Introduction: 🐻 Crochet Overall Dress 🐻
About: I'm a 14 year old girl that loves doing crafts mostly sketching, sewing, and crocheting.
Have you ever had those moments when you go ✨ I could make that ✨? That was basically my thought process when I saw a cute dress on Pinterest. It wasn't crocheted, but nonetheless I was obsessed. This pattern is easy and can be done over a weekend or two. I hope you have a fun time making it! Let's get crocheting!
~ 4 skeins of Tan Yarn
~ 1 skein of Dark Brown Yarn
~ 4.25 Crochet Hook
~ Large Darning Needle
~ Two 9 mm Toy Eyes
~ Basic Crochet Knowledge
~ Waist Measurement
Step 1: Abbreviations
Term - Abbreviation
Rd - Round
Stitch - ST
Slip Knot - SLP KT
Slip Stitch - SLP ST
Chain Stitch - CH
Single Crochet -SC
Half Double Crochet - HDC
Double Crochet - DC
Increase - INC
Half Double Crochet Decrease -HDC2TOG
Step 2: Skirt
Make a SLP KT with Tan yarn and your 4.25 mm hook.
Rd 1: CH until it fits around your waist comfortably. Mind the stretch
SLP ST into the first CH
Rd 2 - 7: HDC into each ST, making sure to SLP ST into the beginning ST before starting a new Rd
Mark the sides of the skirt (Reference Picture 4)
Rd 8 - 12: HDC in every ST, INC in the marked stitches
Rd 13 + 14: INC in first ST (continue to increase in marker stitches )
Rd 15: No more INC in the marker stitches, HDC in every ST
Rd 16 - 41: HDC in every ST
Tie off
Step 3: Waistband
Make a SLP KT with Dark Brown yarn and 4.5 mm hook
Rd 1: CH 6
Rd 2: Starting with the 2nd chain from the hook, HDC in each CH, CH 1 and turn
Rd 3: HDC in each ST
Repeat Rd 3 until it fits your waist
SLP ST the ends together
Tie off
Step 4: Top Front
Make a SLP KT with Tan yarn and 4.5 mm hook
Rd 1: CH half of your waist measurement
Rd 2: HDC in each ST starting with the 2nd Ch from the hook
Rd 3 - 11: HDC in each ST
Rd 12 + 13: 4 SC, DC until last 4 ST, 4 SC
Rd 14: insert hook into 5th ST, HDC until last 5 ST, SLP ST
Rd 15 - 21: HDC in each ST
Tie Off
Step 5: Top Back
Rd 1: CH half of waist measurement
Rd 2 - 13: HDC in each ST
Tie Off
Step 6: Pockets
Rd 1: CH 16
Rd 2 - 10: HDC into each ST
Switch to Dark Brown yarn
Rd 11: HDC in each ST
Tie Off
Step 7: Bear Applique
Make a magic circle of 6 ST with Dark Brown yarn and 4.5 mm hook
Rd 1+ 2: INC (Double Crochet Stitch) in every ST
Rd 3: 6 HDC , SLP ST , 4 DC in the same ST , SLP ST , 4 HDC , SLP ST , 4 DC in same ST , SLP ST , 6 HDC , skip 1ST , SLP ST into last ST.
Tie off
Make a magic circle of 6 ST with Tan yarn and 4.5 mm hook
INC (HDC) in every ST
Tie off
Sew the Tan magic circle on the Dark Brown circle with Tan yarn on your needle ( reference picture 9 and 10 )
To sew a nose, have Dark Brown yarn on your darning needle. Insert your needle from the back of the applique. Skip 1 ST and insert your hook into the next ST, pull through. Repeat this again. Cut yarn and tie ends.
Insert 9 mm toy eyes above the nose and 5 ST apart.
Step 8: Shoulder Straps
Rd 1: CH 8
Rd 2: Starting in 2nd CH, HDC in each ST, CH 1
Rd 3: In back loop only, HDC in each ST
Repeat Rd 3 until it fits from the top of the dress, over your shoulders, to the back of the dress.
*Try on the dress to get the best fit.
Tie off
Step 9: Assembly
Sew with tan yarn and darning needle
Sew/SLP ST top pieces right sides together.
Sew with Dark Brown yarn and darning needle
Sew/SLP ST the top to the waistband, wrong sides facing you (inside out).
Sew/SLP ST the skirt to the top, wrong sides facing you.
Sew the bear applique to the top. I placed mine in the middle (or at least tried to).
Sew the straps to the top, one side in the front and the end in the back.
Sew the pocket onto the skirt. I placed mine to the right and 14 rows from the waistband.
Hide ends
Step 10: Finale
And you're done! Give yourself a pat on the back and flex your new creation!
