3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wooden Remote Control Quadrocopter Build
Introduction
Hello Everyone,
First, I would like to thank you for viewing my instructable.
And, if you enjoyed it, please give me a vote!
Thanks....
Now onto the instructable.
I've been into remote controlled toys since I was a kid.
(about 40+ years ago, summer of 1969?)
I had purchased a Roswell Quadrocopter (see blueprints on next step) back in 1999.
(still a kid?)
This is the first Quadrocopter I have purchased.
Never built it, though...(guess I never had the time)
Now, I dug the old flier out of storage and thought I would like to build a wooden one.
As, the original Roswell Quadrocopter was made from paperbacked foam.
Seeing now, the electronics and motors are much better then 11 years ago.
I will not be going into heavy detail on the build of this Quadrocopter.
As, that could make it a very long instructable.
Also, you may notice I don't have pictures of every step.
I didn't plan on this being a instructable, so I took what pictures I had
and did the best I could of describing what I did.
I will give you brief descriptions and hopefully this info will be useful for someone else.
If you are interested in some history on the Quadrocopter.
History of the Quadrocopter
Quadrotor on Wiki
If you like my instructable, please take a second and vote for me!
My quadrocopter took 2nd place at the 2010 Minnesota State Fair.
Step 1Stuff I used to build the quad.
Step 1
I did all my designing with my CNC (Computerized Numerical Control) software.
DIY-CNC
I used a program called Aspire made by Vectric software.
Vectric - CNC software
I scanned in each part from my old Roswell Flier kit.
Then I traced them, modified each part  and turned them
into vectors.
I used a Sherline Mini mill to CNC the parts.
Sherline Products
 I did use the Mikrokopter electronics.
The copter is capable of hover hold, GPS, and flying FPV (first person view)
The electronics can be purchase here:
Mikrokopter Products
Motor used are:
Brushless Turnigy 2217 20turn 860kv 22A Outrunners
Another good website for reference would be
RC Groups Forum
The blog of my wooden quadro-copter on Rcgroups.com.
The copter is made from Ash, Oak, Walnut and Paduak.
The battery used is a 11.1 volt lithium.
I am using a Poweredge 2200 mah 11.1 volt lithium.
Most important:  TIME, PATIENCE and lots of reading!
Now onto the next step...
78 comments
1-40 of 78next »
Jan 3, 2012. 10:22 AMlesizz says:
Not only a cool project, but nice looking too. I understand how you get forward motion, by adjusting the motors to lifti one side of the aircraft so that the blades are slightly tipped and thus applying directional thrust. But how do you pivot the craft to make it face a different direction?
Jan 3, 2012. 6:46 PMRadioactive_Legos says:
Because two motors rotate clockwise and two motors rotate counter-clockwise, by increasing the speed of the clockwise motors and decreasing the speed of the counter-clockwise motors the quadcopter is able to rotate clockwise. The opposite obviously applies for rotating counter-clockwise. It's very similar to how a conventional helicopter rotates (called "yaw"). The tail rotor on a helicopter pushes to counteract the rotational force of the main rotor. By increasing or decreasing pitch on the tail rotors and thus the thrust, it can let the helicopter rotate clockwise or counter-clockwise. Hope this helps!
Jan 3, 2012. 7:21 PMlesizz says:
Gotcha. Tx for the reply.
Since opposite-spinning props are positioned opposite from each other, then same-spinning props are adjacent to each other. (I had to draw a diagram of a 4copter to figure this!).
So then, increasing the speed on one same-direction pair would tilt the frame resulting in horizontal thrust. So if my logic is correct so far, then turning the frame results a directional thrust. If that is correct, then is your turn-the-frame control the same knob as your horizontal thrust control? But then, I suppose you could provide horizontal thrust by increasing the speed of only one prop.
(Sorry, I tend to be hyper-analytical, and this thing fascinates me.)
Jan 3, 2012. 7:36 PMRadioactive_Legos says:
Traditionally, the same-spinning props are opposite from each other. That way (in a "+" configuration, at least, where one motor is at the front of the quadcopter), increasing one motor and decreasing the opposite motor will move the quadcopter forward/backward/left/right or any combination of those, and increasing either pair of same-spinning props and decreasing the other pair will make the quadcopter rotate clockwise or counter-clockwise.
Jul 24, 2011. 7:25 AMsdevi reddy says:
hey sir,
iam Jeevan reddy from india,sir can i use the motors which are used in dvd drives and also i want the detailed technical description of quadrocaptor.
Jan 2, 2012. 10:18 PMmaverick31 says:
hi hero..this is murali.. from vijayawada... its great that you have dare enough to do such a project.. did you succeded in doing it.. and i am at starting stage can you help me out in doing this
Oct 24, 2010. 1:25 PMMichaelgoode says:
video?
Sep 4, 2011. 9:41 AMvruiz3 says:
its on the last page
Sep 5, 2011. 2:07 AMMichaelgoode says:
I asked that nearly a year ago, but thanks! ;)
Oct 3, 2010. 6:59 PMdermord says:
oh might godd!!! you are a totally genious! ,do you sell it???
Sep 4, 2011. 9:42 AMvruiz3 says:
900+ dollars? :D
wow that monster has got to be worth like 900+ dollars
May 9, 2011. 12:31 PMhuf123 says:
Just out of curiosity, what took 1st place at the state fair. Because this is one of the coolest home built projects that I have seen.
Jul 26, 2011. 6:24 AMsdevi reddy says:
hai,
hello iam jeevan from india.please help me in this project.please email me the detailed circuit of quadrocaptor and also parts which are required for this.
i hope u will help me.
Jul 30, 2011. 7:19 AMsdevi reddy says:
tnq sir.....................
can i use dvd player motors for quadrocaptor design
i cant get the motors which are prescribed by u......................................
Jul 24, 2011. 7:28 AMsdevi reddy says:
sir i was in this project since 3 months.please help me sir.
i want detailed circuit design of quadrocaptor.please sir awaiting for your reply
Jul 30, 2011. 7:13 AMsdevi reddy says:
thank u sir for ur reply................
Nov 27, 2010. 8:45 AMAmit Tulshyan says:
respected sir,
>i didn't understand how did you build the remote control
>secondly i live in india can you sugest some other kind of motor which is easy to find any where
Jul 24, 2011. 7:31 AMsdevi reddy says:
hai Amit,
iam from hyd..if u like to do friendship with me email me.saijeevan.d@gmail.com is my email.we can share our ideas abt this project.
May 25, 2011. 6:20 PMgurustein says:
It's awesome.Few people in my country had made it and claimed it that they invented it.But now I came to know that it was invented many years ago.Thank You.
Nov 18, 2010. 4:45 PMddrocketman says:
great touch!
Nov 12, 2010. 11:37 PMtzq33tdq says:
this is so awsome!!!
Oct 25, 2010. 1:04 AMMichaelgoode says:
hey, i love this, your work is great. I am a young and inexperienced builder, so im asking if you would help me build this remote contol car/robot thing. It will have a 4 wheel drive with tank steering, I have been wanting to do this for a while. I almost know what im doing :D
Oct 25, 2010. 5:58 AMMichaelgoode says:
its not a tank it just has tank steering. But thanks for the help.
Oct 10, 2010. 12:36 PMjaruwit says:
very nice.
Oct 5, 2010. 12:28 PMPyrochrome says:
Hi Greasetattoo,
Nice work, congratulation. You must be both artist and scientist.
With which software did you do the mounting insctructions drawing ?
I need to do exactly the same with my CAD files for my home made robot, you'll be nice to give me some advice to do it. thanks !
I give you 5, 'cause esthetism, engineering, and communication are all perfect.
(your tattoo rules !)
Oct 6, 2010. 11:07 AMPyrochrome says:
OK, I was thinking that you draw it yourself.
(this file: http://www.instructables.com/image/FHWS3H7GEFGD5GJ/Stuff-I-used-to-build-the-quad.jpg)
thanks !
Oct 5, 2010. 11:10 AMMattFryy says:
Yeah alright so this things pretty cool, but there's still space on top for a deathray or two. Make it happen and the Drone hasn't got a chance in hell!
Oh how I love technology.
Oct 5, 2010. 6:11 PMMattFryy says:
Good to hear the world is well and truly doomed. In a good way :)
And no, but I'll keep my eyes open on eBay.
Oct 5, 2010. 11:40 AMtoddkrein says:
How do you keep the pieces secured in mill during routing? Sprues?
Oct 5, 2010. 9:22 AMmiauster says:
Very, very nice work. You should be the first!!!
1-40 of 78next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
98
Author:Greasetattoo(Tattoos From Grease)
Thanks for viewing my Instructable! Click above link to see some of my tattoo work! I am a Tattoo Artist, 20 plus years and a hobbist Woodworker, 40 plus years
