-This instructable is entered in the woodworking contest. If you liked it then please vote for me when the contest goes to a vote!!-
-If you like what you see here then check out www.darkproductionsllc.com for more cool props and custom artwork. New updates coming Friday September, 24 2010.
Today's project is the Weighted Companion Cube from Portal, and in honor of the fact that Portal 2 is on it's way I would like to present you with my instructable on how to make a Weighted Companion Cube. For this project you will need a somewhat moderate skill at carpentry and a significant amount of familiarity with your Tablesaw, Router, and a chisel.
****WORD OF CAUTION AND DISCLAIMER********
This project puts you in very close proximity to a lot of sharp blades etc. Proper safety measures as well as safety equipment should be observed and worn at ALL times. Basically, if you lose a finger it's on you. So here we go.
Tool List:
10" or greater Table Saw
Router with a 45 degree chamfer bit (I prefer Diablo myself but you pick)
Shaper Table with a v-groove bit
Drill Press
3-1/2" Holesaw
1" Holesaw
5/8" Hair pin nailer (check Harbor Freight tools it's indispensible if you are a carpenter!)
Materials List:
1 piece of 2'X4'X1/2" Medium Density Fiberboard (MDF)
1 Piece of 2'X4'X1/4" Medium Density Fiberboard (MDF)
Remove these ads by
Signing UpStep 1Let the cutting begin!!!!!!
Ended up with:
I'm going to make this, and it will be so much fun!
If not, purchase might be considered. This really is the most impressive looking one I've seen. <3
im gonna be trying so hard to make one from cardboard, im saving the wood for my lifesize dalek. ;)
Regards,
~Newsome-- owner; Dark Productions LLC
(C.C. stands for Companion Cube)
