100 Kazooz in My Pocket
Intro: 100 Kazooz in My Pocket
Can You Make
An instrument anyone can play?
Maybe.
An instrument small enough to fit in your pocket?
Not impossible.
An instrument so small that you can fit enough in your pocket for all of your friends, their friends, chance acquaintances and any bystanders?
Now you're getting silly.
Of course, that's the sort of instrument it is.
Maybe.
Not impossible.
STEP 1: Materials and Tools
With just a few readily available materials and tools you can make hundreds of pocket kazooz, quickly and easily.
Light weight cardboard.
I will including a picture that you can print out on 8 1/2 x 11 inch cardstock to make 20 kazooz, but you can use almost any light weight scrap cardboard (cereal boxes, shirt boxes, business cards, greeting cards, incomplete deck of playing cards, the heavier weight junk mail, etc., etc., etc. )
Ordinary lightweight disposable plastic grocery bag--Actually not just the ones from grocery stores-- from Walmart, KMart, Walgreens, Target, etc--but not the heavy plastic ones.
I have never tried counting the number of kazooz you can get from one bag; but it is a LOT.
Rubber Cement --This is the best thing I've found to glue the plastic to the cardboard.
Scissors or craft knife--the only tool you really need.
STEP 2: Step One
Print out the sheet of kazooz on letter size cardstock Sraying the printed side with a fixitive helps prevent the ink from running if it gets damp.
or
Get a scrap piece of card from cereal or other box or etc.
Cut out one the printed kazooz or if using scrap card, cut an approximately 2 inch square.
or
STEP 3: Step Two
Fold the square in half.
Cut a hole about 3/4 inch diameter in the card. Circles are nice, but a diamond shape only takes two cuts with either scissors or knife, so they are a lot quicker.
STEP 4: Step Three
Cut a piece of shopping bag about the size of your square of cardboard. Exactness is not important as long as it is at least 1/2 inch or more larger than the hole.
STEP 5: Step Four
Spread rubber cement around the hole on the unprinted side of the cardstock. Spread thinly, try not to get an excess around the hole or it can sqwish out onto the plastic.
STEP 6: Step Five
Place the plastic square over the hole and press it down smoothly. I find getting it more or less smooth, but not stretched tight, usually works best. The square should still fold fairly easily.
Once dry enough to be stuck firmly in place, trim off the excess plastic (a craft knife works best)
STEP 7: Step Six
Playing your kazoo-- With your mouth a little open, hold the plastic covered side touching your lips. Humm. You can play any tune you can hum.
the sound is controlled by your voice, but can vary some what by
the size (the larger the vibrating membrane area the louder it can be --but if it is very much larger you will need a heavier plastic or try stretching it tighter.)
how loose or tight the membrane is A looser membrane tends to produce more buzz
and amplification.
How to make different types of Kazooz, kazoo history and myths, kazoo design, etc.
For more than most people could possibly want to know about kazooz, go to
groups.yahoo.com/group/Kazooz
and amplification.
21 Comments
motleyjust 12 years ago
https://www.instructables.com/id/Red-White-and-Blue-Pocket-Kazooz/
for pocket kazooz in colors suitable for 4th of July, Memorial Day, Veterans Day, Flag Day, etc.
Make them and hand out to everyone for a holiday concert.
Find more info (than you probably ever wanted to know) about the kazoo at the Yahoo group Kazooz
http://groups.yahoo.com/group/Kazooz/
Puzzledd 13 years ago
I just added another picture to be used on them.
Kiteman 14 years ago
motleyjust 14 years ago
3D Max is a high end program (with corresponding price tag) that does those things
Poser and DAZ Studio are rendering and animation programs, that is you can use to make still pictures or animations using figures and props that were made in some other programs. But you can't really make most models in them, although I have put some models together in Poser using primatives (cubes, shperes, cylendars, etc) like with building blocks.
garrett10 14 years ago
http://www.contentparadise.com/productDetails.aspx?id=640
You can get a trial version here
http://my.smithmicro.com/downloads/index.html
DAZ Studio works pretty much the same as Poser and uses most of the same content.
You can get the basic version for FREE
You can buy DAZ Studio Advanced which has a bunch of extra features . There is a trial version to download and try.
http://www.jdoqocy.com/click-3566892-10669253
DAZ (and a lot of other places) also has a bunch of free stuff that can be used for both programs
http://www.kqzyfj.com/click-3566892-10547366
Poser Figure Artist is very similar to Poser4. You can use the little wooden manikin or the more realistic figures to practice drawing, which was the purpose of the original Poser. You can also use to to create pictures in various styles, from photo realistic to pastel, color pencils, pen and ink, etc. without drawing at all, but I believe it doesn't have a bunch of the newer features, such as the Cloth Room and Face Room.
35% off on Poser Figure Artist by using this link, No Coupon code needed!
http://www.kqzyfj.com/click-3566892-10556110
threadbare 14 years ago
https://www.instructables.com/id/Anti-Boredom-pocket-kit/?comments=all#CFBWCQTFXA2ZORK
AndyGadget 14 years ago
