Introduction: 3D Cutting Board
Dazzle the guests at your next get-together with this amazing 3D cutting board! Or create a gift for that "hard to buy for" person on your list.
Step 1: Materials
Depending on the size of the cutting board you are planning to build, you will need different lengths of wood.
- Cherry
- Walnut
- Maple
- Table saw
- Sander
- Planer
- Wood glue
- Butcher Block Oil (for the finish)
Step 2: Planing
Plane all three types of wood to the same size. I cut and planed my pieces of wood down to about 1 1/2" by 1". The lengths were various sizes.
Step 3: Cutting
There are many different methods used to make a diamond shape out of each type of wood. I chose to use the miter saw method. Set the miter saw to 30 degrees. Cut the end off of the piece of wood. Measure from end to end on your cut, use this measurement to set up a stop on the miter saw. Now cut all the wood into diamond-shaped pieces.
Step 4: Start Gluing
After cutting all the pieces, start gluing them all together until you have enough for your cutting board. Once again, this will depend on the length and width you desire your cutting board to be.
Step 5: More Gluing
After the glue dries on the smaller pieces, lay them out the way you want them, making sure to have them in the same pattern . Place pieces of wood along the outside. Then glue and clamp all the pieces together.
Step 6: Cutting... Again
After the glue dries, plane the cutting board down. Then cut off the excess pieces to create a straight edge on the cutting board.
Step 7: More Gluing and Cutting
Cut some wood for the trim around the cutting board. (I chose walnut for the trim.) Glue the trim around the cutting board on two opposite sides. Then after it dries, cut the leftover material off. Do again on the other two sides. then plane it down. Now it's almost done.
Step 8: Beauty Work
If there are any cracks or holes, just mix some sawdust and glue together and scrape it on the spots. Then sand it off and it should look pretty nice.
Step 9: Finishing Up
Use a 1/4" router bit around all the edges. Sand it down until your happy with it. To finish the cutting board I put a couple of coats of butcher block oil on it. I also put some cork pads on the bottom (make sure to use the best side as the top).
Step 10: Finished
Woodworking Contest
26 Comments
3 years ago on Step 10
Very nice but not end grain.
Reply 3 years ago
Thanks for the clarification.
Question 3 years ago on Step 2
I love this project, but as I was trying it out, I clearly got the dimensions of the cuts wrong. Could you clarify those measurements? My diamonds are not working out...
Answer 3 years ago
You have to cut your 1x1 piece of wood at at a 30 degree angle. Make sure that when you cut it again that the length of the piece is the same length as the edge to edge measurement of the previous cut. It takes some fiddling around before it fits right. Hopefully this helped.
3 years ago
This is the most amazing cutting board i ever seen!
BRAVO!
Reply 3 years ago
Thanks!
3 years ago
Awesome,looks fantastic,great job!
Reply 3 years ago
Thanks
3 years ago
Very nice. Just one (probably overly pedantic) point though- it's not end-grain...
Reply 3 years ago
If you wanted the endgrain look, you could rip the boards at a 30 degree angle on two opposite sides, then make square crosscuts the thickness you desire for the endgrain.
Reply 3 years ago
Thank you for the advice
3 years ago
does it matter the type of glue you use. ie food grade glue?
Reply 3 years ago
Any wood glue should be OK once cured as long as it was at least water resistant. A foaming glue like Gorilla Glue might make it harder to get tight joints. I would recommend TiteBond II (water resistant) or TiteBond III (waterproof, but somewhat more expensive).
3 years ago
This was absolutely beautiful - and I get completely messed up looking at it - and even more at some of the construction images. Have to make it!
3 years ago
Looks awesome. I'd just be afraid that I would have trouble cutting in straight lines ;) with the realistic 3D effect.
3 years ago
Great work! I made something similar many years ago for my wife with floorboards from the school she went to. In quilting, that's known as a "tumbling block" pattern.
3 years ago
Really nice work! Almost too pretty to cut anything on... :)
3 years ago
Wow that is amzing . Some really talented people out there !!! Nice work !!!!!
3 years ago
I really like this!
Reply 3 years ago
Thank you!
