Introduction: π Bug in Circuit: Learn Debugging With This IoT Relay Board
π Introduction
Build, break, debug, and learn β all in one kit!
The Bug in Circuit is an IoT-based ESP32 relay board for students, makers, and educators. But there's a twist β the board comes with a built-in fault. You must find and fix it using real-world debugging techniques like continuity testing and logic tracing before making it work.
It's not just plug-and-play. It's plug, probe, patch, program β and then play.
Perfect for engineering students, IoT learners, and anyone who loves solving real problems.
Bug in Circuit IoT Relay Board (2 / 4 / 6 Channel Variant)
ESP32 (pre-soldered)
USB Cable for programming
Multimeter
Jumper wires
5V DC power supply (or USB)
Arduino IDE (Installed)
Arduino IoT Cloud account (optional)
Breadboard (optional but helpful)
Step 1: Understanding the Bugged Relay Board
This is no ordinary relay board. The Bug in Circuit board includes a subtle issue β maybe an open trace, a missing jumper, or misrouted signal.
Your first challenge:
- Power the board via USB or 5V terminal.
- Use a multimeter in continuity mode.
- Trace logic and power paths.
- Spot the fault and fix it!
The goal is to simulate real-life engineering debug situations in a safe, educational way.
Step 2: Fixing the Circuit
Once you've found the bug, it's time to patch it!
Common fixes might include:
- Adding a jumper wire
- Soldering a small patch
- Bypassing a track
After fixing:
- Use a simple multimeter check to confirm relay switching path is now closed.
- Proceed to test your relay circuit manually with GPIOs.
Step 3: Programming the ESP32
Now that the circuit is fixed, it's time to upload your first sketch:
- Use Arduino IDE.
- Select βESP32 Dev Moduleβ as the board.
- Flash the code and observe relay click.
π§ Update the GPIO pin numbers based on your actual relay input pins.
Step 4: IoT Cloud Control (Optional)
Want to make it smarter? Use Arduino IoT Cloud to control relays from your phone or Alexa.
- Sign in at Arduino IoT Cloud
- Add your ESP32 board.
- Create variables like Relay1, Relay2.
- Upload the cloud sketch.
- Test switching from the dashboard or link Alexa/Google.
Step 5: Kit Variants Available
Choose the difficulty level:
- 2-Channel Relay Board β Beginner-friendly
- 4-Channel Relay Board β Intermediate
- 6-Channel Relay Board β Includes onboard SMPS for 230V input
Each variant features a different βbugβ to fix!
Step 6: Learning Outcomes
With this kit, youβll learn:
- Circuit tracing with multimeter
- Relay working principles
- ESP32 programming with GPIOs
- Debugging faulty circuits
- IoT cloud integration
This is not just another projectβitβs a real experience.
Step 7: Why It Matters
Debugging is a vital skill in electronics. Unlike kits that work out-of-the-box, Bug in Circuit makes you think, test, fail, and succeed β just like real engineers do every day.
Itβs more than a project. Itβs preparation for the real world.
