Introduction: 200 WATT INVERTER 24V DC TO 220 V AC @ 65KHZ
About: Iam instrumentation and controls professional working in Emirates global aluminium (EGA) located at Dubai. I'm circuit designer and software developer by passion. Whatsapp (+91)9163954390
In this writeup I'm demonstrating 200 W inverter with input voltage 24 V and output voltage 240 V AC with operating frequency of 65KHZ. The circuit is loaded upto 200 Watt.
BILL OF MATERIALS
C1 22PF
Q1 IRF840
Q2 IRF840
Q3 25N120
Q4 25N120
Q5 25N120
Q6 25N120
Q7 25N120
Q8 25N120
Q9 25N120
R1 100K
R2 100K
R3 100K
R4 100K
R5 10K
R6 10K
R7 330E 1W
R8 330E 1W
R9 100E 1W
R10 100E 1W
R11 10K
R12 4.7K
R13 4.7K
R14 1k
R15 1k
R16 4.7k
R17 10K
R18 1K
R19 10K
R20 1K
R21 10K
R22 10K
R23 10K
R24 10K
R25 10K
R26 10K
R27 200WATT 230V LAMP
T1 PULSE TRANSFORMER
T2 MAIN TRANSFORMER
U1 TL494
Step 1: Construction
This circuit is intended to deliver 200W power with 24 V DC input and 240 V ac output.
The circuit uses IC TL494 as an oscillator. The oscillator generates 65 khz.
The output is taken from PIN 9 and 10 and fed to mosfet IRF840. The output drives a pulse transformer. This transformer generates 12 V Ac @ 65Khz
The secondary of pulse transformer is fed to gate of IGBT banks 1 and 2.
The IGBT bank 1 and 2 drives transformer T2. T2 is the main power transformer.
IGBT 1 and 2 are 7 IGBTs in parallel.
The circuit is tested with 200Watt lamp.
Please watch the video for the reference.
Step 2: Transformer Design
Pulse transformer T1
No. of turns in primary = (12*10000000000)/(4*65000*69*1500) = 5
Core area of selected core = 69 sq. mm
Input voltage = 12 V DC.
However in tested circuit supply voltage is 17 V Dc.
Primary and secondary are 5 turns each center tap winding in primary and secondary.
Main Transformer T2
Supply voltage = 24V Dc
No. of turns in primary = (24*10000000000)/(4*65000*228*1500) = 2.69 turns or 3 turns.
For an option of 12 V we need a center tap winding.
Then for a center tap it needs 1.5 turns.
It is difficult to make 1.5 turns , so we make 2 + 2 turns as center tap.
So for 24V DC we have 4 turns (2 +_2 center tap)
Secondary voltage = 220* 1.414 = 325 V
Secondary no. of turns = (325/24)*4 = 54.16 or 54 turns.
so Secondary is 27 + 27 turns center tap winding.
Wire used = 23 SWG. (Current capacity = 0.584 A)
For 200 Watt 200/24 = 8.33 A
No. of conductors secondary= 8.33 A / 0.584 = 14 conductors 23 swg
Primary = 200/220 = 0.909
No. of conducors primary = 0.909 / 0.584 = 1.55 or 2 conductors 23 swg.
Step 3: Conclusion
The circuit involves 220 V AC power. So care must be taken while making.
The circuit may be used as a reference.
