Enjoy ;)
Remove these ads by
Signing UpStep 1: Materials
Parallax servo
Cutting pliers
Scewdriver
2X 220Omh resistors
Soldering iron
Desoldering pump.
Soldering iron.
Remove these ads by
Signing Up
Parallax servo
Cutting pliers
Scewdriver
2X 220Omh resistors
Soldering iron
Desoldering pump.
Soldering iron.
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
assuming you have a solder sucker you can easily unsolder the pot from the board and use it in other projects :)
resistor color code
220 ohm: red red brown
2.2k ohm: red red red
Good tutorial
