Introduction: 3/8th Marlinspike
I made this marlinspike to make paracord knot work easier. The turkshead knot at the top acts as a knob which fits into your palm. I machined it from 3/8" aluminum bar. You can read more about marlinspikes below.
Marlinspike (/ˈmɑrlɨnspaɪk/; sometimes marlin spike, marlinespike, or the archaic marlingspike/marling-spike) is a tool used in marine ropework.
Shaped in the form of a polished metal cone tapered to a rounded or flattened point, they aid in such tasks as unlaying rope for splicing, untying knots, drawing marline tight using a marlinspike hitch, and as a toggle joining ropes under tension in a belaying pin splice.
Most marlinspikes are 6 to 12 inches long, but may reach 2 feet and more for working heavy cables and ropes. They are usually made from iron or steel, whereas fids, similar in shape and function, are formed from wood or bone. The marlinspike may be a separate tool or one item on a pocket knife.
Sailors who become proficient at knot tying, splicing, and sewing using the marlinspike are said to have mastered marlinespike seamanship, earning them the right to be known as marlin spikes or marlinspike seamen.
Source: Wikipedia
Source: Wikipedia
Step 1: Machine the Point
I offset my lathe carriage to 5 degrees. I then ran the cutting bit back and forth until a point formed. You don't want the tip too sharp otherwise it will pierce paracord rather than slip around it.
Step 2: Smooth Out the Shoulder
To ease the shoulder left behind from the 5 degree cut, I ran a file over the spike. Doing this makes it much easier to push the spike all the way through a knot. I then used sand paper to remove the tooling marks.
Step 3: Trim and Cut the Top
I didn't do an exact measurement. I just placed the spike in the palm of my hand and marked it so the length would be a couple guessed inches past my index finger. I then cut it down with a pipe cutter and machined the end round.
Step 4: Cut the Turks Head Groove
Using my calipers I measured and marked 15mm. I then cut a groove about 2mm deep. This will keep the turks head knot in place while the spike is in use.
Step 5: Polish
I polished the spike with a buffing wheel and polishing compound. This step is important. You'd be surprised how much more difficult it is to push an unpolished spike through a knot.
Step 6: Add the Knot
I followed this knot tying tutorial here. Using a paracord needle I ran a second pass and pulled it tight into the groove. I then trimmed the ends and tucked them in.
Thanks for reading.
Thanks for reading.
