Introduction: Building a 3D Biome Home!!!
My name is Bryce and I started this biome home back in November. It is now January and I am finally finished! The goal/objective of this project was to make a 3D model that could sustain a certain environment. We used basic materials such as wood, plastic wrap, and tin foil. A biome is an environment that can support animals to their certain needs but will pressure other species if they have not completely adapted to the environment. Figuring out where to start was a bit hard because I didn't know what kind of house to do but once I figured out the type of design i was going to do, it became easier and easier as time went on. Since the house was made of wood, I had to buy wood and then cut it(my dad helped me with cutting it) and after we chopped the wood, we started forming the shape of the house.
I used carpet, wood, glue, and tin foil, along with an apple juice box.
Step 1: Going to Work
First, you have to find your materials and cut them out to measure the size of the house you want. Then you will have to start building the design of the house so it will be sustainable and so it will fit upright and stand on its own. Then you will think of sustainable aspects.
Step 2: Aspects
After building your house you have to start adding some sustainable aspects so you can survive in the environment. When adding them, you need to think in what order you will add them because if they are added in the wrong order. you could possibly screw up the design of the house.
Step 3: Finishing Your House!
After adding all of your aspects, you can we want to look over your house to make sure everything is in place and secured correctly. As long as everything is good and in place your house is complete!
