SKODA Superb MK2 Door Panel Removal
26,023
6
11
Introduction: SKODA Superb MK2 Door Panel Removal
About: A Mechatronics engineer with an addiction for knowledge.
This instructable is aimed to help the Škoda superb mk2 owners like me who were having trouble removing the door panel.
Step 1: Uncovering the Screws
1-Removing the handle:
-The window switches' panel is welded with top part of the handle, and the handle should be removed entirely by prying it upward with a wide flat head, preferably without sharp edges because the rubber is a little weak. and the second picture shows the location of the clips (yellowish greenish color).
-The windows switches panel's connector is removed by pulling the blue lock and pulling outward.
-The mirrors' switch connector is annoying to remove by hand, however, it's easily removed by inserting a flathead between the connector's shroud and the plug, pushing it in and twisting.
Two T-25 screws is hidden behind the handle.
2-Removing the tweeter's cover:
-The cover is removed by inserting a flathead and twisting slightly to unlatch the clips.
-Doors locks' rocker button is removed similarly to the mirrors' switch, but can easily be removed by hand
One T-15 screw is hidden behind the handle.
3- The door also has two visible T-15 screws in the bottom side.
The panel now has no screws connecting it to the door.
Step 2: Removing the Panel
-The panel now has to be pried away from the door using a wide flathead (plastic is better as to not scrath the paint), starting from the bottom and working around the panel's sides. (The fasteners' locations are visible in the picture)
-After the panel is loosened, it's pulled upwards the outwards.
in that step the window's rubber and the panel top leather part will rub against each other, and it is going to make it feel like the panel is still attached with something, careful prying should eliminate this problem
The panel has Five cables preventing the panel from being pulled out further from the door :
1-Door handle's bowden cable, and is removed by unlatching the clip and pulling it to the left (while looking from above).
2-Door handle LED's connector, and is removed by pushing the metal pin inside and pulling the connector out.
The led can also be removed with it's casing from the door handle easily (may come off on its own) but re-attaching while remounting the panel is a PITA.
3-Tweeter's connector, and is removed by pinching with the right thumb and index and pulling the connector out with the left hand.
4-Security's indicator LED, removed by inserting a flat head and twisting, lifting the tab securing the connector, then pulling the plug.
4-Puddle light's plug, and is removed similarly to the tweeters connector.
(two man job, or using something to keep the panel high untill the plugs are removed would help alot)
Step 3: Reassembly
Reassembly is pretty much retracing the steps,but while paying attention to:
-The fact that the panel has hooks on top that latch onto the cover behind the mirror.
-Fishing the handle's connectors before attaching the panel is essential, because they Will get lost in there.
(the designers have made that simple which i loved :D)
- The speaker is huge, and the panel have alot of (beautifully designed) fasteners waiting to poke it.
- The handle has pins for alignment and securing, the previous' owner mechanics made sure to ruing all of them, be gently when pressing it back into its location.
pictures of removing the mirror to replace or fix, and changing the courtesy light is available if requested :)
Be the First to Share
    • Anything Goes Contest
    11 Comments
    The_Friar
    The_Friar
    6 months ago
    This was very helpful when replacing my passenger door wing mirror. For those looking to do that, the interior trim concealing the wing mirror bolts can only be removed once the door card has been removed. It is straightforward to do, just pull the mirror trim away and the three bolts are visible. The only slightly tricky bit was freeing the cable from the cable clip on the door panel. It only unclips once removed from door and needs a hefty tug to pull it out.
    It isn't necessary to detach the cables preventing the panel from being pulled out further from the door, as in the last 8 paragraphs of step 2. Once the panel has been unhooked and lowered you have full access to remove the interior mirror trim panel.
    When replacing the mirror, locate the top side first, making sure that the window rubber seal lies over the mirror mounting trim panel. (If you locate the bottom first, you will never get the window seal above the trim panel).
    MichalL16
    MichalL16
    Question 3 years ago on Introduction
    Hi, thats very helpfull but would you be able to help where to buy handle for UK right hand drive Skoda I look everywhere and I can't find it :(
    MichalL16
    MichalL16
    Answer 3 years ago
    Picture for msg
    ajh1949
    ajh1949
    5 years ago
    Could you please send me the instructions for removing the drivers door mirror on my 2013 superb?
    ukba7867
    ukba7867
    6 years ago
    Sorry its hashem
    ukba7867
    ukba7867
    6 years ago
    Please can you provide me Step by step instruction on how to change front interior door handle for Skoda superb. The chrome lever (interior handle) got snapped. I got the part but I don't know how to change. A video or Ste by Ste image will be of a great help. Thanks Hesham. The above image of removing door panel is simply superb
    Ussss
    Ussss
    7 years ago
    ....and yes, please post the other guides Hashem.
    Ussss
    Ussss
    7 years ago
    Fantastic guide. We have a CR170 MKII (and a MKI too!) and we love it and this may come in handy in the future. Thank you Hashem!!!
    livichris
    livichris
    7 years ago
    I have a Superb and love it - great car. Gonna save this for future reference. thanks
    Hashem_Mehyar
    Hashem_Mehyar
    Reply 7 years ago
    It is an awesome car ! let me know if you need anything regarding it :)
