Unfortunately I can't get completely miffed about it because I love a couple of flavors of capri sun. Plus it's handy as heck to pop them in the freezer then pop them in my lunch box cooler. They serve a dual purpose here. They keep things cool in the lunchbox cooler, and by the time lunch is around they have thawed out.
The other thing I love about these things is all the cool things I've seen people make with them. Wallets, purses, bags, you name it. Just do a google search for "capri sun projects" or "DIY capri sun". You'll see what I mean
I have a bit higher aspirations than that. I want to try making an umbrella or a tent out of them. But the tent might be a bit ambitious. Most people sew them together with thread, fishing line, or upholstery thread. Or they will tape them together with Duct Tape or Gorilla Tape. I wanted to weld them together.
At first I looked into how they do it industrially. Apparently they either use microwaves or ultrasonic welding. Do-able, but not for everyone. Certainly not with parts I had laying around the house, and certainly not cheap.
In the end I found a soldering iron or wood burner works like a charm.
Step 1: The science...
What is CAPRI SUN packaging made from? Is it recyclable?
CAPRI SUN pouches are polyester-reverse side printed to aluminum then laminated to polyethylene (a plastic polymer). Unfortunately, this packaging is not recyclable.
So it looks like a laminate of aluminum foil and polyethylene. Ok fine. What is the melting temperature of polyethylene? A quick trip over to Wikipedia and I had my answer. I love Wikipedia, best invention ever. The nobel prize should go to the guys that invented it. They are certainly more deserving than a couple of the past winners.
From Wikipedia:
For common commercial grades of medium- and high-density polyethylene the melting point is typically in the range 120 to 130 °C (250 to 265 °F). The melting point for average, commercial, low-density polyethylene is typically 105 to 115 °C (220 to 240 °F).
Ok so the melting point is somwhere between 220°F (115°C) and 265°F (130°C). Ok, that shouldn't be a big problem. I think clothes irons only get up to about 200°F so I'm thinking an Iron wouldn't work.
Step 2: Trying to use the EuroSealer to weld Capri Sun pouches together
You can pick them up for cheap on eBay. I did. It, unfortunately, doesn't have the heat needed to weld Capri Sun pouches. So I thought I could open it up and remove the resistor in it (if there is one) or put more voltage through it by rigging a larger battery source. It uses two AA batteries so it has 3volts. I thought of hooking it up to 4.5 volts and 6volts to see if I can get more heat out of it.
I still think this is worth trying I just haven't gotten around to doing it yet. But I'll update this Instructable when I do.
Step 3: Building a Capri Sun pouch welder.
UPDATE:
Ok so I tried taking a stainless steel bar, heated it up on the electric stove burner (on high) then I tried to clamp it down over 2 overlapped Capri Sun pouches on a wooden cutting board. It was a surprising failure. I could hear the remaining liquid in the pouches searing, I could see the plastic pouch melting. But no matter how hard I pressed I couldn't get the two pouches to weld together.
Stay tuned for my next attempt along this line. I'm going to take a copper pipe to try to weld pouches together. What I learned from this last attempt is that I think I need something flexible underneath the pouches along the seam to help compress and set the weld.
UPDATE:
One commenter on this project gave me a good idea. Perhaps using some material between the bags to act like solder flux would aid the welding process. The trouble is, what that material might be. I'm thinking of a lower temperature melting point plastic.
Step 4: Using a Soldering Iron or Woodburner to weld Capri Sun Pouches
Another quick trip over to Wikipedia and I had the information about how hot a soldering iron gets:
Lead-based solder uses 250 °C to 280 °C or 300 °C while lead-free soldering needs a higher temperature, about 350 °C to 400 °C.
So a soldering iron gets plenty hot for welding Capri Sun Pouches. I just have to be somewhat quick and not leave it in the same place very long. Now my Soldering Iron/Woodburner comes with a bunch of different tips, so I selected one that was flat. This tip actually broke when I was using it, but they are cheap to get replacements (or so I hope). But it still had a flat side on it and it continued to work for my purpose.
Now it takes a bit of practice to get this technique down. You have to figure out the right speed with which to drag across your seem without making a hole, but still keep it in place long enough to melt the Polyethylene. The pictures below are actually my second attempt so it's easy to pick up the technique. The secret is lots of steady pressure, and it works best if you weld both sides. But when I was done I had two Capri Sun pouches welded together. The seam was water tight and wouldn't pull apart. Brilliant!
So commence the making of things with Capri Sun Pouches!
Step 5: Using a clothing iron to weld? Not so much.
Conclusion: A standard clothing iron just doesn't have the heat needed to weld CapriSun pouches together.
Visit Our Store »
Go Pro Today »
However you did give me a good idea. Perhaps putting some material that would act like solder flux between the bags before welding them would aid in the weld.
Chris
Of course, I've been resealing MRE pouches, potato chip bags, and the like for forever. It's great to seal up stuff like cigarette lighters so they stay waterproof while hiking
I remember having to adjust the heat down slightly from the top of the range. I also put some newspaper down so I don't accidental seal it to the ironing board.
try google/youtube with seal mylar iron
Thank you for your contribution!
