3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ultimate Vertical Hydroponic Farm on the Cheap.. Gift away green crops!
Ok guys i apologize for the crappy instructable .. i kinda rushed it in order to make it to the gift contest... i obviously lost that one.. so i'm coming back to fix this one... maybe i can do better in the Shopbot contest :)
Ok originally i said a lot of things about a concept.. i wrote a blog while building this and i reused the stuff i wrote back then.. of course this is no longer a concept.. i fixed it into almost a final design.. i'm going back and cleaning this up so if i left concept or past tense stuff please forgive me..
Looks like i lost all of the contests i entered and i'm not elegible for the gardening contest going on right now.. So if you liked my instrcutables and you learn something. please vote for me in my other contest entries..  right now i need all the votes i can get..  my best contest entries are the following... i organized them in the order of chances of winning.. please help by voting for me
RIght now i believe my best chances of winning are on this Nano holder with earphone organizer. So please!! vote for me
http://www.instructables.com/id/3d-printed-6th-gen-nano-watch-band-w-earphone-org/
.25 ultra slim minimalistic Wallet, money clip, metal bottle opener, credit card that could be attached to your android case
http://www.instructables.com/id/25-ultra-slim-minimalistic-Wallet-money-clip-me/
This is a link to my iphone wallet case.. so please vote for me here too .. thanks
http://www.instructables.com/id/The-ultimate-all-in-one-iphone-case-wallet-money/
THANKS
Step 1Hydroponic concept and materials
hydroponic concept and materials
  • last photo ←
My materials are as follows
Water pump
Sunterra 120016 Large Fountain Pump, 200 GPH, Black (the GPH might be a bit much but you need the power for the water to go up that high)
i think it was a 10 ft Rain Master 2 in. x 3 in. Vinyl Downspout... cut down into 3 long pieces X2 with a total of 6 pieces
http://www.homedepot.com/h_d1/N-5yc1vZ1xg3/R-100095267/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Amerimax Downspout Flex Elbow X5
http://www.homedepot.com/h_d1/N-5yc1vZ1xg3/R-100036053/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
15 min timer for the pump
Another timer for your lights.. don;t matter which type.. cheapo is fine
Black piping hose
PVC pipe (for reinforcement)
2 - 2" x 3" plastic C outlet
2  - 2" x 3" pieces of flat plastic (you will use this and the C outlets to make lid for each end of your system)
Large container to work as water reservoir
6 - 2' by 8" pieces of wood to  make your system shell  or reinforcement
Large zippy ties
solo cups or net cups..
if you use solo cups use a 3 in hole saw (i did this but later changed it to net cups so my holes were kinda big
if you use net cups use a 2.75in hole saw. (didnt test this so i'm guessing) (dont make it too thigh so u have space to take out once you have roots)
Vinyl Downspout has a small side that goes inside of the downspout and a large opening that goes over the other downspout piece.. i placed the larger piece on the one on top and the small one on the bottom to prevent leaks... this is a crucial step!!***
i then sealed it with LOTS of silicone and duck tape... you can use black or white.. i used black but then covered with white for appearance purposes *** please use lots of silicone..  please let the silicone fully cure before exposing it to water.. having the seals water thight will save you lots of headaches trying to fix leaks later on!!
i'm using dixie plastic cups.. they require a 3 inch hole and i used a 3 inch hole saw.. The cups are bit big but ithink it might be good since i be able to grow bigger plants.. i don't know how is going to work out.. but i seen people use smaller cups in other set ups (PLEASE NOTE) i did change the design.. so please read the entire instructional.. i changed the red solo cups to net cups.. they a bit more expensive.. but they let the water flow easier and they let the plants grow around them... Try using a smaller hole saw... like 2.75 in .. so the net cups fit better if you gonna use this design
i used solo cups at the beginning and i drilled 3 holes at the bottom of each cup
i'm using some roofing metal net and some plastic pieces to hold this up.. and some zippy ties. but i dont think this is going to be my last set up.. i might change it later on
PS.. For some reason they dont sell end caps for downspouds.. so you have to improvise.. i use the plastic C- outlet then needed to add a flat piece of plastic.. and screw it to make it a cap.. Silicone it and duck tape it to make it a end cap..
(PLEASE NOTE) i did change the design.. so please read the entire instructional.. i changed the red solo cups to net cups.. they a bit more expensive.. but they let the water flow easier and they let the plants grow around them... Also Please not that the total vertical design doesnt work well.. look at other pictures.. it ended up being a slanted S shape.. this method lets lettuce and other plants grow in different directions.. believe me those lettuce heads will get huge.. and so will the curly kales
22 comments
May 20, 2012. 1:54 PMkleinjahr says:
Ahemp! Nicely done, of course no one would even think to grow anything for recreational use. Mind, if one did grow such a plant,or two, it would only be for the purpose of doing an instructable on rope making. Riiight.
May 21, 2012. 2:01 PMaaronjehall says:
is mojito mint really any different from peppermint?
May 21, 2012. 3:43 PMStCanna says:
I love your use of materials! The first thing i though then i saw this is "where would i put the fish tank for a aquaponics setup?" I was thinking to have water/effluent from a fish tank pumped up to the top as you are doing and then the larger containers on the bottom could use a bell siphon equipped bed to dump back into the fish tank. That way you would maintain an organic system without having to continually purchase "nutes" and you could produce edible fish as well. If you haven't done any research on aquaponics just search the word on youtube and you will get way more than you can watch and also search the name Murray Hallam as he is one of, if not THE, leading authorities on the subject of building aquaponic systems.
May 21, 2012. 6:51 PMStCanna says:
Just make sure you do some research on the subject. Aquaponic systems need to "cycle" before they can support the plants without added nutrients. Also the big blue container you refer to probably won't be a good choice for fish long-term due to the fact that most of those contain BPA and will slowly leach into the water and eventually kill off the fish as well as being absorbed by the plants you hope to eat. Usually the solution is to get some type of container that is "food-safe" or BPA-free although i have wondered about taking one of those cheap containers and just coating the inside with a "marine" resin as that would be safe for constant water contact once it cures.
May 20, 2012. 7:09 AMjuly1962 says:
I don't know about this. Once some of the bigger plants get tall, they're going to be growing up in front of the ones behind them. I would think this would only work for plants that stay small, except for the top row.
May 20, 2012. 8:22 AMdbennett says:
I'm worried about mold growing in the folds of the flex pipe. Have you noticed any problem with this? I've read the instructions for commercial hanging gardens and they always direct you to dismantle and thoroughly clean, preferably with bleach, the whole system each month. ☹
May 20, 2012. 2:54 AMjmunoz10 says:
Amazzzzing!!!! I cant wait to start this project!!!
Feb 7, 2012. 6:42 AMAaronJBobb says:
Awesome Instructable! I'm almost done collecting all the supplies. I was wondering what type of pump you used? How many GPH is it? And where did you get it?
Feb 7, 2012. 7:58 AMAaronJBobb says:
Thank you! I'll post pics once everything is done. Can't wait to get things growing!
Jan 17, 2012. 10:29 AMCatTrampoline says:
Excellent instructable. I especially like how you tell what did NOT work and why, in order to save others some frustration.
I might try this. Outdoor vegetable gardening in north Texas is so challenging that I have decided to move most of my efforts indoors.
Jan 17, 2012. 8:43 AMjessyratfink says:
Awesome. Very nice setup. :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:mstyle183
