Introduction: 10 Basic Arduino Projects for Beginners! Make at Least 15 Projects With a Single Board!
Arduino Project & Tutorial Board;
- Includes 10 basic Arduino projects.
- All source codes, the Gerber file and more.
- No SMD! Easy soldering for everyone.
- Easy removable and replaceable components.
- You can make at least 15 projects with a single board.
Step 1: Video Tutorial & Project List
See how it works! You can see all the steps of this project in this video.
- Enable the Buzzer and LED with the LDR
- Control the RGB LED with Potentiometers
- Play Ringtone with Buzzer and Button
- Enable the Buzzer and LED with the PIR
- Control the RGB LED with IR Remote
- Control the Servo Motor with IR Remote
- Control Multiple Servo with Potentiometer
- Humidity and Temperature indicator with DHT
- Temperature indicator with LM35 and OLED
- Control Multiple Servo via Bluetooth Slider App
Step 2: Required Hardware:
1x Nano V3 Board - http://bit.ly/2MHVDYi
1x Bluetooth Module - http://bit.ly/2D735b0
1x PIR Motion - http://bit.ly/2WAenxz
1x OLED I2C - http://bit.ly/2HIhQqf
1x DHT11 - http://bit.ly/2sZG84T
1x LM35 - http://bit.ly/2TsCvA6
1x LDR - http://bit.ly/2MPatwo
1x IR Infrared - http://bit.ly/2TpVBH3
1x RGB Module - http://bit.ly/2BfFzZc
1x Buzzer - http://bit.ly/2Soa0X2
2x Potentiometer - http://bit.ly/2GeU4zQ
2x Potentiometer Knob - http://bit.ly/2DOijDw
2x Push-Button - http://bit.ly/2Wx1xjL
Female Header - http://bit.ly/2MJtnVm
Resistor Kit - http://bit.ly/2GlmUil
Optional Equipment:
Soldering Tool Kit - http://bit.ly/2D6YbuC
Soldering Stand - http://bit.ly/2RuweC9
Wire Cable Cutter - http://bit.ly/2P5FJXA
Step 3: Download Gerber File & Order PCB
- Download the Gerber (PCB design) file.
- Go to https://www.pcbway.com/ (I explained why I selected the "PCBWay service" below.)
- Click "Quote & Order"
- Only a few information will be entered in the "PCB specifications" field. All other settings will be default.
- PCB Size: 114 x 91 mm
- Quantity (minimum) : 5pcs
- Layers: 2 Layers
- Solder Mask (PCB Color): Green
- Silkscreen (Text Color): White
- Under "Surface Finish" selection: Yes
- Click "Calculate"
- Build Time : 1-2 days / Qty: 5 / PCB Cost: $27
- You can select any Shipping Way
- Click "Add to Cart"
- Upload the Gerber file
- Wait review (All your orders will be receiving a free engineering file review service from PCBWay trained and professional technicians before you pay in the most timely manner.)
Why PCBWay?
- When things go wrong, they are always extremely helpful.
- They actually tested every single board at no extra cost.
- Quality. I've never been disappointed.
- No hidden fees. What you pay is what you see in the invoice.
- You may order minimum 5pcs PCB.
- Suitable for many customers who are price-sensitive like students, hobbyists and makers.
- You may choose DHL and other courier services for the balance of speed and budget.
- You will get extremely prompt responses via emails and chat during working hours.
Bonus: Get $5 New User Free Credit
Step 4: Soldering
- No SMD soldering! Easy soldering for students, teachers, hobbyists and makers.
- All component names and locations marked on the PCB.
Step 5: Assembly
- All component locations are specific on PCB.
- All components are connected to separate pins. Therefore, each component can communicate with one another at the same time.
- Do not forget to remove the Bluetooth Module when uploading code!
Step 6: 10 Basic Arduino Projects for Beginners!
- Temperature indicator with LM35 and OLEDControl
- Multiple Servo via Bluetooth Slider App
Download: http://bit.ly/2Bf67tH
- All source code
- All required libraries
- All pin numbers to which the components are connected
Important: Don't forget to remove the Bluetooth Module when uploading code!
