35mm Film Bag
Intro: 35mm Film Bag
Historically, 35mm film was made of triacetate, but newer film is made of mylar. This newer film is surprisingly durable, and can be pieced together to construct handbags and tote bags in a variety of sizes and shapes. The steps that follow document the construction of a medium-sized tote bag, but you can vary the measurements to make any type of bag you'd like.
Also check out the photos-only 'ible of this super cool bag!
STEP 1: You'll Need. . .
- 35mm film - trailers from newer films are suggested and can frequently be found on eBay for only a few dollars
- heavy-duty string (yarn can also be used if desired)
- sewing needle
- scissors
- ruler (optional but suggested)
STEP 2: Cutting Strips and Piecing
To construct this bag, the following strips of film are needed:
- 14 strips 12" long (7 per side)
- 2 strips 12" long (for the handles)
- 2 strips 26" long (for the sides and the bottom)
- Begin by threading your needle and overlapping the sprockets of two of the 12" strips
- Stitch through the sprockets to hold the two strips together (an up-and-down type stitch is suggested)
- Add another strip overlapping one of the two existing strips and sew through the sprockets to connect the strips
- Continue until you have affixed 7 strips to each other to form a sheet of film
- Repeat with the other 7 12" strips
- Fold up approximately an inch of each side of each of the two sheets so that the cut ends are not exposed
STEP 3: Sides, Bottom, and Handles
- Overlap the edges of the 26" long pieces and sew through the sprockets to connect them to one another (an up-and-down type stitch is suggested)
- Align the cut edge of the side piece with one of the sheets and sew through to connect them (an over-hand stitch is suggested)
- Continue around the bottom edge sewing through the sprockets before sewing up the third side
- Repeat to affix the second sheet to the side/bottom pieces
- Position the remaining 12" pieces where you would like your handles and sew to secure them to the bag (an up-and-down type stitch is suggested)
- Show off your awesome new bag!
32 Comments
yoyology 12 years ago
shesparticular 12 years ago
wish2snowboard 13 years ago
BrianJewett 12 years ago
You'll also probably need an army or boy scout type buckle with a sliding clamp since the film would probably tear immediately with a traditional buckle.
Good luck, and don't forget to post!
shesparticular 13 years ago
whitemanwalking 13 years ago
http://i45.photobucket.com/albums/f73/Jaffercake/DSCN0653.jpg
two-eight 13 years ago
mr.squeakers 13 years ago
As noted above, I was able to track down a trailer on eBay - there are lots of them available there but newer ones are suggested since they're cheaper and are more likely to be mylar film.
mb.marcie 13 years ago
Redline_lover 13 years ago
Thanks for the question!
jb17kx 13 years ago
Since the mid-1930s cellulose acetate films began to replace nitrate, with cellulose triacetate ending up replacing nitrate film in full in the West by the early 1950s. All was well and good, however we have come to learn that acetate film has its own problems; namely that under certain storage conditions acetic acid can be released from the base and cause the film to disintegrate.
The third, which has been around for as long as acetate but didn't come to much use until the early '90s, is polyester (Kodak's trade name for it is ESTAR). Its main advantages are that it's a) not flammable (but it will melt), and b) it's incredibly resistant to failure under tension or sheer force (but the downside is that an ESTAR jam in a projector will more likely destroy the projector rather than the film).
Provided you are using new trailers you will be fine. I'd suggest only using trailers for another reason too: older trailers, even pre-2000, are becoming increasingly harder to get for those people who actually want to preserve them or actually show them.
jb17kx 13 years ago
ilpug 13 years ago
