Introduction: 2-Channel Thermostat 0-255°C
Hello everyone, in this project I wanna show you how to make 2-Channel Thermostat. This project is based on Atmega 328P(Arduino Uno). My thermostat can measure temperature from 0 to 255 °C on 2 separate channels. In the future I am gonna convert my cnc machine to 3dprinter and use this thermostat to control temperatute of the extruder and the table.
I made video and step by step instruction how to make it.
So, let's go to work :)
Materials:
- Electrocnic parts
- Enclosure box
- Arduino
- Circuit board blanks
Tools:
- Soldering iron
- Tin
- Pliers
- Drill
Step 1: Watch the Video
Video will give you a good overview on how to create such a 2-Channel Thermostat. But the following steps will still contain some extra useful information.
Step 2: About Schematic
Schematic in eagle and pdf file you can download below.
How you can see Thermostat is based on Atmega 328P that same is used in Arduino Uno. Temperature is read from 100K thermistor (0-255°C) . There are 2 thermistors and 2 relays for heaters. Additionally I made two 12V outputs and two free outputs pins from aduino. This pins you can use to make any change in schematic. To power thermostat I used 12v transformer. To control thermostat I made 3 potentiometrs. Two to set temperatures and 1 to adjust hysteresis (from 0 to 9 °C). To set and read all values I used 16x2 LCD blue display.
Step 3: Make PCB
First you have to make PCB board. Template in Pdf and Eagle files to download in previous step. To make pcb I used toner transfer method. It is very easy and gives very good results. When excess of copper is removed, just drill the holes.
Step 4: Soldering Time
Now solder all electronic components to PCB and control board is ready :)
Step 5: Programming
Time to code. To move code to Atmega use this tutorial created by Arduino. I made 2 types of code. First 2-channel thermostat with hysteresis, and second only 1-channel with hysteresis. You can download code below.
Step 6: Encloser Box
To make front panel of box I used cnc machine. There are potentiometers, switches, display, leds and output connector.
Step 7: Assembly Everything Together
Now assembly all parts together. Connect wires. Attach transformer and relays. Screw pcb to bottom of box.
Step 8:
Now your 2-Channel Thermostat is completely finished :)
You did it!
Please subscribe my Youtube channel for more projects :)
Thomas Workshop Youtube channel
If you have any questions leave a comment below :)
