The sensors are made from stretch conductive fabric and piezoresistive Eeonyx fabric. The glove is connected to the Arduino via metal snaps and a fabric cable made from sewn conductive thread traces.
HOW THE SENSOR WORK
The piezoresistive effect describes the changing electrical resistance of a material under mechanical pressure. Eeonyx coats a range of anti-static woven and non-woven fabrics in an inherently conductive polymer, giving them piezoresistive properties. By adhering two traces of stretch conductive fabric parallel to one another across the fingertip and then attaching a piece of piezoresistive stretch fabric on top of these, one is able to measure the change is resistance between the two conductive traces when pressure is applied through the piezoresistive material.
Sensitive Fingertips is a collaboration between Dr. Umida Avloni, director of the Avloni Academy of Music, Dr. Jamshid Avloni from Eeonyx and Mika Satomi and Hannah Perner-Wilson from KOBAKANT. This is the first working prototype, things to be improved include:
- Integrating the sensors better around the shape of the fingertip, possibly knitting the glove and including conductive and resistive yarns to do so in a three layer knit
- Making sure the sensor reacts well not only to holding down pressure, but to the tapping of piano keys
- Making sure all this works on the scale of a child's hand
- Improve the software and visualization side
http://www.kobakant.at/DIY
Videos
Remove these ads by
Signing UpStep 1Materials and Tools
- Eeonyx SL-PA coated piezoresistive stretch fabric (RL-5-129) from http://www.eeonyx.com
- Stretch Conductive Fabric from www.lessemf.com/fabric.html
- 117/17 2 ply conductive thread from www.lessemf.com/fabric.html
- Fusible interfacing from local fabric store or www.shoppellon.com
- Aleene's Flexible Stretchable Fabric Glue from http://www.amazon.com/Aleenes-Flexible-Stretchable-Fabric-Glue/dp/B0001DSCQ0
- Metal poppers (snaps)
- Jersey stretch fabric
- Non-stretch fabric
- Regular thread
- 5 x 4.7uF capacitors
- 5 x 50K ohm resistors
- Solderable Perfboard with copper line pattern from All Electronics http://www.allelectronics.com/
- Male and female headers from Sparkfun http://www.sparkfun.com/
- Arduino USB board from Sparkfun http://www.sparkfun.com/
- Computer running the following software:
- Arduino software free for download from http://www.arduino.cc/
- Processing software free for download from http://processing.org/
- Sewing needle
- Sewing machine
- Scissors
- Pen and paper
- Iron
- Cutter knife
- Pliers
- Soldering iron
How accurate do those resistors need to be?
I just want to say I'm a big fan of your work and your Instructables have helped me get a start in integrating soft circuits into my projects.
I was wondering if you could explain how you attached the Eeonyx fabric to the finger tips to complete the sensors. Here's a few questions in particular...
Is that conductive thread in the picture?
Did you use fusible interfacing to make the conductive fabric strips underneath adhere to the Eeonyx fabric?
Thanks and keep up the great work!
Gundanium
i did use fusible interfacing to adhere the conductive fabric strips!
Can't the Eeonyx patch deform (while the finger isn't pressing on something) and detach from one or both of the conductive fabric traces causing an open circuit?
excllent tutorial!
But I do think there is an error in the Arduino code being used to visualise the data: I get this error when I compile in Arduino:
o: In function 'main':
undefined reference to 'beginSerial'
Could it be a typo somewhere?
Serial.begin();
It's all about spelling and syntax!
Thanks :-D
