Introduction: ⚡ How to Auto Change 220W Mini Inverter When Electricity Is Gone | Auto Load Turn-On System
Are you tired of manually switching to backup when the power goes out?
Looking for a smart, automatic system that powers your mini inverter, WiFi router, or DC appliances when electricity fails?
This blog shows you how to build a Mini DC IPS Auto Load Changeover Circuit that:
- Automatically switches from AC adapter to battery when power cuts
- Turns on your load instantly without delay
- Works for inverters up to 220W and other 12V devices
Let’s dive in! 👇
Components List (Serial-Wise)
- Relay – SRD-05VDC-SL-C (5V SPDT Relay)
- Diode D1 – 1N4007 (Relay coil protection)
- Diode D2 – 6A10 (High current reverse protection)
- Resistor R1 – 1kΩ (for LED2 – Power Indicator)
- Resistor R2 – 1kΩ (for LED1 – Battery Indicator)
- Resistor R3 – 1kΩ (for LED3 – NO Mode Indicator)
- LED1 – 5mm Red LED (Battery mode – NC)
- LED2 – 5mm Red LED (Power adapter indicator)
- LED3 – 5mm Red LED (NO Mode Active)
- DC Power Socket – 5.5mm barrel jack (12V Adapter)
- Battery Connector – 2-pin terminal block (12V Battery)
- NC Output Connector – 2-pin terminal block (Battery Load)
- NO Output Connector – 2-pin terminal block (Adapter Load)
- PCB or Breadboard – Assembly base
- Jumper Wires – For connections
Step 1: 🧠 Circuit Working Principle
Discover Easy, Affordable, and Reliable PCB manufacturing with JLCPCB!Register to get $70 New customer coupons:https://jlcpcb.com/?from=EST
Special Deal: Get a $30 coupon for JLCPCB premium 6-layer PCBs: https://jlcpcb.com/6-layer-pcb?from=getcoupon
This system uses a 5V relay to detect whether the 12V adapter is providing power. When electricity is available:
- Relay coil is energized
- Load is connected to the adapter via the Normally Open (NO) contact
- When electricity is gone:
- Relay becomes de-energized
- Load automatically switches to battery power via the Normally Closed (NC) contact
This transition is instant and automatic with no switch needed.
Step 2: 🔄 Detailed Circuit Diagram Explanation
At the heart of the system is a 5V SPDT Relay (SRD-05VDC-SL-C), which acts as a smart switch between two power sources — a 12V DC adapter and a 12V battery. The adapter's 12V line powers the relay coil (between Pin 2 and Pin 5), which switches the load from battery (NC) to adapter (NO) when energized.
A 1N4007 diode (D1) is placed across the relay coil to prevent voltage spikes when switching, protecting the relay from damage. Another high-current 6A10 diode (D2) is placed in series with the adapter line to prevent back current and reverse polarity issues.
When the adapter is powered:
- The relay is energized
- Common contact (Pin 3) connects to NO (Pin 1)
- Load receives power from the adapter
When the adapter fails:
- The relay de-energizes
- Common contact switches to NC (Pin 4)
- Load is powered from the battery instantly
There are 3 LED indicators:
- LED2 shows adapter (power) status
- LED1 shows battery mode (NC active)
- LED3 shows NO mode (adapter powering the load)
Each LED is in series with a 1kΩ resistor for current limiting.
Step 3: 🔋 Real-Life Use Case
Suppose you're running a 220W mini inverter, WiFi router, or LED light system.
✅ When electricity is ON → Load runs via adapter
✅ When electricity fails → Load switches instantly to battery
✅ No user action, no flicker, no downtime
Perfect for:
- WiFi Routers
- Smart Home Devices
- Mini Inverters
- Microcontroller Boards (Arduino, ESP, etc.)
Step 4: 🎥 YouTube Video Overview
🔌 Auto Load Switch Circuit for 12V DC Devices 🔋
🔧 Live Load Test
🔋 Works with Mini Inverter, Router
📡 Automatic Switchover System
📍 Subscribe: EST Experiments
Step 5: 📝 Final Thoughts
This Auto Load Changeover System is simple, cost-effective, and powerful. It guarantees uninterrupted power for essential devices using a basic relay and few components.
Whether you're a DIYer, student, or electronics enthusiast, this circuit is a must-have tool for your home backup setup.
