Introduction: 3D Beaded Panther Head!!
This Instructable will show you how to make a 3D beaded pink panther head
Step 1: Gather Materials
You will need :
1. 57 Beads
- 54 Pink Beads (Rounds or other)
- 2 Yellow Beads (Bicone or other)
- 1 Pink Bead (Bicone or other)
- For this Instructable I will be using Faceted Round beads and Bicone beads, you can use different beads if you would like
2. String
- Approximately 5/6 Ft.
- Fishing line (6/8 Lb.) works best for 3D projects as it is very strong and thin enough to pass through the beads multiple times
3. Scissors
4. Nail polish
- If you don't have any nail polish you can use a permanent marker
- Red works best but any color will do
5. A Permanent Marker
- You will need a black permanent marker
Step 2: Fold String in Half
1. Cut a piece of string
- You want to make sure you have enough to finish the project without running out
2. Fold string in half
- Make sure that both ends are even
3. Paint the left end of the string
- Paint the string using nail polish or a permanent marker
- Let it dry for a minute
Step 3: Make Circle #1
1. Put 5 pink beads (Rounds) on the left end (Painted)
2. Pass the right end (Clear) through the last bead in the opposite direction
3. Hold both ends of the string even
4. Pull tightly to the center
Step 4: Make Circle #2
1. Put 3 pink beads (Rounds) on the left end (Clear)
2. Pass the right end (Painted) through the last bead in the opposite direction
5. Pass the right end (Clear) into the next bead
Step 5: Make Circle #3
1. Put 2 pink beads (Rounds) on the left end (Painted)
3. Pull to the center
4. Pass the right end (Painted) into the next bead
Step 6: Make Circle #4
1. Put 2 pink beads (Rounds) on the left end (Clear)
4. Pass the right end (Clear) into the next bead
Step 7: Make Circle #5
4. Pass the right end (Painted) into the next 2 beads
Step 8: Make Circle #6 & 7
1. Put 1 pink bead (Round) on the left end (Clear)
2. Pass the right end (Painted) through the bead in the opposite direction
Step 9: Pass Both Ends of the String Into the Same Bead
1. Pass the left end (Painted) into the next 2 beads
2. Pass the right end (Clear) into the next 3 beads
- Both ends of the string should now be through the same bead
- The left end of the string should be Clear and the right end of the string should be Painted
3. Turn the project
- The left end of the string should now be Painted and the right end of the string should be Clear
Step 10: Make Circle #8
1. Put 4 pink beads (Rounds) on the left end (Painted)
Step 11: Make Circle #9
Step 12: Make Circle #10
1. Put 3 pink beads (Rounds) on the left end (Painted)
Step 13: Make Circle #11
4. Pass the right end (Clear) into the next 2 beads
Step 14: Make Circle #12
2. Pas the right end (Clear) through the last bead in the opposite direction
Step 15: Make Circle #13
Step 16: Make Circle #14
2.Pass the right end (Clear) through the last bead in the opposite direction
Step 17: Make Circle #15
Step 18: Make Circle #16
4.Pass the right end (Painted) into the next 3 beads
Step 19: Make Circle #17 & 18
Step 20: Pass Both Ends of the String Into the Same Bead
1. Pass the left end (Clear) into the next 5 beads
- The left end of the string should be Painted and the right end of the string should be Clear
2. Turn the project
- The left end of the string should now be Clear and the right end of the string should be Painted
Step 21: Make Circle #19
Step 22: Make Circle #20
Step 23: Make Circle #21
1. Put 2 pink beads(Rounds) on the left end (Clear)
Step 24: Make Circle #22
Step 25: Make Circle #23 & 24
Step 26: Tie a Knot
2. Pass the right end (Clear) into the next 2 beads
- Both ends of the string should now meet up
3. Hold one end of the string in each hand
4. Tie a knot
- Make sure to pull the string as hard as you can without breaking it
5. Tie one more knot to make sure that it is secure
6. Pass one end of the string into a couple of beads
7. Cut the string
8. Pass the other end of the string into a couple of beads
9. Cut the string
10. Turn the project
- The front should be now be facing towards you
Step 27: Make Circle #25
1. Cut a new piece of string (Approximately 2 Ft.)
2. Pass one end of string into the top left bead in the third circle to the right of the circle that you just tied off
- This is where the snout will begin
3. Fold string in half
4. Paint the left end of the string
5. Put 2 pink beads (1Round & 1 Bicone) on the left end (Painted)
6. Pass the right end (Clear) through the last bead (Bicone) in the opposite direction
7. Hold both ends of the string even
8. Pull tightly to the center
9. Pass the right end (Painted) into the next bead to the right
Step 28: Make Circle #26
Step 29: Make Circle #27
1. Put 1 pink bead (Round) on the left end (Painted)
2. Pass the right end (Clear) through the bead in the opposite direction
Step 30: Make Circle #28 & 29
Step 31: Tie a Knot
1. Hold one end of the string in each hand
2. Tie a knot
3. Tie one more knot to make sure that it is secure
4. Pass one end of the string into a couple of beads
5. Cut the string
6. Pass the other end of the string into a couple of beads
7. Cut the string
Step 32: Make Eye #1
1. Cut a piece of string (Approximately 6")
2. Pass one end of string into thebeadbetween the left ear and the snout
3. Turn the beads to the left once
- The left ear and left side of the snout should now be facing towards you
4. Put 1 yellow bead (Bicone) on the right end of the string
5. Let the bead fall to the center
6. Pass the same end of the string (right) into the first bead to the right of the left ear
7. Pull tightly
8. Pass the same end of the string (right) into the next bead
9. Tie a knot with the other end of the string
10. Tie one more knot to make sure that it is secure
11. Pass one end of the string into a couple of beads
12. Cut the string
13. Pass the other end of the string into a couple of beads
14. Cut the string
15. Take a black permanent marker and draw a dot in the center of the eye
16. Let it dry
Step 33: Make Eye #2
2. Pass one end of string into the bead between the right ear and the snout
3. Turn the beads to the right once
- The right ear and the right side of the snout should now be facing towards you
4. Put 1 yellow bead (Bicone) on the left end of the string
6. Pass the same end of the string (left) into the first bead to the left of the right ear
7. Pull tightly
8. Pass the same end of the string (left) into the next bead
12. Cut the string
14. Cut the string
16. Let it dry
Rainbow Contest 2016
