Introduction: 3.7V Battery Low and Full Level Indicator Circuit
Hii friend,
Today I am going to make a circuit of 3.7V Battery low and full charge indicator.
Let's get started,
Step 1: Take All Components As Shown Below
Components required -
(1.) Transistor - BC547 x1
(2.) Resistor - 1K x2
(3.) Resistor - 220 ohm x3
(4.) pn-Junction Diode - 1N4007 x1
(5.) LED - 3V x2 (Red for Low charge indication and Green for Full charge indication)
(6.) Battery - 3.7V and 3V
Step 2: Connect 1k Resistor
Firstly we have to connect 1K resistor to Base and emmiter pin of the transistor as solder in the picture.
Step 3: Connect 220 Ohm Resistor
Next solder 220 ohm resistor to collector pin of the transistor as you can see in the picture.
Step 4: Connect 1K Resistor Again
Next we have to connect 1K resistor again.
Solder 1K resistor in series to 220 ohm resistor as solder in the picture.
Step 5: Connect 1N4007 Diode
Next connect 1N4007 Diode to the circuit.
Solder -ve of Diode to base pin of Transistor as picture.
Step 6: Connect Green LED
Next Solder +ve leg of green LED to 1K resistor which is connected to collector pin of transistor and
solder -ve pin of green LED to +ve of diode as you can see in the picture.
Step 7: Connect Red LED
Next Solder +ve leg of Red LED to Collector of transistor and
solder -ve leg of Red LED to -ve of diode as solder in the picture.
Step 8: Testing - 1
Now our circuit is completed and now we have to check this circuit.
Connect +ve of 3V battery to +ve leg of green LED and -ve of 3V battery to emmiter pin of the transistor as you can see in the picture.
~ As in abouve picture glowing Green LED Because this battery is fully charged.
Step 9: Testing - 2
When I connected 3V battery then Red LED is glowing and Green LED is also glowing in small amount.
~ Hence when Battery will be full charge i.e. 3.7V then Green LED will glow only and when battery will be low i.e. 1.5V then Red LED will glow only.
Thank you
18 Comments
7 months ago
Thanks for this nice practical, so how can.I make a design for any type of battery like 6v, 9v, 12v etc?
Question 1 year ago
Sir can I use any type of resistance of this circuit
1 year ago
We want the red led to glow at 2 volt so what changes will be in the circuit
1 year ago
It doesn't work for my battery unfortunately. Red LED just never lights up while battery is draining. Eventually the green LED just turns off (Red LED works, I checked it out)
2 years ago
Thank u so much my friend, this circuit means a lot to me it is very short and simple to build
Question 3 years ago on Introduction
Hey Buddy can you explain how does this circuit work. Basically I am asking the working principle.
Answer 2 years ago
I want to know also .. in simulator it didn't work , but in plactical it worked on 9v,6v,4v,3.7v
Reply 2 years ago
Right, in simulator, fails ! (Simulide) using actual gain of bjt, and correct fvoltage for leds and diode...
3 years ago
You should protect the transistor's base with a resistor, actually it is directly connected via the green led (1.8V~) and the diode (0.6V) without any current protection. I need to test but I'm sure the transistor will get too hot.
Reply 2 years ago
You are totally right. It actually gets very hot @4v
Why we don't connect 9v battery
3 years ago
Where's the schematic? Not to complain but people need to be taught to wire from a schematic and not pictorial diagrams.
How to modify 6'9'12 volt circuit?
Answer 3 years ago
Moving the "plus" input on the other side of the 1k resistor, so between the 2 resistors (1k & 220), will change the voltage threshold. This circuit isn't reliable nor precise. Electronicians know diodes direct voltages aren't stable and that there's no zener effect even if it looks like.
3 years ago
Nice 1 buddy
3 years ago
would really love explanation of what happen too, and a way to test other batterie (1.5V, 9.0V, etc...)
3 years ago
Thanks for that .Its interesting . Do you understand what is happening in the circuit and can you explain that to me?
