I am using this idea since last six months, it just came in my mind (why not experiment).DANGER HIGH VOLTAGE
You need the circuit of an energy saver bulb whose tube is burnt or damaged.
This is a high voltage and high frequency generating circuit, be careful there is high voltage present if you connect it to AC line. There is a high voltage input capacitor (from 2.2uf to 10uf 400 volts). The idea is to put a bridge rectifier on the output on this circuit and use for LEDs.
A 23 to 25 watt energy saver’s output can produce 165 mA current (it is written on it) for the energy saver light bulb. We need to use this constant current output for our LED lights. By using bridge rectifier (ultra fast) you can get 100 volts of DC. A high frequency switching output cannot be rectified properly by using normal bridge rectifier like 1N4007 or similar. We need an ultrafast diode to make a bridge rectifier like UF4007,BYV26 or similar.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
On a side note, today i didn't have time to go buy the diodes so someone went for me with a note with my specificacions. In my note said UF4007 diode and i specifically said I DONT WANT the typical 1N4007. Guess what the vendor sold to my friend... 1N4007's .
Some guys just want to sell stuff...i hate that.. :(
Good luck my friend and i'll write to tell you my results when i can go MYSELF to buy the bloody diodes :)
If you go to market to buy yourself ask the shop keeper to give you diode with 700-1000 volt 1 amp and recovery time of at least 50 ns (nano seconds) if you get less than 50 ns it will be great, or if you get a bridge rectifier of same ratings.
Regards
Hope you get my message and you're kind enough to guide me, obviously i'm a complete amateur. (Maybe i should be playing with this stuff :) )
Cheers
HIGH VOLTAGE CIRCUIT BE CAREFUL.
It is very good to try yourself I do appriciate it thats how you learn.
Please try to use the diode i have described (or any ultra high speed) I have selected this diode after many experiments. No bridge rectifire will do it. If possible get ultra fast or hyperfast bridge rectifire (may be not available in the market). The out put depends on the rectifire and capacitor. When you put the load there you measure the voltage and current. On NO load the values are different. Recently I got a 45 Watt CFL which says 750 mA current but when I made the circuit (with ultra fast diode and .47uf capacitor) the load says 250 mA current at 100 volts. I tried 1.0 uf capacitor but no more current I also usd hyperfast diods but still same values od current and voltage.
Its better using CFL having capacitor joining filament.
Regards.
Regards.
I really liked your project!
Where do you live?
Also, I am against using 5mm LEDs for home illumination, sooner or later they do burn out as they have no heatsinking. And when used in larger groups, close placement and combined heat makes it worse. Its not good to see our hard sweat wasted because some of 5mm LED burned out. i am yet to see a properly driven 1W led burn till date.
Also, in the 150mA project you have seemingly used 1w LEDs? or are they are half watt>? what did they cost?
If you use LEDs slightly below their recomended current rating they wil not burn nor produce more heat. For example a 1W LED uses 3.3v and 300 mA. Try driving it on 280mA current. Also for a 20mA LED use 18mA current. In this way its life increases and less heat.
In this instructable LEDs are being driven on 140 mA current not on 150mA.
Since then I swear i'll use only 1W, 3W and such high quality LEDs. Making our gadgets is pain and time, Can;t afford to loose the hard work due to some inferior components. These usually, I drive 700mA or 1000mA LEDs at 350mA... SUper low heat and super long life!
I agree with you I have the same experience as you said with 5mm LEDs.
please use 1 ohm or 1.5 ohm 3 Watt resistor.
All LEDs are in series, because the output voltage is about 100 volts so a 3.3 v LED in series of 30 will cover about 99 volts.
Of course if one LED will burn the whole string will go off. Try using good quality LEDs of the same manufacturer, this can reduce the burning of LED.
I will try to overcome this problem and will try a simple method so the instructable will remain simple and easy.
If you have any simple idea please share it with me.
Thank you.
Tomorow i bought 30 LEDs of 8mm & 0.5 Watt. I want to ask about the Capacitor and diode. Should i use the same diode and capacitor for 8mm LEDs?
I also bought 0.1uf 400v capacitor and UF4007 diodes. please tell me that should i use the same circuit for 8mm 0.5 watt LEDs as you used for 0.5 Watt LEDs?
I have these LEDs CLICK here
and you used these Click HERE
Now is the circuit same for both configurations????
Regards:
Kashif Raza from Pakistan
Also read the instructable again for the safty, this circuit has live and high voltage when connected with AC line. Please be careful.
Thank you
Regards:
Kashif Raza
Please use attached circuit. It will limit the current to 150mA. after connecting LED check the voltage accross LED terminals. it should be between 3.2v to 3.4v. if yes then it is 0.5 watt LED if not then it is not 0.5 watt.
(Did you get LEDs from Hall road, Lahore?)
do not change the value of resistor (R) and please use 3 watt resistor and use heat sink for LM317T.
For more info on LM317T please download its datasheet from internet.
I still have those unbroken bulbs with me which were removed from the base easily and couple of them were not able to survive are in sealed container. I normally do this kind of stuff away from residential area in open space and break them inside a big plastic container so every thing remain inside it.
Please visit following web sites for more info about broken CFL disposal and cleanup.
http://www.epa.gov/cfl/cflcleanup.html
http://content.usatoday.com/communities/greenhouse/post/2011/01/epa-clean-up-broken-cfl-bulb/1#.UEmKQrIgdSg
http://www.mass.gov/dep/toxics/stypes/brkncfls.htm
