3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wifi Receiver Extender (W.R.E.)
I will show you how to make a simple wifi receiver extender made from household items. I had problems getting a good wifi signal in our house so I thought of this. It help me it might help you!
Step 1Meterials Needed
Meterials Needed
Materials:
- Wifi Receiver
- USB  Extender
- Steamer Plate
- Laptop
- Tripod
24 comments
Jul 11, 2010. 7:40 AMrimar2000 says:
Very, very interesting, congrats. I have an laptop Acer ASPIRE 4315 (this that I use now) with wifi, but the wifi is transparent for me. I start it and the router, and it connect to the web automatically. Can I use your invention? How? Forgive my ignorance...
Jul 11, 2010. 7:46 AMScott_Tx says:
Luckily he's provided instructions on how to make your own, how convenient!
Jul 11, 2010. 2:41 PMmattyk6 says:
You need to use an external USB WifFi adapter. Your laptop comes with an internal WiFi adapter, but for the directional aspect, you need either an external antenna or WiFi adapter. I've not seen a laptop with a connection for an external antenna.
Jul 11, 2010. 5:26 PMrimar2000 says:
Thanks, I did imagine something so. As I use always the laptop the same way, never I needed an external wifi.
Jul 13, 2010. 10:08 AMspa31rky says:
So an external adapter is required. Explain more please. I have an DELL INSPIRON 2200 WITH INTERNAL WiFi
Jan 24, 2012. 1:54 PMmahmoud169 says:
what i can say just thanks
Dec 29, 2011. 9:11 AMdagob says:
If I use a full sized satellite dish to make this wifi extender will I get signal from further?
Jul 19, 2011. 1:24 AMXOIIO says:
Why is this in the laser section?
Jul 4, 2011. 11:32 AMtrewq7 says:
does it work?
Jul 11, 2010. 8:22 AMXOIIO says:
Not bad, I've seen better and worse. When we moveminto our new house I am going to set uo a full sized satellite dish like this!
Jul 3, 2011. 11:52 PMsiamonsez says:
If you know the the direction of the wifi source, a wave guide like the cantenna:
http://www.turnpoint.net/wireless/cantennahowto.html
would give much better results.
A parabolic antenna shouldn't make much difference over such a short distance, and if you are really getting a stronger signal it's probably just because of the large mass of metal and not the shape.
Also, any antenna should actually be wired to the signal receptor. A USB wifi adapter that already has a little external antenna for ease of access.
Jul 3, 2011. 10:36 AMjavajunkie1976 says:
This is great! I only have WiFi connection when I'm squeezed into a tight corner of my place and only if I prop it up to standing level. This will help as no one should have to stand all the time to use the net.
Jul 11, 2010. 12:28 PMStevanx says:
Nice quick project, but i miss some data on how much it improved the WiFi range etc. and how about when you're not aiming directly at the WiFi transmitter? Another thing - I think I will try to test this on a 3G(HDSPA) modem to see if i can get a better signal since the coverage here is very bad. Will update you on this when I get the time :)
Jun 5, 2011. 7:57 PMcliqueker says:
It's not a Wifi extender or something... Take note that the author indicated a Globe Tattoo on the 1st page. That was just a USB modem for 3G/HSDPA signal. It won't work for Wifi unless you buy yourself an external wifi antenna.
Nov 2, 2010. 5:55 PMhipydude2001 says:
im not getting any reply notices so could you email me at hipydude2001@yahoo.com
Nov 2, 2010. 5:54 PMhipydude2001 says:
what would be the max strength of the wifi recev and a decent and absolute minuman?1 mbps 11 ,23,50,80,100,3gs? or does it depend mainly on the dish?
Nov 2, 2010. 1:18 PMhipydude2001 says:
i have a full size satalite dish and have been wanting to try to convert it to get free wifi and possibly maybe a better speed, im paying to much for only like 6 mbps at best as is with lan line, i would have to look at it better and its out side so i would need a pretty long cord?.
Jul 22, 2010. 6:57 AMknotquiteawake says:
I made something just like this last weekend while moving. We had ATT shut off our internet since we were moving. I used a paper bowel lined in tinfoil with that same kind of adapter pushed through it. Worked like a charm. I wish I would have thought of the veggie steamer, since we did have one I could have used. It allowed me to get the free wifi from the apartment's lobby across the complex.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
132
Author:ASCAS(ASCAS.com)
My name is "Angelo S. Casimiro", I am now 13 years old. I got interested in electronics and mechanics when i was 4 year old. And started soldering circuits (kits) at 7 years old. And improved solder...
more »
