Introduction: Ninja Turtle Car Key
how would you like to have the coolest car keys ever? forget key chains iv got you 1 better. you can but the chip that unlocks your car INSIDE A TOY!!! I used a ninja turtle toy
Step 1: Get the Toy
you need a toy that you like, think is cool, and can fit the chip or your clicker in. I wanted to use a transformer but found a turtle.
Step 2: Lets Play Doctor
if you are not squeamish because next you must open up the toy. some are held closed with a screw and they are ez. mine was melted. so I fount its line of connection and broke it so I could get to his guts
Step 3: Clean Out the Crap
OK when you have got the toy open take out all the objects that may keep you from putting your car lock peace in it. For my toy i just broke the peaces out. it wasent that hard, but be sure not to brake the outside of the toy. if the toy has a peace that holds the 2 sides together keep it and use it to hold ur chip in place.
Step 4: I Need Space!!
the chip must fit in along with its battery. so after u clean out the toy the chip must b cut down to size if it cant fit in. just look at the picture
Step 5: I Like to Move It Ove It
I wanted my toy to still move but I the space issue would not let it work so you could only have 1 movable arm IF!!! I grind him down. the other arm I just glued in place
Step 6: Buttin
how will you click it to lock and unlock? using the back side of your toy mark out where the buttons on the clicker are on the side then drill some holes. I made small holes and used some paper clips to go in the hole and click the buttons
Step 7: Glue
I glued some wires to the buttons so I could click them through the holes on the shell and it worked fine
Step 8: Last 1
put it all together
