Introduction: ๐ŸŒธ Crochet Puff-Flower Vest ๐ŸŒธ
About: I'm a 14 year old girl that loves doing crafts mostly sketching, sewing, and crocheting.
Like many others, my Pinterest feed has been flooded with puff flowers recently. I never thought to do anything with them, however I realized that they are a fun way to upgrade the typical vest and add a bit of color! In this tutorial I will show you how to crochet a vest using puff flowers. So grab your hook and let's get crocheting!
You will need:
~ yarn (in the colors fern, daylily pink, lavender, light blue, butter, tangerine splash, off white)
~ 3.75 mm crochet hook
~ large yarn needle
~ scissors
~ basic crochet stitch knowledge
~ basic sewing knowledge
Optional:
~ stitch holders/pins
Step 1: Abbreviations
These are the abbreviations I will be using in this tutorial. Be sure to reference these as needed.
Step 2: Crocheting the Flowers
Take your 3.75 mm crochet hook and your off white yarn
Round 1: Create a magic ring with 12 sc inside
Switch to colored yarn
Round 2: Insert hook into any st. Pull colored yarn through and ch 3.
Yarn over and insert hook into the same st. Pull yarn through.
Yarn over and insert hook into the next st. Pull yarn through.
Now you should have 11 loops on your hook.
Yarn over and pull through all of the loops. Ch 2 and slp st into the next st.
Now you have completed one petal! Only 5 more to go.
Repeat Round 2 until you have 6 petals. After you have slp st into the next st, ch 1 and tie off.
Hooray! You've finished one flower! In order to complete a vest, we will need 163 flowers, which sounds like a lot!
However as you have seen, these flowers are super quick and easy to make.
Repeat Rounds 1 and 2 until you have:
27 Pink Flowers | 27 Orange Flowers | 28 Yellow Flowers | 26 Green Flowers | 28 Blue Flowers | 27 Purple Flowers
or a total of 163 flowers.
Step 3: Sewing the Flowers - Front Panel
Materials for this section: large yarn needle or crochet hook | colored yarn
Congrats on completing 163 flowers! Give yourself a pat on the back. Now we can move onto the sewing part.
Begin by setting up your flowers in the pattern shown above. Feel free to set up the color combinations any way you'd like.
Sew or slp st the flowers in place. Take two flowers and place them right sides together. Only sew two petals together.
Take a third flower and set it below the other two. Reference photo (7). Sew the flower in place following the natural ridges of the petals.
Once you have completed the trios of flowers, sew them together to form rows. Reference photo (1 + 11)
Sew the rows together to finish the front panel.
Step 4: Sewing the Flowers - Back Panel
The back panel is more or less the same as the front panel, so you're already halfway there.
Layout the flowers as shown in the picture above. Sew the flowers in trios. Then stitch the trios to form rows. Sew the rows together to complete the back panel.
Step 5: Assemble Panels
Materials for this section: large yarn needle | colored yarn
Now that the front panel and back panel have been finished, we can assemble the vest.
Lay the panels right side up adjacent to each other. Follow the petals ridges and sew 4 rows together.
(Reference photo) Cut and tie off.
Flip the panels right sides facing each other and sew the other side seam. Remember to only sew 4 rows. Cut and tie off.
Sew the shoulder seams following the petals' curves.
Step 6: Waistband Ribbing
Materials for the section: off-white yarn | 3.75 mm crochet hook
First we will be starting off with the waistband ribbing.
Round 1: ch 11
Round 2: hdc in each st starting with the second ch from the hook
Round 3: ch 1 and turn, hdc in each st
Repeat Round 3 until the waistband fits around your waist comfortably.
Once you have reached your desired length, take the two ends of the waistband and slp st right sides together.
Cut and tie off.
I used pins to secure the waistband in place while I was sewing. However this is optional.
Make sure that the middle of the waistband aligns with the middle of the vest.
Stitch the waistband to the bottom of the flower vest, gathering the flowers slightly as you sew. Cut and tie off.
Step 7: Sleeve Ribbing
Next we will be doing the sleeve ribbing.
Round 1: Ch 8
Round 2: Sc in each st starting with the second ch from the hook
Round 3: Slp st into the shoulder seam (facing out) of the flower vest. slp st into the next st of the flower and ch 1
Round 4: Turn your work and sc in each st of the ribbing, ch 1
Round 5: Turn your work and sc in each st of the ribbing. Slp st twice into the flower adjacent to the ribbing
Do not slp st into the same st.
Repeat Round 4 and 5 until you have returned to the shoulder seam.
Slp st the ends of the ribbing right sides together. Cut and tie off.
Repeat this for the other sleeve
Step 8: Neckline Ribbing
Finally we will complete the neckline ribbing. This is exactly like the sleeve ribbing but with less stitches.
Round 1: Ch 6
Round 2: Starting with the second ch from the hook, sc in each st
Round 3: Slp st into the shoulder seam facing into the flower vest. Slp st into the next st and ch 1
Repeat Round 4 and 5 until you have returned to the beginning of the ribbing.
Slp st the ribbing ends right sides together. Cut and tie off.
Step 9: Grand Finale
Sew in some of those loose ends and hooray! You've finished! Take a moment to take in your beautiful puff-flower vest.
I hope you have had a blast creating this colorful summer project. Thanks for reading!
