Introduction: ( CPS ) CAP PHONE STAND
compiled by::::Moksham,
today in this project you can learn to make a wonderful cap phone holder ..now if you are wondering why would need a cap phone stand. here are some reasons which might help you think over it..
1:- now if u are travelling and u want to watch a movie on your mobile but u also want to relax and don't wish to hold your phone then this cap phone stand will shore fill your need.
2:- u can also play games while wearing the cps ( cap phone stand )...
Step 1: Materials
1 : a cap
2 : hot glue gun
3 : an empty cardboard tube
4 : empty tape roll
5 : blade
6 : a marker
7 ; screw driver
Step 2: Measurements
first of all measure the length of the caps flap..
my cap measures up-to 7 cm...now take your scale and place it near to the empty cardboard tube and measure 7 cm and put a mark on it.as shown above..
now again from the marked spot measure 7 cm .
and now again from the last marked point measure 3 cm .. as shown above..
when its already like the above picture cut it..
Step 3: Making the Holder of the Phone Stand
now place the tube sideways and place the scale more than half (lets take it 80 % ) and mark them.as shown in the fig ..
now draw two rough lines from the marked two dots to the other side as shown above.
now cut the 3 cm as shown in the pictures but don't cut more then the circle line .. note : cut the rough line that u just made.now to make it a little bigger use the screw driver and push it inside the cut of the cardboard tube. if there is any problem in the lines above that u can't understand just follow the pictures ..
now when u r done till the pictures above do the exact same thing on the other side of the tube(7 cm s side)(note :: when it is all finished the 3 cm area will be cut and the 7 cm area will be cut but the 7 cm in the middle should not be cut...only the two side ends of the cardboard tube...)
Step 4: Making the Phone Stand
now take the empty tape rolls and measure more than half as u did before in the cardboard tube(remember to measure as 80 % ). now when u have marked the edges draw two straight line starting from each end ,, as shown above.and cut it out...
now as u may have noticed that one piece would be bigger and the other would be smaller ,, now take the bigger piece and insert it inside the 3 cm area of the tube.when it reaches the end of the cut glue it with the help of the hot glue gun..
Step 5: Making Earphone/headphone Holder
now take the 7 cm side of the tube and insert the cap flap inside the cut made into the cardboard tube on the 7 cm s side. as shown above.after u are done drop some glue on the second (middle) 7 cm piece.at last take the left out smaller piece of the tape roll and place it above the glue to paste it there..
Step 6: THE FINESHED "CPS"
all the above pictures shows how does your finished cps looks like, how to put your phone in the phone stand,how does the earphone / headphone holder works, and the final looks of the "CPS"..
hope this project was helpful to u .. best of luck .. enjoy..
