Introduction: 3 Ways to Revive Stale Bread
Three simple and easy ways to save your stale bread.
There are few things that are as delicious as a fresh baked loaf of bread hot out of the oven. It's also hard to eat an entire loaf of bread while it is at it's freshest. Keeping bread fresh is a losing battle, from the moment it is done baking it begins to lose it's moisture through a process called starch retrogradation. In the original baking process, the starch began to gelatinize above 150F and absorb moisture. Once absorbed, the starches swell and create the spongy fresh solid texture we associate with bread. As the starches recrystallize over time they loose the moisture that was once locked in in the baking process. By simply reheating your bread your starches will re-gelatinize and reinstall the soft texture we have come to associate with "fresh".
This Instructable will cover three different methods for remoistening your stale bread.
Step 1: Things You'll Need
Stale Loaf of Bread
Paper Towels
Aluminum Foil
1-2 Celery Stalks
Oven
Microwave
Step 2: Microwave Method
Steps:
Moisten a section of paper towel long enough to completely cover your loaf of bread (or the portion that you intend to eat). Do so by soaking your paper towel in cold water, and then squeeze out as much of the water as you can.
Wrap your portion of bread in your damp paper towel snuggly.
Place your covered loaf or slice into your microwave.
Microwave for 10 seconds.
Remove your bread from the microwave.
Remove it's paper towel covering.
Serve!
Step 3: Oven Method
Steps:
Preheat your oven to 300F (148.8C).
Tear off a piece of aluminum foil large enough to cover and wrap your bread loaf/slice in.
Wrap your bread in the aluminum taking care to make sure it is completely covered.
Place your foil covered bread into your warm oven for 5-20 minutes. If you are just heating a slice or small roll, you'll want to warm it for less time (closer to 5 minutes) than if you are warming and remoistening a larger or thicker loaf of bread (closer to 20 minutes).
Remove your bread from the oven and allow it to cool within the foil. You'll want to let your bread remoisten inside the foil so that as it cools it doesn't release it's remaining moisture as steam.
Serve and eat as soon as it's cool enough to touch.
If your bread is really dry, I occasionally dab a couple drops of water along the length of the bread loaf with my fingers. This will help to reincorporate moisture into your loaf beyond just reheating and softening. If you decide to add water, make sure that you don't over saturate your bread loaf otherwise you'll end up with mushy bread. Start small, you can always add more.
Step 4: Celery Method
Steps:
Slide a celery stalk inside your bread loaf bag.
Seal or close off your bag.
Place your bread bag with celery stalk back into the fridge and let it sit for several hours. I have had the best results when it sits overnight in the fridge.
Remove your celery stalk from the bag. It should be fairly dry and tough by this point having lost most of it's moisture the bread.
Step 5: Beyond Reviving
There is the possibility that your bread has dried out beyond reasonable or easy remoistening. If this is the case, try reusing your bread in other ways: make bread crumbs, make croutons, thicken a soup, or feed the birds!
38 Comments
1 year ago on Introduction
This process might sound like a "song and dance" but it really IS easy. I have only done this with Hamburger Buns and individual items such as scones, bread slices etc. This method works with frozen bread and stale buns etc. The power levels that you use will depend on the power of your microwave, but lower power works better than a setting that is too high.
Separate the top and bottom of the bun then lay out a clean cotton tea towel full length, and put the pieces beside each other, 3 or 4 inches from the far end. Fold the distant end of the towel over the top of the buns, then roll them towards you one time. Stop. Spray the towel lightly from a spray bottle filled with clean plain tap water. Roll the bundle in the towel towards yourself once and spray lightly again. If the towel is very wide, you should fold the sides into the middle and continue rolling the buns and spraying until all of the bun is enclosed inside the dampened towel. Don't over-spray the water too heavily, the amount you use will depend on how thick your tea towel is. After you're finished rolling and spraying, put the bundle in the microwave and run it at a reduced power level of 30% for approximately ??20 or 30 seconds?? I NEVER have the MW at full power or even half power because I think the bread comes out too steamy hot and rubbery. Gentle power for a slightly longer time allows the bread to get rehydrated all the way to the middle without wrecking the outside. Remove the bundle and turn it over to its other side, run the machine again at 20% power for 20 to 30 seconds. Remove from the microwave and check the bun to see if it's the way you want it. Repeat if necessary.
3 years ago on Introduction
A completely rock hard french stick (cut in half to fit in the microwave) took 20 seconds in the microwave. But was great.
6 years ago
That is not true. Dogs are omnivores, not carnivores, which means they can eat both meat and vegetables, including grains, just like people can. There are somethings we can eat that ghey should not, however. Chocolate and liquorice, for example, are very bad for dogs; but most grains are just fine.
6 years ago
i'm probably in the minority here, but I like stale/dry bread. not to say i dislike fresh though. i've only done the microwave/towel thing before myself, the others seem excessively wasteful to me.
Reply 6 years ago
Same here. Old, rock hard bread is awesome. Ever since I was a kid everyone I know was telling me that I would break my teeth that way, but who is listening.
6 years ago
Thanks for the tips -
Another idea would be prepare in advance - put the bread in a double layer of plastic wrap - inner wrap might be perforated but outer should be airtight.
8 years ago on Introduction
If you're storing your bread in the refridgerator then that is causing it to go stale quickly.
Reply 6 years ago
Actually, my wife buys a dozen loaves at once and we put them in the freezer. When we need one, we take it out and put it on one of the counters, but on trivet to let air circulate around the bottom too.
All this is done in the original wrapper, except for French bread which we cut in half and freeze them separately in those large zippered bags.
Once thawed we find the original fresh condition is returned, with the bread just the same as it was when it went into the freezer. Day old bread will again be day old. Oven fresh bread will be oven fresh, and stale bread will still be stale unfortunately.
Refrigeration, on the other hand just seems to ruin a loaf of bread, making it -I don't know - like it's stale or grainy and more course somehow.
Reply 6 years ago
I agree, the freezer preserves bread really well and refrigerator makes it stale in no time. If bread has spent much time in the fridge, when you bend it then it will be so bad that it breakes in two.
6 years ago
Great tips! Definitely going to try the microwave one!
6 years ago
If you have a vegitable steamer, then place the bread in the vegetable area and expose to steam. The amount of time is necessitated by the size of the bread. Usually under a minute is enough.
6 years ago
Thank you for the tips I use old bread to mix in to the dog's food. My goats love it too. I also put it in the compost bin.
6 years ago
Actually the best way i have found is the easiest. It does sound weird but it works. Get your bread and put on a place, then put a few sprinkles of water, enough to cover the bread and only the bread. So a slice of pizza will take like 2 or 3, a bread stick 1 or 2. Basically you want water to be touching off of the bread. If you have a piece that is all bread (like the bread stick) you could just turn the water on to about a medium stream and pass the bread through the water. Microwave on 30 second increments until fully warmed up. A slice of pizza usually takes about 30 seconds for me. Voila! Hot soft pizza or whatever you're eating in no time flat, without all the messiness of celery or wet paper towels.
Reply 6 years ago
I use our stale bread, buns, bagels, etc. and make the most delicious, crunchy croutons. So easy and fun to do.
7 years ago on Introduction
Thank you! I found this very helpful.
Thanks for sharing the information :)
8 years ago on Step 5
Don't forget French toast as a great way to use stale/dry bread. (It actually works best that way; fresh bread generally gets too soggy.)
Fun Fact: The French term for "French toast" is "pain perdu", meaning "lost [i.e., "wasted"] bread". :)
I like french toast, made from toast.
My mother-in-law made dumplings. She broke up the bread, soaked it in milk, added salt and a little flour; formed it in balls, and boiled them. There may have also been some egg. Very tasty with gravy.
Where was your mother-in-law from? The result (including eggs!) sounds very much like a Bavarian or Austrian "Semmelknödel" - very tasty indeed with gravy, one of the favourite kids meals in Bavaria...
