1,000 Year Doghouse
Intro: 1,000 Year Doghouse
Ferrocement is incredibly strong yet inexpensive and easy to build with. In this doghouse, I know my dog will be safe from hurricanes, tornadoes, earthquakes, and small tonnage nuclear detonations.
STEP 1:
Assemble a dense wire mesh in the shape desired. The surface must curve in two planes, as on a sphere or an egg. Flat plane, cylinder, or cone surfaces will not be strong. Use at least 4 layers of hardware cloth and/or chicken wire. The finished wire mesh should be mashed or laced to less than 3/4 inch thick with no holes large enough to stick your little finger through.
STEP 2:
Slap on the concrete, working it thoroughly into the wire mesh, removing all voids. Excess concrete will fall through the mesh to the inside. Scoop it up occasionally and use it on the outside again. When the wire mesh is completely filled and covered, smooth the inside and outside surfaces so the concrete layer is less than 1" thick from inside to outside. Apply all the concrete in one session, to avoid a weak seam between old and new applications. Keep the concrete damp for a week by covering it with wet towels and plastic. (28 days for maximum strength).
STEP 3:
Now Frisky will be safe and secure. When Armageddon comes, I'm heading for the doghouse!
87 Comments
iti 14 years ago
by_rhonda 6 years ago
Here is an excellent article on ferrocement
http://www.engineeringcivil.com/water-proofing-by-ferrocement.html
MelodiousDirge 14 years ago
iti 14 years ago
It needs a sealer of some form. Because the house is curved, therain will run off, but if it rained for a week, it will obsorb thewater, and sooner or later the saturation point will be reached andwater will run through.
It has tiny fractures throughout, over time if not checked, they grow,turning into hairline cracks, then big cracks. Any wire insidewill rust, and expand the cracks more. etc etc.
Sealants are required. Just do a test, try it yourself.
Even cement walls on a house must be sealed on the outside if you wantan fha loan. Why? because they will do the same thing, absorb therain, water from sprinklers and then transfer it to the inside.
And in the case of a sprinkler? It doesnt take days, lol. I tried this one too. It was fun to watch and see that thepattern on the inside was the same as the outside. I nice curve.
MelodiousDirge 9 years ago
Thanks for the LOL, but you missed my point: this is a dog house, not a containment pond or a driveway. It won't leak any more than a clay planter will. Maybe after a few years of freezing and thawing it will have hairline fractures, but this isn't a boat, it's a doghouse. Let's not overcomplicate things, hmm?
clevernonsense 11 years ago
JJG2 9 years ago
The permeability (an cracking) of the cement/concrete depends on the ratio of the mix and the type of binders/fibers/reinforcement used. Also cements include more than the common Portland type that most people think of. Magnesium oxide based cements are far more moisture resistant *and way more expensive on a per lb. basis.
If you want to ENSURE impermeability you will want to use the right ratio of the correct ingredients (including and acrylic latex binder) and then paint or coat with a flexible elastomer paint (like the EPDM paint used on RV roofs now). Over kill perhaps, but a good guarantee.
The cement used in driveways, sidewalks, etc, is only poorly porous, which is why run off from developed areas is an ecological issue. But due to cracking and poor ingredient ratios it also doesn't keep the ground under it dry enough to prevent life forms from living under it...
I love the FidoDome, DomeHead! You did a great job and the Master looks tail-wagging happy! Depending on what area you live in you could probably get by without sealers. With ferrocement/ferroconcrete and the dome shape the most will happen is rain will slowly absorb and then it will follow the path of least resistance. Downhill around the edge. It would be a rarity for it to leak at the top and as long as you don't have to worry about a wet FidoDome freezing then you could probably bypass sealer, but sealer would be a good thing.
glorybe 14 years ago
Maybe this will help
https://en.wikipedia.org/wiki/Ferrocement
cathrynm 10 years ago
dome_head 10 years ago
milesnorth 11 years ago
rawknexstuff 13 years ago
anatole 15 years ago
xd12c 14 years ago
I would like to get/build one, but I don't have the resources :?
cd41 15 years ago
ClayOgre 15 years ago
spark master 14 years ago
Cement structures take time to really dry out and some peolple compain of humidity for several years. I would think in SW USA this could be a lucky good thing, in Manitoba maybe not.
Jest fer fun you could, with a small dome use bottles (blue green or flint) with the ends exposed to the light so internally you have illumination. A design even, say a constellation if it is a shed type building. In a small structure like for the dogs you could make a two layer bottle wall (no tilt, then put your ferro cement screening and maybe 2-3 in a cluster at the top as a skylight. If you use small bottles like mini juice things or ginseng bottles, you could do constellations and being a dog house do , errr do SIRUS, (Cannis Major).
The final coating can vary but the stuff they use to lay ceramic tiles is water proof on drying . Big bro waterproofed an entire basement with it, filled cracks and space too, so it is like hydrocement in that it filled cracks and stayed waterproof (over 10 years, no leaks). When we did the facade onhis bar/club we used it there as well.
It pays to add something to the cement mix that makes it water proof over a final coating of paint which peels. It would be great to paint over it anyway.
A structure as small as this dogigloo might be better made with Struclite and then a finish coat of water proof cement with lotsa bonding agent. Structite is a cement mixture with styfoam and pearlite (perhaps) mixed in. With your wire mesh it should be self supporting and will be cooler in summer warmer in winter.
seeya in the funny papers
jamiebeau 14 years ago
