Introduction: 10 Simple Lifehacks With WD-40
Step 1: Light a Fire in a Rain or Any Wet Contitions
WD-40 is very flammable. you can youse it as a fire starter.
Step 2: Remove Grease or Wax From Any Surface
You can use WD-40 to remove your kids crayon drawings from any surface, it's very easy
Step 3: Get a Pice of Gum Off the Carpet
If you step on a gum on your favourite carpet, no problem. You can separate it from the carpet with some WD-40. Same method works if the gum stuck in your hair.
Step 4: Remove Stains
WD-40 is a good stain remover. If you spill some ketchup on your carpet. No problem. Soak the stain for 5 minutes with wd-40 and the stain will be easy to remove.
Step 5: Cut Through Stuff Easily
lublicate your scissors and they will easily cut trough tough stuff
Step 6: Clean and Waterproof Your Leather Shoes
Step 7: Clean Stainless Steel Apliences
Step 8: Remove Stuck Dirt, Rust or Glue
Clean up your stove from those dry and hard to remove spills.
Step 9: Got a Tight Zipper
Lubricate your metal zippers for a smooth motion
Step 10: Remove Stikers
Step 11: Subscribe to My YouTube Channel =)
Subscribe to my YouTube channel for more cool tips like this!
