Introduction: 10Amp VARIABLE POWER SUPPLY
Hello everyone,
I am Amey, welcome to my channel
Today, I am building another cool project which is 10Amp VARIABLE POWER SUPPLY with the help of LM317IC and other electronics part.
So lets' make it
Step 1: COMPONENTS
4 X 10A10 DIODE
1 X LM317(Voltage Regulator)
1 X BD139 Transistor
4 X 2n3055 Transistor
1 X 1000uf Capacitor
2 X 5K ohms potentiometer
1 X 10Amp Fuse
1 X 220ohms Resistor
Heat sink for the 3055 transistor
Step 2: Circuit Diagram
I made the connection as per the Circuit Diagram
I also attracted the PCB file so you can make your own PCB
Step 3: WORKING
As name given "10amp Variable Power Supply", the load can draw up to 10amp form this circuit.
To regulate the voltage I use LM317 which is basically a VOLTAGE REGULATOR which can handle up to1.5 Amp of current, So to handle 10 Amp of current 2n3055 transistors are use which is power transistor with current handling capacity of up to 10 Amp, I use 4 of those(you can use two only simple remove two of the transistor).
All the 2n3055 Transistor are driven by BD139 transistor which is NPN transistor which use to limit the current for the connected load
For safety purpose I added a 10amp fuse to protect the circuit form overload.
At the output I am also adding 1 DIODE and FUSE(Not mention in this project) for reverse voltage protection for charging battery
