Introduction: 1, 2, 3, Metal Detector
In this Instructable I will show you how to create a very simple, low cost metal detector. This is not the type of large scale metal detector you can use on the beach however; this can be used for finding where two studs in your walls meet (aka locating the nails), a lost screw, screws, or just simply fooling around testing different objects around the house.
Materials
-a 9 volt battery
-9 volt battery connector
-a LED (any color)
-a switch
- a resistor 100 ohm -/+5% color bands are: brown, black, brown (needed for the 1.5v LED)
-and of course a metal sensor. I got mine from SunX.com, but you can try a number of different robot part sites or electronic components suppliers. try and get one with a LED built in that way you can see if the metal detector works when it touches metal.
OK lets get started!
Also don't forget to visit the site!
http://www.wix.com/SimpleCircuits/Simple-Circuits
Materials
-a 9 volt battery
-a LED (any color)
-a switch
Step 1: The Circuit
The circuit is very simple. For assembly please follow the provided circuit diagram. Remember that the LED and metal Detector are polarity sensitive. I ask you strongly to test each component before soldering them all together.
Step 2: Test
flick the switch or hold it down, depending on what type you used. hold the detector to some metal and if the light inside lights up, its metal!
the LED is simply to let you know there is power going to the metal detector.
A video of the metal detector in action
