Introduction: ๐ŸŽฎ How to Install Batocera on Orange Pi Zero 3 and Zero 2W
About: Learn and Apply to real life
Looking to turn your compact Orange Pi board into a retro gaming console? Batocera is a lightweight Linux-based operating system designed for retro gaming emulation โ€” and now it runs well on small boards like the Orange Pi Zero 3 and Orange Pi Zero 2W.
In this guide, I'll walk you through how to install Batocera, configure it, and start playing your favorite retro games.
What Youโ€™ll Need
  1. Orange Pi Zero 3 or Orange Pi Zero 2W
  2. MicroSD card (16GB or more recommended)
  3. Power supply (5V/2A, via USB-C or micro-USB)
  4. HDMI adapter (for Zero 3, use USB-C to HDMI or expansion board)
  5. USB keyboard/gamepad
  6. Wi-Fi network
  7. Computer to flash the image
Step 1: Download the Batocera Image
Batocera now supports the Orange Pi Zero 3 and Zero 2W with test or community builds.
  1. Visit: https://mirrors.o2switch.fr/batocera/orangepi-zero3/stable/rc/
  2. Download the latest .img file available for your board.
โœ… Note: The image for Zero 3 generally works on the Zero 2W due to similar Allwinner SoC architecture.
Step 2: Flash the SD Card
Download: https://balena.io/etcher
Open Etcher
Click โ€œFlash from fileโ€ โ†’ select Batocera .img
Select your SD card โ†’ click โ€œFlash!โ€
Step 3: Boot Up Batocera
Insert the flashed SD card into your Orange Pi.
Connect it to a display, keyboard, and controller.
Power it on.
Batocera should boot automatically โ€” the splash screen and UI will load after a few seconds.
Step 4: Set Up Wi-Fi
Use your keyboard to navigate to the Main Menu > Network Settings
Enter your Wi-Fi network name and password.
Wait for it to connect โ€” now you're online and ready for updates or scraping metadata.
Step 5: Add Games
Once Batocera is connected to Wi-Fi or Ethernet, it gets a local IP address on your network.
๐Ÿ–ฅ๏ธ To Find Your Local IP in Batocera:
  1. From the Batocera main menu, go to:
  2. Main Menu > Network Settings
  3. Look for the line labeled "IP Address"
  4. It will look something like: 192.168.1.105 or 192.168.0.123
โœ๏ธ Write down this IP address! You'll use it to connect from your PC or Mac.
๐Ÿ—‚๏ธ Access Batocera File System from Your Computer
๐Ÿ’ป On Windows:
  1. Open File Explorer.
  2. In the address bar, type:
  3. \\192.168.x.x (replace with your actual IP)
  4. Press Enter โ€” you should see Batocera's shared folders (roms, bios, etc.)
๐Ÿ On macOS:
  1. In Finder, press Cmd + K
  2. Type:
  3. smb://192.168.x.x
  4. Connect, and browse the shared folders.
๐Ÿ“ What You Can Do via Network Access:
  1. Copy ROMs to appropriate system folders (/roms/nes, /roms/snes, etc.)
  2. Upload missing BIOS files to /bios
  3. Change or upload custom themes under /userdata/themes
Step 6: Performance & Tips
  1. Performance: Smooth for NES, SNES, GBA, Genesis. N64 and PSP may struggle.
  2. Cooling: These small boards can overheat. Use a small heatsink or case with passive airflow.
  3. Bluetooth: Zero 2W Bluetooth generally works better but Wi-Fi limit distance
  4. you should turn off wifi if you use speaker bluetooth. Expect add game
Step 7: โ— Known Issues
  1. Some PS1 games lag
  2. Audio out may require HDMI or specific settings
  3. Bluetooth pairing slower but work
Step 8: Final Thoughts
Using Batocera on the Orange Pi Zero 3 or 2W is an awesome way to repurpose small SBCs for retro gaming โ€” and itโ€™s entirely open-source. Performance wonโ€™t rival a Pi 5, but itโ€™s a fun and cost-effective project, especially for emulating older 8/16-bit systems.
If you're looking for a cheap, compact, and silent emulation box โ€” this is a great weekend project.
Step 9: Credit
reddit:click me
