php?cPath=26&osCsid=4831656a4ff37ba1e0796e077cfc856c
May 2, 2011. 2:43 PMswilliamson1 says:
how do you actually connect the wires to the el tape
Apr 26, 2011. 6:00 PMurtlesquirt says:
Love the movie, love the costume.
If I have the time to make it, I might be Clu for Halloween.
Apr 24, 2011. 9:24 PMDigiBentoBox says:
Maybe you could use copper tape to travel all the way down the back of each individual piece (Like the copper wire "fan" they used on the site; http://electroluminescence-inc.com/customPattern2.htm).
This way, if it was the black terminal that ripped and rendered the piece useless, the copper wire/tape would connect the pieces. Not only that, but it would also prevent excessive bending, at the sacrifice of a nominal amount of flexibility.
(That way, your 100s of $$$ spent will last longer than halloween! :D Great tutorial man, and THE BEST suit recreation I've seen. You're mighty creative)
Apr 17, 2011. 8:40 PMFantôme 1S says:
nice suit, but the step 1Electroluminecent Tech could be more detailed ...
Mar 28, 2011. 8:40 PMSupernovaDesigns says:
I am trying to plan out a Tron Legacy costume, but want to have the details in red. I had originally been planning on using the EL tape, but I'm having a tough time finding tutorials on how to create any kind of a shape other than a straight line. As far as I can find, the sheets are only available in blue and pink. Do you think a transparent adhesive vinyl could be placed over the top of the EL sheet to change the color?
Mar 19, 2011. 12:29 PMInfiniteElectricBoogaloo says:
Hi! I have a question on this part of the design, as it stumps me the most right now. You said that you designed the pattern on a computer. What program did you use? Also, where did you get the illustrations above that you drew the pattern on? Thank you! :)
Feb 28, 2011. 1:01 PMarchangl says:
You said that you can get flexible fabric EL, I've only known about the sheets and tape too, where can you get the flexible fabric?
Mar 1, 2011. 12:52 PMHeWantsRevenge says:
nice job though showing some pictures of the actual construction of the el wire wouldve been perfect.
Feb 28, 2011. 12:59 PMmu0p says:
Amazing! Thnx so much for posting this!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:Tifetup
