Introduction: 3D Cardboard Labyrinth Maze
About: Smoll Time Maker. I mostly work with cardboard and paper. Like making stuff. Aspiring inventor/engineer. YouTube:https://www.youtube.com/channel/UCcu0AbsG0LjzM5cmmLvkAUw?view_as=subscriber
Hi Everybody,
My name is Asray and I am a 15 year old who has a keen love of making projects out of cardboard.
Today I will show you all how to make a 3D Labyrinth Maze made out of cardboard.This project is simple to make and super fun to play with. Traditionally, mazes are 2D and super boring to play with but I made a maze with a twist so that it is challenging and fun to play with.
(P.S. This is the first instructable I'm ever writing and I'm submitting this to the Instructables Toys and Games Contest. Pls vote for me :) )
You can see how this works in the youtube video I made:
https://www.youtube.com/watch?v=Kl4KByf-p64
  • Cardboard (Thickness: 3mm [preferred])
  • Hot Glue/Superglue
  • Blade/Paper Cutter
  • Pen/Pencil
  • Ruler/Scale
This is a really easy project to make and as you see, very few materials are required. Materials are easy to obtain and very cheap.
Step 1: Cut Out Two Cardboard Squares Measuring 15.3 Cm X 15.3 Cm
Step 2: Cut Out a 3 Mm X 7.65 Cm Slot in the Cardboard Squares Equidistant From Each Side
Draw parallel line which has a width of 3 mm and 7.5 cm away from both ends. Then on the marking created by the parallel lines, using a blade, cut a segment of length 7.65 cm. Do this for both the cardboard pieces.
Step 3: Draw a Square Graph of 1.5 Cm X 1.5 Cm on Both the Cardboard Pieces.
Step 4: Cut Out Another Piece of Cardboard Measuring 15 Cm X 15 Cm. Draw a Graph of 1.5 Cm X 1.5 Cm. Then Cut It Into 4 Equal Parts. on Each Part Cut Out One Square on the Corner.
Step 5: On the First Two Cardboard Pieces, Cut Out the Cardboard As Shown in the Images.
Step 6: Glue and Attach the Cardboard As Shown in the Pictures.
Step 7: Add the 4 Cardboard Pieces (from Step 4) to the Middle of the Structure With the Openings Outwards. Look at the Pictures for Reference.
Step 8: Cut Out Strips of Cardboard of 0.8 Cm Width. Prepare 50 of These Strips for Making the Maze Walls.
Step 9: Glue the Cardboard Strips As Shown in the Pictures. Glue the Strip Pieces With Reference to the Graph (Step 3). This Is Part 1 of 8 of the Maze.
Step 10: Maze : Part 2 of 8
Glue the cardboard strips as shown in the pictures.
Step 11: Maze : Part 3 of 8
Glue the cardboard strips with reference to the pictures.
Step 12: Maze : Part 4 of 8
Step 13: Maze : Part 5 of 8
Step 14: Maze : Part 6 of 8
Step 15: Maze : Part 7 of 8
Step 16: Maze : Part 8 of 8
Glue the cardboard strips with reference to the pictures. You're done glueing the internal parts of the maze.
Step 17: Cut Out 6 Strips of Cardboard Measuring of 2 Cm X 15 Cm and 8 Strips of Cardboard Measuring of 2 Cm X 6.5 Cm. Glue the Strips of Cardboard to the Edge of the Cardboard Maze Structure.
Glue the cardboard strips to the edges of the structure so that the ball doesn't fall out of the maze.
Step 18: Glue Pieces of Paper to Mark the Start and End of the Maze.
Step 19: The Maze Is Finished! Put a Tiny Bb Gun Ball in It or a Bead to Play. Play With It and Record Your Final Time.
Thank You for reading my article on how to make a Cardboard 3D maze. Pls do make it as it is fun to play with and make.
I am also entering this project to the Instructables Toys and Games Contest. Pls vote, I would be happy to win this contest. As a rookie instructable writer it would be great for me to win.
