Introduction: 21 Mind Relaxing Zentangle Patterns, How to Draw Tutorial
Well this a Mind Relaxing Zentangle Patterns in a Triangle, this is just with some random imagination and getting it done with time and finally loving the art piece.
I am a hobby artist who loves to make - Doodle, Zentangle, Mandala, Graffiti, Canvas Art
Follow my YouTube channel for more such videos: sarabjeetworld
My Art Instagram: sarabjeet_world
My Personal Instagram: Sarabjeetworld
Well for this project, I used
1- Standard drawing file
2- Micron markers
3- Artline Markers
4- Black sketch pens
5- Scale
6- Graphite pencil.
Step 1: Lets Begin
In this step, I made a Triangle as your can see in the image.
You can make it of any size as per your drawing file.
Step 2: Drawing the Blueprint
Inside the triangle start drawing a straight line from any one point of the the triangle but ending a little higher on the other hand as shown in the picture.
the second line starting point will be the ending point of the previous line.
Step 3: Rough Is Done
Repeating to what is being explained in step 2, in the end you will get the end less paradox type design inside the triangle.
Step 4: Rough to Fair
Its time to fair the rough design, by using a micron pen and doing it fair and rub the pencil design.
Step 5: Borders
To start of just make a small circle design on the boundary of the triangle on all 3 sides.
Step 6: Lets Start
Now its the the time to start covering the triangle by making the Zentangle patterns.
In this we did the zigzag straight lines patterns in which we make 7-8 close thin lines and then change the angle and keep on continuing till the end, e will move design from broad to thin side of the triangle.
In the second, we will cut the area in circular shape partitions after every regular intervals and then covering the alternate in black color.
Step 7: Spiral in This
In this pattern, its from the thin to broad side of the triangle.
giving a spiral pattern on the both sides alternatively, and the coloring it black from behind as shown in the image
Step 8: L Shape Design
this one is fairly easy pattern,
just separate the area with regular vertical partitions, and then making a L shape design in every partition and covering the upper area with all black color.
Step 9: Circular Motions
Start making circles depending on the area size and goes all the way to the bottom with smaller circles.
leave the circles and cover rest of the area with black color.
Step 10: Circular Spiral
this pattern is actually one of my favorite ones
just need to makes circular patterns from small to broad side of the triangle, connecting one after the other.
In every portion leave a smaller line similar to the bigger one, and then cover rest of the portion with black color.
Step 11: Long Area to Cover
start making circular portions segregated at equal intervals.
Just make the edges round from both sides.
Step 12: Half Way Through
Make circles of various sizes depending upon the space, leaving circles color rest of the area black.
Step 13: ZigZag This Time
make a zig zag line from broad side to the thin side.
The triangles formed because of the zigzag line, make a smaller triangle in each side, start coloring all the triangles one by one.
Step 14: Circular Sprial
the easiest one out of all, we just need to make a circular spiral of different size.
Step 15: Wavy Lines and Semi Circle
Just ahead of the design done in step 14, we will make wavy lines with their tip ending with a black small dot like design.
on the right of it, making circular partitions and covering with smaller lines in circular motions.
Step 16: Chess Board Pattern
Start doing a horizontal vertical lines pattern in the area. make a black dot on the intersection area where the lines are interseting.
Step 17: Thick ZigZag
the 2 Patterns covered in this, In one you just need to make sea shell likes design, smaller circles connecting one with the other like a chain.
In the other design, I separated the area with few thick vertical lines and then joining the borders with thick line from both sides alternatively giving a spiral effect.
Step 18: Road Like Design
In this divide the portion again with a circular motion partitions.
Cover alternate portions with black color while the remaining one give a dotted line effect.
Step 19: Spiral Paradox
In this, divide the area into smaller square area and the in each make the spiral like design like we made this in the Triangle in step 3. just a change it was in triangle in this we will make it in square.
Step 20: And We Are Done...
And we are done with the patterns in the triangle. Hope you liked it.
