Introduction: ⚔ Robot (Monster) Fight With Cadboard
Hello! This is a walking and running frog robot
Robot has only one eye.
A robot is easy to do.
It is especially loved by children.
It looks very funny and interesting
I hope you like it. If you like it. Please vote for me
Thanks. Let's make it :))
Note : You can watch the video to understand the steps to do!
Step 1: You Need
👉 You need:
- Cardboard
- Ice-cream stick
- BBQ bamboo stick
- On/Off Switch
- 9V Battery & Battery Connector
👉 Cardboard Measurement:
(cm = centimeter)
Triangle : 15cm x 7.5cm = 4 Pieces
15cm x 7.5cm = 1 Pieces
15,5cm x 7,5cm = 2 Pieces
Circle R = 2.5cm = 2 Pieces
R = 1cm = 1 Pieces
Step 2: Prepare
Prepare a cardboard sheet, pens, paper knives and rulers
Draw a triangle whose hypotenuse is 15 cm and the other side 7.5cm
Step 3: CUT
After you're done drawing, cut it
You need to make 4 such triangles
Step 4: Prepare a Rectangular Cadboard 15cm X 7,5cm
Place a rectangular cover of 15cm x 7.5cm
Place the triangle cardboard on the rectangular cardboard
And permanent it with hot Glue
Step 5: Draw Circle
Draw two circles with a radius of 2.5 cm
And a circle with a radius of 1.5cm
And Combining to create gears ( Fourth Photo)
Step 6: Make Small Holes
Make small holes to oblique the toothpicks
Put the gear and a rubber band in
Step 7: Use a Small Plumbing
Use a small plumbing
You need to make it for the remaining toothpicks
Step 8: Prepare 6 Ice Cream Sticks
Prepare 6 ice cream sticks with a length of 4.5 cm
Create 2 holes at the 2 ends ( Second Photo)
Step 9: Mechanism of Action
Mechanism of action (first image and second image)
Attach operation mechanism to the robot
Step 10: Attention
Pay attention to the direction my hand is rotating (first image)
Hand to rotate the left and right will be opposite
The operating mechanism of the two robot sides must be different. if the other side turns left then this side has to turn right
NOTE: You should watch the Video to better understand (Stating from the 3rd minute 03:24 - 03:52)
Step 11: 2 Remaining Cardboard Sheets
2 remaining cardboard sheets
Mark the touch point ( Second Photo)
And Attach frog legs ( Third Photo)
Step 12: Use Motor and Two Small Gears
Use motor and two small gears
Look closely at the electrical circuit diagram for assembly
Please make sure to connect the power cord firmly to avoid rework
Step 13: Prepare Two Cardboard
Prepare two cardboard boxes measuring 15.5cm x 7.5cm and have a hole
Make a moderate hole to place the switch ( Second photo)
Put it all in and take the next step (Third photo)
Connect the elastic band together (Fourth photo)
Step 14: Decorate
The final stage is to decorate it. Please decorate according to your preferences
A sword that can bring humor to a robot, or call it a fighting robot! haha :))
Step 15: Finished Product. Let's See the Finished Product
I hope you like it.
If you like this Robot. Vote to help me. Thank you vary much :)))
Thank you very much. Have a nice day ! :))))
