3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The "Reverse Joule Thief" Battery Charger
The \"Reverse Joule Thief\" Battery Charger
Here is a totally different take on the Joule Thief (JT) circuit commonly found in garden lights. Instead of charging a 1.2v battery directly from the solar cell and converting the power to run a 3-volt LED, we'll be using the JT to convert the output from the solar cell and charging a Lithium battery first. Then when night falls, the battery is used to drive the LED directly.
 This method has some advantages: (1) the Lithium cell that was chosen here (and avialable for $2 here) has an output of 3-volts, which can drive a White LED directly; it also has a huge capacity (800mAH) and very low leakage. (2) The solar cell normally can only charge the NiCd battery in full, direct sunlight, but, with the JT circuit, it is able to deliver power to the Lithium cell even on overcast days.
Step 1The 'Reversed' layout.
The \
A look at the circuit will tell you this is not a run of the mill JT configuration. Most obvious will be the fact that there is only a single coil involved (the 220uH) - we are using a second transistor (Q2) and C1 to take over the timing requirements. This allows us to use a wider range of coil values, as well as operate over a larger voltage range.
Besides reversing the charge / discharge order, this circuit also reverses the location of the driver transistor and the coil, but wait, that's not all! The transistors all have reversed polarities, and even the output voltage is reversed!
No, it isn't an error! Diode D1, the LEDs and the charged battery all have their polarities  reversed! That's because this Joule Thief is configured as a voltage inverter. This arrangement was chosen due to its advantages for this kind of application.
To improve efficiency, the traditional JT relies on a fairly constant battery supply (over a millisecond or so) to give it a boost when it is delivering power. With the limited output from a Solar Cell, we have to store all its power in C2 and feed it into the Lithium in one big pulse, meaning the capacitor will be "empty" for the few critical millisecond, cancelling the 'kick' the normal JT requires to work well.
Our 'Reversed' JT circuit will work as a regular JT - without the 3v Lithium load, an input of 1.2v will light up the LEDs quite nicely. Not strictly necessary, the LEDs are there so you can SEE the system working, and also to prevent the battery overcharging.
36 comments
Aug 13, 2010. 4:07 PMcoherent23 says:
Oh, and it might be worth considering swapping out the overload-protect LEDs with a zener and FET charge-regulator, at little additional time/expense. Can probably grab 'em off a scrounged board. Older boards often even have the schematic symbol for each part, making it easier to ID zeners, transistors, etc.But I still give kudos on this build just the way it is. Haven't built it yet, but it looks sound to me. -Chris whY
Dec 18, 2011. 11:14 AMnigel cox says:
Good evening, have just finished building your circuit, have been looking for a more powerfull led light set up for a long time, can only get the main light to come on dimly but does come on gradually when covering the solar panel, have probably made a mistake with the transistors, will be picking my friends brains as to the position of the pins, using a mobile phone battery of 3.6 volts, do you think this would be alright as I know you can have a certain amount of pecentage error in most circuits, also will this circuit charge up in dull winter weather, thanks for a very interesting article, regards Doc Cox.
May 4, 2010. 6:32 AMacmefixer says:
I forgot to ask, what is the DC resistance of the inductor?  It makes a big difference in the output of the JT.
I have some 180 uH inductors that I've used in similar JT circuits --  their DC resistance is probably lower than this one.  I've found that it helps to boost the output by putting two in parallel which decreases the DC resistance.  Thanks.
Aug 13, 2010. 3:58 PMcoherent23 says:
If you wind your own inductors/transformers using parts and methods described in other JT instructables, and using larger wire, I think you can significantly reduce the resistance. I think this may be one key to my desired 0.5V 0.5A cell JT-esque device. And perhaps FETs instead of bipolar transistors, too. Maybe. - Chris whY
Oct 1, 2011. 8:50 AMjimengn01 says:
I have a project I need some help with. I am new to this forum and can get lost for hours ready all this cool stuff. I need a PCB board made with a subsiquent schematic that ressembles the joule thief, Would you be interested ? I will pay !!
Jim
Oct 1, 2011. 3:36 PMacmefixer says:
You can design your own PC board with ExpressPCB which is free software you download. When you have done a design, you submit it to their website, where they bill your CC and it is made and shipped to you. Three PCBs cost about $65.00. ExpressPCB also has ExpressSCH which lets you draw schematics and export them as a .bmp file. It's true that you have to learn to use the prog but it gives you total freedom to make exactly what you want.
Aug 13, 2010. 10:50 PMacmefixer says:
You can read how this author converted 0.3VDC to 5VDC with some MOSFETs. This is a .PDF document. http://www.ece.uvic.ca/~jbornema/Journals/064a-97ia-jmd.pdf
Aug 13, 2010. 7:42 PMacmefixer says:
I wind my own toroids, and with heavier wire the DC resistance is negligible. I got the 2N7000 MOSFET JT to work down to a small fraction of a volt. See my blog. http://watsonseblog.blogspot.com/2009/01/joule-thief-fet-only-is-topic.html The problem is the current demand increases as the supply voltage goes down. And the MOSFET must have very low resistance. At a half volt, the 2N7000 can only put out a few milliamps to the LED. Paralleling them helps, but a high current, low gate threshold MOSFET is needed.
Sep 4, 2011. 1:40 PMramatern says:
Oscillating output for a charger... is this thing functioning as a pulse charger? Now, if I could get this in a size for lead-acid batteries...
May 29, 2010. 7:49 PM.Unknown. says:
So, is this safe for the battery? What if it were a 2800mah 3.7V li ion battery?
Aug 23, 2011. 12:32 PMmiddlenamefrank says:
Actually, though the link you posted earlier isn't explicit, that looks like a LiFEPO (Lithium Iron Phosphate) battery rather than a generic "Li-IoN" battery (which can refer to a variety of exact chemistries, but not LiFEPO).
A LiFEPO battery has a nominal cell voltage of 3.0V, and an open-cell, fully-charged voltage of around 3.6, as compared to Li-Ion which is typically 3.7 and 4.2 for those conditions. It also has about half the capacity of the Li-Ion batteries, but on the plus side it's a lot cheaper, more rugged and has much longer life (it may last 1000 cycles under circumstances where Li-Ion would only last 200).
So your 3.3V maximum charge voltage is a good maximum, since at that voltage the LiFEPO battery is really nearly fully charged. Don't increase the maximum voltage any more on that battery; although LiFEPO is less likely to behave catastrophically than Li-Ion, you really just don't want to abuse lithium batteries.
Jun 6, 2010. 9:29 PM.Unknown. says:
Can I charge 2 li ion batteries with this? Or do I need a better power source?
Dec 23, 2010. 10:04 AMdasimpson1981 says:
from what you have said using 100ohms to do the maths that gives you 0.02amps
that would be 2ma
Dec 23, 2010. 11:34 AMdasimpson1981 says:
i stand corrected lol
Dec 23, 2010. 10:07 AMdasimpson1981 says:
i think you should of used 10ohms
Aug 13, 2010. 3:48 PMcoherent23 says:
I like your reasoning of using a LiION battery and direct-charging it. I also _LOVE_ this ste, even though I would not recommend some of the more dangerous projects (unlike your rather safe one) to amateurs. Some of them scare me, and I have experience with Tesla coils, and knowledge (in person, and with copious explanation, but no personal builds yet) of micropulsed very-high powered "can-crushers" and theoretical instruction on things like railguns. But this here is the kind of circuit I would recommend to any person who can understand enough about it to avoid catching the LiION on fire. :) I like to see novice to intermediate level projects on here with real-world utility and simple builds, using scrounged or super-cheap components. Bravo! GREAT build! I will most likely be using this idea with my two freebie garden lights and surplus cellphone batteries, but slightly modified for other uses and the parts I have. But, since I can't stop getting sidetracked with 4 more browser tabs every time I open a page, I will ask if you (author or readers) have something like this but for another type of solar cell. There's probably one on here, and/or I could probably knock some of the designs around enough to work with it, but I came here looking for the "pre-invented wheel" so to speak. I was given a solar cell that can generate 0.5V at 0.5A, which is a substantial amount of power - 250mW - as tested for voltage with no load other than my meter's 10 or 20Mohm voltage circuit, and current with a direct short through the 10A low-resistance - probably an ohm or so - circuit on the meter), but at a very low voltage. (The meter was a freebie too, needed repair, and I don't have a spec sheet on it.) I have experience with many types of electronics, but not with ultra-low voltage. Is there a JT-type of circuit I can power with this cell? (Although I have even outdone and defied true engineers a couple of times with my hacks they said were impossible, "I are jus' a technishian, sir," as I was instructed by my professor in trade-school 20 years ago to say. And I'll design bicycles for fish if I'm so-inclined, but don't like inventing the wheels. :) Anyone? Anyone? Bueller? (Someday I'll have a solar-powered catapult that throws cars, like that crazy British nobleman has, but solar. Yeah. That's it. That's the ticket. I also want a Tilt-A-Whirl(tm) ride combined with 12-gauge skeet-shooting, and Wile E. Coyote's ACME Portable Hole. I need Trump's money and Wile E's ACME catalog. That may just be my life's dream. How did Wile E. make his money for all that stuff? I'm unemployable by conventional standards. And I'll catch that darn bird, someday.:) (comment deleted and reposted after correcting typos.) -Chris whY
Jun 15, 2010. 8:45 AMrmfungaro says:
I have a 6v solar cell, removing the joule thief circuit i can use this circuit to charge 3.6v Lithium batteries?
May 3, 2010. 7:05 PMjimk3038 says:
Great instructable!
Just the other day I bought a solar lamp at the hardware store for $3.50 bucks. I bought it just so I could rip it apart. Blows me away - only $3.50.
I'm guessing there is no reason I couldn't use a pair of 1.2V NiMH instead of the Lithium cell. I've got a bunch of 2500mA.hr AA cells.
I'm hoping to keep a Zigbee radio running instead of the LED. The radio uses 200uA while sleeping. When transmitting / receiving the current jump up to 35mA. However, the active time is only for a few seconds. The radio then goes to sleep for a programmed amount of time (15 minutes).
OK, my question, is there anything special about the inductor? Will any old 200uH inductor work? I found a couple at digikey - here is an example: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=237-1173-ND
I had a hard time seeing your inductor in your pics. Could you put a lasso around the inductor to call it out?
Thanks again for a great instructable.
May 3, 2010. 9:08 PMjimk3038 says:
Thanks for showing the inductor in your pictures. I guess I forgot they could look like resistors.
I'm not sure I understand your comment about using the LEDs / diodes for regulation. If there were no LEDs or diodes would the circuit simply keep the 3V battery trickle charged? After becoming fully charged, the battery would simply waste the extra energy by becoming warm.
My Zigbee radio can handle 2 to 3.6 volts. So, if anything, maybe just a 3.6V zener diode to clamp the output from ever going over 3.6V. You see, in my application, I don't want to share any energy with an LED.
Does that make sense?
Thanks again,
Jim
May 3, 2010. 7:35 PMNerdz says:
Since the joule thief is nothing more than a boost converter, the value of the inductor doesnt. The value of L just determines the frequency and amount of ripple in the output. So you can probably get away with using a home-made inductor using a ferrite core from a old power supply with a few turns of wire (say like..10+ is a good start)...or if you can..radio shack sells a assortment of inductors..you can pick and chose one that works from there..its like 2.50 or something for the pack
Aug 31, 2010. 9:55 AMrcisneros says:
I wonder if you could reverse this circuit? Everything but the inductor is in one component. To the left is the LED and the Blue/Black wires come from the 2v 20ma solar cell. Red/black wires go to the 1.2 600mah nicd.
Sep 1, 2010. 3:40 PMrcisneros says:
It's real name is QX52521F. It cost 0.01 yuan. I'm looking for it the states with no luck. If anyone can read Chinese, http://paulchen3.b2b.hc360.com/supply/62313686.html
Sep 7, 2010. 8:08 PMrcisneros says:
Hey I found a supplier that will sell them to me for 10 cents or 20 cents a piece. I'll have to go with the 20 cents because the 10cents people have a minimum of 1000 pieces policy. If you don't have access to this IC, I can send you a couple for you to play with as a thank you for your time and advice.
Sep 1, 2010. 11:19 PMrcisneros says:
1. Thanks for the response. 2. If I find this stateside, I'll post the info asap. 3. I'm a little confused. Got the add a 100uF cap to the solar cell and connect them to the battery input. The second part is where I'm confused. Which diode would you say is a good choice?
Sep 7, 2010. 8:10 PMrcisneros says:
How does the size of the inductor effect the circuit? Would a larger inductor drain the battery faster but give a larger out, brighter light? Or does it effect duty cycle?
Sep 3, 2010. 5:19 PMrcisneros says:
Wow. That sounds great. I'll post the results as soon as I build the thing. QS you rock btw.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
