Introduction: . White R Spiderlamp
handcrafted toy lamp
How to make a lamp and reuse your toys with some accessories,
relive and remodel and light your room..
- Spiderman toy figure
- socket
- Cable for current
- Wheel damper
- light bulb
- screws
- Glue for plastics
- Armellas
- Wood
Step 1: Step 1.
Locate where we will put the light bulb holder and make a hole for the bulb holder to enter or screw in.
Step 2: Step 2
Locate the prototype joints that will be fixed without movement and add a few drops of high strength glue.
Step 3: Step 3
On the back of the prototype insert the eyelets that will be used to hold the power cable and start to introduce the cable.
Step 4: Step 4
Spray the prototype and the cable using a base first and then the color white and take the necessary passes to cover everything well
Step 5: Step 5
Paint the base wood and make the holes at the bottom just below where the prototype feet would go and then screw.
Step 6: Step 6
Stretch the cable along the path through the prototype until you reach the starting point where the light bulb will go, make the necessary connections to make the light bulb works.
Step 7: Step 7
Screw the bulb, connect the cable and turn on. It´s Ready!!
You have a beautiful modern table lamp with your favorite toy.!!
Step 8: Final Step
What a good idea, right? After a few hours of work you have an incredible result like this ... Congratulations you made it !!
