Introduction: 3 Simple PVC Football Field Goal DIY Décor
Watch Video:
So what is the most widely recognized football symbol in the United States? The field goal post of course. With football season in full swing I wanted to create some décor that any man or woman would be happy to display. These awesome field goals will make great conversations pieces at work and home.
So in this instructable, I will show you how to make 3 simple and yet very sturdy football goals. We are going to be using PVC and CPVC because it is easily found at any home improvement store plus it is easy to assemble. Also as long as you do not glue the joints, you can take it apart and store it away for next year.
The parts needed for all three goals are listed for each.
Step 1: 1st Field Goal
#1 Field Goal (All half-inch PVC)
Parts Needed:
6-inch pipe (x2)
4-inch pipe (x5)
2-inch pipe (x2)
1.5-inch pipe (x2)
T-fitting (x4)
Elbow 90-degree (x2)
End Caps (x6)
For the first goal, I am using all half-inch PVC and fittings. I recommend cutting and laying everything out on the table before assembly. Look at the picture for layout plans.
The assembly is straight forward and should take only about a minute. Make sure to press ALL connections tightly together to prevent slippage.
I do not recommend gluing the joint between the base and first vertical pole, so you can disassemble and store it away for next year.
If you want a larger field goal you can always change the length of the pipes to make them fit to your table or area.
Step 2: 2nd Field Goal
#2 Field Goal (All half-inch PVC)
Parts Needed:
6-inch pipe (x2)
4-inch pipe (x1)
2-inch pipe (x2)
1-inch pipe (x7)
T-fitting (x2)
Elbow 90-degree (x4)
Elbow 45-degree (x4)
End Caps (x2)
For the second goal, I redesigned the base on the first field goal. This goal is great for smaller tables and shelves where space is limited. The assembly is fast and easy. Look at the picture for assembly layout.
Step 3: 3rd Field Goal
#3 Field Goal (All half-inch CPVC)
Parts needed:
4-inch pipe (x2)
2-inch pipe (x5)
1-inch pipe (x4)
T-fitting (x4)
End Caps (x6)
The third field goal is almost half the size of the first goal and has the same shape and appearance. You assemble it together the same way as the first goal.
This field goal will make a great addition to any paper football game. Once you set up the goal, there will be zero arguments about someone cheating.
No matter which goal you choose to make, it is almost guaranteed to be a topic of conversation to any football fan.
Have fun building!
Philippians 3:14
