Introduction: Super Easy LED Flashlight
This instructable is going to show you how to make a Super exremely easy LED flashlight that can slip in your pocket.
Step 1: You'll Need:
3-volt button battery.
Hot glue and a glue gun.
An LED.
Step 2: Put It Together
All you have to do is glue one wire to the correct side of the battery. Bend the other wire so that it does not touch the battery. To turn it on pinch the battery between the wires.
Enjoy.
10 Comments
I made these back in the 80's.
I had a few 1.5 volt watch batteries, so I put a spacer between them and wrapped them it tape. when I took the spacer out and attached the LED, the batteries just had to be squeezed to connect the circuit and I had a mini flashlight!
BTW, you should use a white led, for moar brightness :]
cool, i gotta try this soon.
Minimalist.
He's not a minimalist, he just likes making things way too simple. Oh wait...
aHA! You CAN hotglue electronics if everything is in contact! I KNEW IT!
its kinda tricky to keep the glue from going under the wire. So you have to KEEP it in contact.
Isn't this just a throwie without the magnet?
Yes.
