Introduction: 10-Minute Buttons With Indicator
Perfectly simple Buttons for quick DIY Projects from spare Parts everyone has.
3D Printer
Soldering Iron
Standart Round 5mm Led
Standart Button 5x5mm
Standart Resistor 10k for the Led (quite high)
Step 1: 3D-Print
The fit comes out perfectly on a Prusa, no glue or plastic soldering required. Here are the files for using:
Step 2:
While the case is printing its time to solder. Just cut a perfboard, add the components, solder ground together and one pin to one button or led. Its best to use thin wires that there is enough space. Sorry i don't have a schematic.
Step 3:
Assembling. Just put the 3 parts together and connect it to some Project. The left pin at the controller is GROUND. After that there are the 3 buttons as expected and then the Led which can handle 5V due to the resister. The buttons need a Pull-Up Resistor which can be mostly internal in the MCU.
