Introduction: 2.4 TFT LCD Display + Arduino Code Fixed
I'm recently experimenting the 2.4" TFT LCD Display with Arduino, I bought the LCD not intended to do something but just want to know if it work or not. I searched the instructables, youtube but a lot of code didn't work, so I proceed an intensive case study to check it why, maybe my version of board differs, I start amend the existing code and finally got a breakthrough and hopefully can highlight to those others who are facing the same problem.
The original code name called tftpaint.ino, a simple online search can easily found it, I only highlighting the changes I made here to get it work.
1. Some code have used the library of SWTFT.h cannot work on my board, I change back to Adafruit_TFTLCD.h.
2. Corrected the define pins as
#define YP A3 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 9 // can be a digital pin
#define XP 8 // can be a digital pin
3. Re-allocated the anchor point for color blocks, seeming the XY coordinates of my board is differ
tft.fillRect(BOXSIZE*5, BOXSIZE*0, BOXSIZE, BOXSIZE, RED);
tft.fillRect(BOXSIZE*4, BOXSIZE*0, BOXSIZE, BOXSIZE, YELLOW);
tft.fillRect(BOXSIZE*3, BOXSIZE*0, BOXSIZE, BOXSIZE, GREEN);
tft.fillRect(BOXSIZE*2, BOXSIZE*0, BOXSIZE, BOXSIZE, CYAN);
tft.fillRect(BOXSIZE*1, BOXSIZE*0, BOXSIZE, BOXSIZE, BLUE);
tft.fillRect(BOXSIZE*0, BOXSIZE*0, BOXSIZE, BOXSIZE, MAGENTA);
Step 1: Change the Coordinates
4. Changed the point scale as stated
p.x = tft.width()-(map(p.x, TS_MINX, TS_MAXX, 0, tft.width()));
p.y = tft.height()-(map(p.y, TS_MINY, TS_MAXY, 0, tft.height()));
5. Amended the coordinates to display blocks and colors
if (p.x > BOXSIZE * 5) {
currentcolor = RED;
tft.drawRect(BOXSIZE * 5, BOXSIZE*0, BOXSIZE, BOXSIZE, WHITE);
} else if (p.x > BOXSIZE * 4) {
currentcolor = YELLOW;
tft.drawRect(BOXSIZE * 4, BOXSIZE*0, BOXSIZE, BOXSIZE, WHITE);
} else if (p.x > BOXSIZE * 3) {
currentcolor = GREEN;
tft.drawRect(BOXSIZE*3, BOXSIZE*0, BOXSIZE, BOXSIZE, WHITE);
} else if (p.x > BOXSIZE * 2) {
currentcolor = CYAN;
tft.drawRect(BOXSIZE*2, BOXSIZE*0, BOXSIZE, BOXSIZE, WHITE);
} else if (p.x > BOXSIZE * 1) {
currentcolor = BLUE;
tft.drawRect(BOXSIZE*1, BOXSIZE*0, BOXSIZE, BOXSIZE, WHITE);
} else if (p.x > BOXSIZE * 0) {
currentcolor = MAGENTA;
tft.drawRect(BOXSIZE * 0, BOXSIZE * 0, BOXSIZE, BOXSIZE, WHITE);
if (oldcolor != currentcolor) {
if (oldcolor == RED) tft.fillRect(BOXSIZE*5, BOXSIZE*0, BOXSIZE, BOXSIZE, RED);
if (oldcolor == YELLOW) tft.fillRect(BOXSIZE*4, BOXSIZE*0, BOXSIZE, BOXSIZE, YELLOW);
if (oldcolor == GREEN) tft.fillRect(BOXSIZE*3, BOXSIZE*0, BOXSIZE, BOXSIZE, GREEN);
if (oldcolor == CYAN) tft.fillRect(BOXSIZE*2, BOXSIZE*0, BOXSIZE, BOXSIZE,CYAN);
if (oldcolor == BLUE) tft.fillRect(BOXSIZE*1, BOXSIZE*0, BOXSIZE, BOXSIZE, BLUE);
if (oldcolor == MAGENTA) tft.fillRect(BOXSIZE*0, BOXSIZE*0, BOXSIZE, BOXSIZE, MAGENTA);
if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
Step 2: Finally Done
Last step to amend the clear screen code
if (p.y > TS_MAXY-30) {
Serial.println("erase"); // press the bottom of the screen to erase
tft.fillRect(0, BOXSIZE*1, tft.width(), tft.height()-BOXSIZE*1, BLACK);
